Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: TRX weightloss tip
Old 04-22-2018, 03:57 PM   #1
Default TRX weightloss tip
My TRX need to loose some weight to be a competive scale crawler. What's the best tip to loose some weight?
I've changed the body on mine to a proline commanche body, got rid of the shift servos for the axles and made a custom battery mount.
I know the links are quite heavy, but what else?
Desmo is offline   Reply With Quote
Old 04-22-2018, 06:37 PM   #2
Moderator
JatoTheRipper's Avatar
Default Re: TRX weightloss tip
There's a lot of plastic that can be taken off like the fender wells. Remove remote locking diffs and servos and install from lockers.
Old 04-22-2018, 07:02 PM   #3
Maybe shave a few grams by replacing stainless/ steel screws/ nuts with aluminum... low stress areas like plastic, lexan, rx box, etc.
high plains drifter is offline   Reply With Quote
Old 04-23-2018, 02:41 AM   #4
This is my current setup. No inner fenders and no shift servos. Lighter body. Lighter and lower batterytray. Lockers and overdrive. Added weigt is brass portal covers front and rear.
Sent fra min FRD-L09 via Tapatalk
Old 04-23-2018, 06:42 AM   #5
My rig is 8.2 pounds with no brass and I run a hard body. It’s SORRCA C1 legal and I took first place in both C1 and C2 (still on 4.19 tires) with it yesterday. Weight can be a good thing.
rm25x is offline   Reply With Quote
Old 04-23-2018, 06:49 AM   #6
What weight can they be for each class?
Sent from my SM-G955U using Tapatalk
Feldhege is offline   Reply With Quote
Old 04-23-2018, 07:19 AM   #7
CODYBOY's Avatar
None of the classes have weight restrictions. They for the most part are about tire size, tire coverage with body, and bumper sizes. That is a kind of "in a nut shell" answer!!!! You can find SORRCA rules here: 2018 Rules are up!
Ernie
CODYBOY is offline   Reply With Quote
Old 04-23-2018, 08:04 AM   #8
Moderator
Nice. Who makes those front, brass knuckle weights?
Old 04-23-2018, 09:21 AM   #9
Mine's 8.5 with brass. Got around 110 gram on each portal cover on the front axle. Got SSD portal covers on the rear axle wich is about 70 gram on each side.
Think my plan must be to get some titanium links, lighter wheels, lighter chassis (come on Brazin ), convert to single speed and brush less.
Old 04-23-2018, 10:17 AM   #10
Can't remember. Some no name ebay china shop.
Old 04-23-2018, 10:30 AM   #11
There's already brass everything for the TRX on eBay and AliExpress. No wait, not sure if I've seen brass tires. Male that almost everything.
Ninomaniac is offline   Reply With Quote
Old 04-23-2018, 12:41 PM   #12
Chuck the receiver in a balloon and loose the box if you after loosing every gram. Get rid of the side rails?
o0wiz0o is offline   Reply With Quote
Old 04-24-2018, 07:30 AM   #13
Originally Posted by Natedog View Post
Yes to losing rx box, but side rails help hold my body and I trimmed off about 1/2 the width, still works great but lighter weight and squeezes past obstacles easier.
Any pictures?
Old 04-24-2018, 12:19 PM   #14
Anyone know the wb of the Samix titanium links? https://www.amainhobbies.com/samix-t...025hls/p702639
I'm looking for 313wb titanium links.
Old 04-24-2018, 03:46 PM   #15
I took a drill bit to the body mounts/posts and shock mount braces to shave a tiny bit of weight, drilling through where it was strong enough to take it and dimpling other areas it wasnt. I cut off the bottom of the body post that hung below the post mounts as I never plan on lifting the body any more.
It was a minuet amount of weight
HumboldtEF is offline   Reply With Quote
TRX weightloss tip - Similar Threads
need a tip sc10 man Non Crawler RC's 2 05-08-2012 04:26 AM
Wraith tip JUGGARNAUT Axial Wraith 2 10-29-2011 05:45 PM
new to berg any tip gram lanier Newbie General 10 02-16-2010 12:34 PM
Rocklights Tip... HEAVY METAL Electronics 3 01-12-2008 09:34 PM
Do You Tip At Sonic? Robb Chit Chat 18 08-08-2006 10:07 AM
