10-17-2020, 04:08 AM | #1 |
Pebble Pounder Join Date: Aug 2014 Location: Merrimack
| Transmission loud
So I recently took me transmission apart to check for water, since I submerged my truck. There was only slight moisture inside. I took a Qtip dabbed up the water and added new Vanquish Rc Rock Lube grease. Now my transmission makes a loud humming noise. Any ideas? Spins freely by hand. Only a slight drag from the grease. |
10-17-2020, 04:33 AM | #2 | |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Transmission loud Quote:
Following. My trans makes a sound too, but it’s a little rough to spin by hand. Sent from my iPad using Tapatalk | |
10-17-2020, 05:09 AM | #3 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: Transmission loud
Check if you overtightened the screws of the trans. Maybe that's the issue.
10-17-2020, 05:17 AM | #4 |
| Re: Transmission loud |
10-17-2020, 03:44 PM | #5 |
Just tore it all apart. Degreased everything. Cleaned and re oiled the bearings. Reassembled only using a light coat of grease just on the gears. It’s quieter, not as quiet as before. I’m going to run it and see if it quiets down once the grease has dispersed. |
10-19-2020, 03:46 AM | #6 |
Pebble Pounder Join Date: May 2020 Location: DMV
i had to replace the trans case in my capra and it was luder than before. turns out there were two very small pieces of grit that got in the teeth of one of the gears. i needed a hobby knife to get them out. Its a shame to have to take it apart again, but it may be worth it.
Transmission loud - Similar Threads | ||||
So loud! | mudbeast2 | Axial Yeti | 13 | 11-02-2015 10:21 AM |
It's loud! | Mortimer Snerd | Losi Micro-Rock Crawler | 4 | 04-01-2010 10:05 PM |
loud R2 tranny | scale4x4 | Newbie General | 9 | 09-07-2009 08:08 PM |
Why so loud? | JeepinDoug | Losi Mini-Rock Crawler | 12 | 02-15-2009 07:50 PM |
How loud? | rizzle23 | Newbie General | 5 | 01-17-2006 07:48 PM |
