04-03-2020, 02:02 PM | #1 |
Quarry Creeper Join Date: Aug 2013 Location: Bullard TX
| Looking for aftermarket shock hoops.
I'm looking for shorter shock hoops for my Bronco. I know Locked Up makes some for the rear of a SCX10 but I can't find any for the TRX4. I have a Deadloc low COG chassis installed on my Bronco and I need something that's a shorter shock hoop, the stock mounts are too tall and I can't fit my body as low as I want. I'm about 1/2 in above the electronics skid plate with the body sitting on the front shock mount, even without body posts. Any help is appreciated. I don't want to have to swap back to the stock chassis. Last edited by struhall; 04-03-2020 at 02:04 PM. Reason: Added pic of problem |
04-03-2020, 06:12 PM | #2 |
Rock Crawler Join Date: Jun 2015 Location: In the Sticks in the Ozarks
| Re: Looking for aftermarket shock hoops.
These are from Xtra Speed. (the ones on the right, I broke one of the leftys) They're a little shorter than the stock ones and you could cut the top row of holes off. That would make 'em another 1/4 inch shorter. They're just barely taller than my servo, but it is shim'd up a couple of mm. Just a thought. jim Last edited by dr frankenstyle; 04-03-2020 at 06:15 PM. |
04-03-2020, 07:01 PM | #3 |
Quarry Creeper Join Date: Nov 2018 Location: Oakley
I havent really seen any that are shorter, only taller.
04-03-2020, 08:04 PM | #4 |
Instead of shock hoops, I think you should checkout cantilever suspension. https://www.rcmart.com/xtra-speed-ca...28086-00082632 https://www.ebay.com/itm/Xtra-Speed-...-/143219961051 |
04-03-2020, 11:09 PM | #5 |
Jato, the front of the body hits the inner fenders like it was. I did some more measuring today and the difference I needed was right at the amount the arches raised with the aftermarket chassis so I swapped back to the stock rails. Got it sitting right on the stock skids and low enough to hide the stock electronics tray. I still need to trim the front of the inner fenders, they are hitting my light buckets and pushing the body forward. |
Looking for aftermarket shock hoops. - Similar Threads | ||||
Aftermarket shock caps & collars compatible with Axial shock bodies? | Jim85IROC | Axial RR10 Bomber | 5 | 08-31-2017 07:53 AM |
Shock hoops | BIKETROLL | RC4WD Trail Finder 2 | 6 | 12-13-2016 06:23 PM |
Shock & spring advice for GCM shock hoops. | Ca. Off Roader | Vaterra Twin Hammers | 11 | 01-04-2016 12:17 PM |
SCX10 Shock upgraded Shock hoops | natskiboy | Axial SCX-10 | 15 | 05-18-2012 12:13 PM |
