Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Brazing
Old 01-27-2020, 10:08 AM   #1
Default Brazing
Question
Is the term brazing being used when actually silver solder is the filler?
pep
JacktheRipper is offline   Reply With Quote
Old 01-27-2020, 11:01 AM   #2
Default Re: Brazing
Originally Posted by JacktheRipper View Post
Question
I couldn't tell you the official definition but around here people will use the term brazing if the filler is silver solder or brazing rod.
svt923 is offline   Reply With Quote
Old 01-27-2020, 12:13 PM   #3
Default Re: Brazing
If it requires 840° or greater to melt your filler, it's called brazing, regardless of the silver content of said filler.
TheLetterJ is offline   Reply With Quote
Old 01-27-2020, 07:08 PM   #4
Default Re: Brazing
I use Silicon Bronze rods to tig when I build my stuff and consider that brazing. I like J’s definition though.
Lashlee is offline   Reply With Quote
Old 01-28-2020, 05:17 AM   #5
Default Re: Brazing
Terminology is important, and the use of the words can influence & motivate.
I have mig, tig, tanks & torches, weld, tig and braze the later not often.
I think that silver soldering for the scale world, would be preferred because of the way it flows.
When parts are joined that joint is nice and clean, not like the bird droppings seen when folks braze. It is very obvious, to tell the difference, no amount of grinding helps...... joints are to tight to clean it up.
And now with the Silicon Bronze, offering the advantage of joining dissimilar metals, stainless & steel even better.
So mixing the terms haphazardly, might be confusing some one that might be considering upping their game.
I know enough about metal work to build little cages & bumpers.
pep
Brazing - Similar Threads
Brazing...You can do it if I can! RyansRubicon.co Tools, and Procedures 22 03-30-2010 02:22 PM
Brazing bigdodge88 General Crawlers 6 07-22-2008 10:31 PM
brazing revoracer99 Tools, and Procedures 1 03-01-2008 12:12 AM
need some help with brazing iceman320 Tools, and Procedures 8 02-03-2008 05:50 PM
brazing Trimmy Tools, and Procedures 4 01-14-2008 02:20 PM
