03-27-2018, 09:41 PM | #1 |
Quarry Creeper Join Date: Aug 2017 Location: KY
| New TRX4 owner
Been kicking around getting one. Pulled trigger on a kit tonight. Look forward to putting it together and learning about the platform. |
03-27-2018, 10:35 PM | #2 |
Rock Stacker Join Date: Aug 2017 Location: In the woods
| Re: New TRX4 owner |
03-28-2018, 06:30 AM | #3 | |
Quarry Creeper Join Date: Apr 2012 Location: Harrisburg
| Re: New TRX4 owner Quote:
Check the fitment of the bearings into any metal gears. I broke a gear that wasn't machined properly by trying to press it in with a cross-slide vice. Sent from my HTC Desire 626 using Tapatalk | |
03-28-2018, 06:42 AM | #4 | |
Leaning toward maybe doing the SSD Portal Delete, spool the rear and leave the front unlockable. Eh, I'll wait til I get it in my hands and check it out first. | |
03-28-2018, 06:43 AM | #5 |
| Re: New TRX4 owner
@tcanin00 - thanks man, I'll for sure keep a watch for that!
03-28-2018, 08:12 AM | #6 | |
The Vaterra K-5 Blazer is a great fit, and the wheel base is almost dead on. It's kind of thrown on with adapter I made for an SCX 10. Since this test run, I was able to lower the body a 1/2" and swapped the bumper brackets from front to rear and flipped them to get the front bumper up higher. Sent from my HTC Desire 626 using Tapatalk | |
03-28-2018, 08:28 AM | #7 |
Newbie Join Date: Feb 2018 Location: Charlotte
| Re: New TRX4 owner
Could we ask the source of the blazer Body? Great looking setup Thanks |
03-28-2018, 08:59 AM | #8 | |||
Pebble Pounder Join Date: May 2017 Location: Livin in SL,UT
The K-5 looks BA on there! Last edited by Summitonslingrs; 03-28-2018 at 09:03 AM. | |||
03-28-2018, 10:49 AM | #9 |
03-28-2018, 01:34 PM | #10 |
| Re: New TRX4 owner
Appreciate the update Keep up the great work Enjoy |
03-28-2018, 02:27 PM | #11 |
03-28-2018, 06:44 PM | #12 |
| Re: New TRX4 owner
Another vote for the Ascender K5 Blazer body on the TRX4. I was not aware that Vaterra had discontinued the K5, glad I have a spare unpainted one. With the use of the LURC Ascender conversion body mount they are a drop on fit. https://www.shapeways.com/product/YN...ionId=64364712 Last edited by Inspector86; 03-28-2018 at 06:52 PM. |
03-28-2018, 07:28 PM | #13 |
| Re: New TRX4 owner Sadly, it's true. I saw the rumor on here and I reached out to Rich Trujillo and he confirmed it. He said there wasn't enough demand to satisfy the minimum order quantity required to get more bodies. |
03-29-2018, 05:15 AM | #14 |
03-29-2018, 05:25 AM | #15 | |
I looked at the LURC adapter you posted. The pre-drilled holes in my Blazer are almost an inch too far forward to line up with the TRX 4 posts. They're off-center by almost a 1/4" to the right as well. Maybe since I ordered it unpainted, Vaterra's hole drilling guy said "F#ck it, send it." Sent from my HTC Desire 626 using Tapatalk | |
03-29-2018, 10:19 PM | #16 |
| Re: New TRX4 owner Jato, Do you think the Horizon/Hobbico deal might change the availability of the K5 body in the future?
03-30-2018, 07:19 AM | #17 |
04-01-2018, 07:08 PM | #18 |
| Re: New TRX4 owner
Still haven’t cracked the bags on this kit yet. Can’t decide what body to run..... Have got a Hobbywing 1080, Power HD servo, Traxxas spools, single speed kit, 9T pinion and link module on the way. I plan to spool the rear, but leave the front selectable for now, I think I may like that. I want to be able to change the diff locks with function, hence the link module. I should have a diff lock and speed control function “free”, not sure what I could use those for just yet. I’ve got a set of Hyrax with CI Lil Nova foams on Axial 8-holes I could use (if the wheels will work. Also have a set of CI foams that should work with the stock tires, not sure which I’ll run. I may try the DIY beadlock mod on the factory wheels since they’re cheap enough it don’t make much sense to sell them. I will throw the stock servo and esx in the classifieds I guess. |
New TRX4 owner - Similar Threads | ||||
Rebuilding my trx4. | Evo93 | Traxxas TRX-4 | 24 | 03-19-2019 08:12 PM |
Vedo's TRX4 | Vedo | Traxxas TRX-4 | 15 | 04-22-2018 07:28 PM |
Unimog trx4? | twisted | Traxxas TRX-4 | 2 | 04-04-2018 02:30 AM |
XJ owner out-asshole parks Corvette owner..... | STANG KILLA SS | Chit Chat | 18 | 09-30-2014 06:20 PM |
