04-30-2022, 05:00 PM | #1 |
RCC Addict Join Date: Feb 2017 Location: Surprise
| So my screw is rounded out
So, i have to change the rear stub axles, the screw is stripped(rounded out) how do i take it out? I hope i can?? I know there is a way(HOPEFULLY)to take it out without damaging the housings,if not any idea fellas? Please heeeelllllllpppppp! Thanks again. |
04-30-2022, 05:05 PM | #2 |
Rock Crawler Join Date: Jan 2022 Location: st louis
| Re: So my screw is rounded out
Torx bit, set of standard hex keys, make sure your hex keys aren't worn out of the end. If none of that works, then it's carefully with a drill to get the head of the screw off then vise grips to grab and remove the threaded shaft. Sent from my SM-N975U using Tapatalk |
04-30-2022, 08:20 PM | #3 |
Lousy pic but i can't/wouldn't be able to get some kind of pliers/vice into that spot. Sent from my LGMP450 using Tapatalk |
04-30-2022, 08:36 PM | #4 |
i cant make out a thing in that picks maybe a better pick the torques bits work good ive also had good luck hammering a flat head in to the allen head and loosening them that way what ever way you try make sure to use enuff heat to loosen any thread lock or tight threads before you try to remove thw striped screw Last edited by ferp420; 04-30-2022 at 08:41 PM. |
04-30-2022, 09:01 PM | #5 |
Yeah my phone is a 6 year old phone. Sorry about the pic. I tried the screwdriver trick kept on spinning. Drilling it out, how does one do that. Same size as the screw? How about the threads? Even if i did get the head off, how would i take the screw out? Sent from my LGMP450 using Tapatalk |
04-30-2022, 09:33 PM | #6 |
Rock Crawler Join Date: Apr 2015 Location: San Marcos
Yeah, same size drill bit as the diameter of the screw's shank. You could probably go down a size too just to be safe. Start drilling into the head slowly. Once your bit gets through the head, it'll snap off. There should be enough exposed screw shank that you can put vise grips on it, and turn the screw out. Another option is to use a Dremel or something to cut a straight slot in the screw head. Then use a flathead screwdriver to turn it out. |
04-30-2022, 11:46 PM | #7 | |
| Re: So my screw is rounded out Quote:
you need a really good pair of vise grips to pull this off though | |
05-02-2022, 10:55 AM | #8 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
Man, if you back the camera off a little, it would probably come into focus. I can't tell from the pic what vehicle you are working on, so I cannot picture how to help. This set of pliers is meant for helping to remove stripped screws. I have used mine a couple times and they work great. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
05-02-2022, 11:46 AM | #9 |
Its the Losi LMT..... And those pliers will not enter that small place....lol Even if i did back the camera out, still won't take a better pic....lol |
05-02-2022, 12:11 PM | #10 |
| Re: So my screw is rounded out |
05-02-2022, 01:35 PM | #11 |
Lololol.... Thanks i guess...lol So i have cheap drill bits, taking forever to take the head off by drilling it, is there like better drill bits that won't grind away? My drill bits are cheaply made. Lol |
05-02-2022, 02:28 PM | #12 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
Did you try a torx bit? I bought a small Torx bit set 2nd hand off my buddy and it’s the best $10 I’ve ever spent. Haven’t worried about a stripped screw since. A flathead bit may even work in a pinch. __________________ Amain Addict |
05-02-2022, 03:28 PM | #13 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
05-02-2022, 04:25 PM | #14 |
Yes, i did buy some.... Nope did npt fit...needed it longer and thinner to be able to fit in that mounting hole. Now just drilling the head,y bit kinda rounded out too(or flat) so now i have to buy new stronger drill bits... LOL sure taking a long time...lol |
05-02-2022, 04:25 PM | #15 |
05-02-2022, 06:10 PM | #16 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
Not sure where you're currently at with this now so disregard if this isn't relevant but could you try to use a very thin flat-blade screwdriver and maybe even ( if its a cheapo screwdriver) grind it down to sharpen it a bit or make it more narrow... Then push or tap it into the stripped screw head enough for it to engage and then carefully try to back it out/ unscrew it? Anyway.. Just wanting to help. Disregard if it's past that point or if I've missed something. Hope you get that bugger outta there. |
05-02-2022, 08:26 PM | #17 |
Itttttt'sssss OFF, yay! Many, MANY, thank you's to this swell group of fellas!!! Came off, now i need a pair of vise grips.... Mine broke so need a new pair! LOL It came out in a flash.. Funny how better built bits make difference. AGAIN thank you! |
05-02-2022, 09:47 PM | #18 | |
glad it came out | |
05-03-2022, 08:13 AM | #19 |
05-08-2022, 01:17 AM | #20 |
I kinds knew what you meant after i figured it out at lowes. Lol So the lockout sled off real easy. Then.......noooooo, i couldn't get the screw off with the vise grips, they squashed the end of the screw, i couldn't grab. So got the needle nose pliers with the wire cutter part, grabbed ot and screw it off....whew! Lol Again a MILLION THANK you's for the help! I thought i had to buy a new housing??! LOL didn't have too! |
So my screw is rounded out - Similar Threads | ||||
Rounded off set screw in drive shaft. | racenut | Axial SCX-10 | 15 | 07-17-2015 07:39 PM |
Removal of rounded set screw? | Crutch | Tools, and Procedures | 13 | 04-09-2015 10:32 PM |
Rounded wheel hubs | optikalillushun | Newbie General | 3 | 11-30-2012 03:25 PM |
Flat or rounded carcuss...........TIRE? | RealDeel | Tires and Wheels | 1 | 07-09-2008 01:56 PM |
help with rounded off screws.. | mudhunter | Tools, and Procedures | 12 | 12-01-2006 07:39 PM |
