12-20-2006, 11:17 AM | #61 | |
Pebble Pounder Join Date: Sep 2004 Location: Livermore, CA
12-20-2006, 01:02 PM | #62 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
I would say no... I snapped them with maxx size tires... snapping CVD's has alot to do with weight, how you wheel and what brand they are. |
12-20-2006, 01:40 PM | #63 |
Pebble Pounder Join Date: May 2005 Location: United States Of America
I have some 8mm cvd's that i made a while back if you want them PM me .
12-20-2006, 10:20 PM | #64 |
Rock Crawler Join Date: Sep 2006 Location: Lititz
I think weight definetally played a role. Also I discovered that a bearing in the knucle was trashed. When I designed the axles I was allready pushing the cvd pretty close too bind, and all the slop from a bad bearing might have pushed her over the edge.
12-20-2006, 11:24 PM | #65 |
Returned your PM, Also consider if you are interested in spring steel , as I have used that for some universals. DO you think that your angle of the axles is to severe that , that is what causing you to rip bearings more then usual? |
12-21-2006, 12:04 AM | #66 |
Probably doesn't help any. This was my first build, and I thought a lot of center diff clearance would be a big advantage. Maybe if the driver would learn to recognize a bad hang-up it would help a lot . The truck is 15lb. and has plenty of power, something's gotta give. |
12-21-2006, 12:39 AM | #67 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
this is the most amazing thing have ever seen, and i want it.
12-22-2006, 12:21 AM | #68 |
TEAM RCC Join Date: Jul 2006 Location: Novato
i love this thing nice job
12-24-2006, 12:12 PM | #69 | |
Rock Crawler Join Date: Jun 2006 Location: Sinking Spring
12-27-2006, 07:59 PM | #70 |
Newbie Join Date: Dec 2006 Location: Prior Lake
man thats cool, i want it too!
01-30-2007, 10:33 PM | #71 | |
Newbie Join Date: Jan 2007 Location: Spirit Lake
Assuming you used a CNC, What would it take to get a copy of the DXF files? Quote:
01-30-2007, 11:40 PM | #72 |
Pebble Pounder Join Date: Jan 2007 Location: Superior
Simply beautiful. If I could only fathom that build I would take the broken parts------> |
01-31-2007, 03:54 AM | #73 |
Pebble Pounder Join Date: Oct 2006 Location: Enterprise
Extremely nice rig. You said it weighs 15lbs right? You also said it has a lot of power. It looks like your not running foams too right? I think the reason your breaking the shafts is a combination of the weight of the vehicle and the traction of the tires(they look pretty squished down in some of the pics). Also moab xl's with aluminum rims is a lot to turn. Still, I want that rig |
01-31-2007, 04:37 PM | #74 |
I was running star cut foams, I now have full foams. I like the full foams better. I think the axle design lets the wheel drop into holes and cracks, that a strait axle would bottom out on, that really can bind a wheel and of course you try to get free and welll, something breaks. I set my slipper up now to slip a little before she stalls, hopefully that will keep me out of trouble. |
02-01-2007, 12:49 PM | #75 |
Very nice fab work.. truck looks great The bumpers look like upside down versions of the DG bumpers I had on my quad 15lb. rigs will break alot of parts. Specially with power/torque. The best advice, is what you have already done. Loosen up the slipper clutch some. |
02-06-2007, 11:51 AM | #76 |
Newbie Join Date: Nov 2006 Location: surrey, british columbia
| reply
i like your maxx tubler keep the good work up man |
02-17-2007, 08:06 PM | #77 |
Newbie Join Date: Feb 2007 Location: philly
wow that is a real nice tuber its really good |
02-22-2007, 10:28 AM | #78 | |
Newbie Join Date: Feb 2007 Location: Long Island
Where'd you get those axles? Want to build a tube frame for me??? | |
02-22-2007, 11:03 AM | #79 | |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
What CVD brand of CVD did you break ? How did it break? What kind are you replacing with? | |
02-24-2007, 06:43 PM | #80 | |
I don't make tube chassis for sale. There are guys on here that do. If you can't find one, I can put you in touch with a guy in our club who does. | |
