09-12-2019, 01:15 PM | #21 |
Quarry Creeper Join Date: Sep 2006 Location: Orange, CA
| Re: Brandon's VS4-10 Rear Portal Yota Build
Looks good, you bringing this down so I can try it? and scratch it?
09-12-2019, 02:04 PM | #22 |
Looks great Brandon! Nice choice for the interior. Sent from my iPad using Tapatalk |
09-12-2019, 02:19 PM | #23 |
An Origin Finder...cool. I always like these Yota bodies with the tires hanging out the side.
09-12-2019, 04:05 PM | #24 | ||
| Re: Brandon's VS4-10 Rear Portal Yota Build Quote:
Agreed, found that in the attic yesterday and it fits perfectly. I had an old Bruiser interior I was going to modify but the lexan spawn interior is just way too easy. I might go back to a narrower wheel. I originally ran it that way but wanted to test the wider wheels to see how the tire contact affected performance. Does look good this way. | ||
10-18-2019, 09:59 AM | #25 |
Mounted the interior. Just bolts to the top of the VFD trans cover. I can still access my battery mount and its lightweight. More body work too. Front is pinched and rear bed length was increased to match the WB then bobbed. Rear bed bolts to the chassis, cab is easily removable though. I need to finish the front hood area and work on bumpers / sliders to hide the imperfections. Body needs more sanding and filler. |
10-18-2019, 02:07 PM | #26 |
Love the Yota hardbody and 4.19 BFGs, glad the pinch was not excessive lol. |
10-19-2019, 12:35 AM | #27 |
Rock Crawler Join Date: Dec 2012 Location: Utah
Great looking yoder with a mean stance!
11-20-2019, 03:47 PM | #28 |
Isn't this about due for an update?
11-20-2019, 04:28 PM | #29 |
| Re: Brandon's VS4-10 Rear Portal Yota Build Im still messing with it. Wasn't happy with the bed. Going for a super simple cage design and eliminate the rear shock towers. Then I can lean the rear shocks forward on the cage mounts. Thanks Josh for the tubing material and safety silv. Havent messed with this stuff in years. Here is the start. |
11-22-2019, 10:25 AM | #30 |
Mocked up the scale motor from Scale Design by Mr. Commad. Wont fit under the hood but love the way it looks on the chassis.
11-22-2019, 03:06 PM | #31 |
Quarry Creeper Join Date: Nov 2018 Location: Mexico, Guadalajara
wooow! this build is amazing, truly unique someday a vanquish kit will be in my collection |
11-24-2019, 10:28 AM | #32 |
Some progress on the rear cage. Just needs shock mounts then I will clean it up and paint.
11-27-2019, 09:54 AM | #33 |
Finished up the cage over the weekend. Still needs to get cleaned up and painted but the fitment is good and ride height with the shock mount tabs is perfect. Fuel cell cap covers the low profile Tekin dig servo, radiator mount was added to the cage. Might tweak the position some but happy with the overall look. Ill add some styrene to the fuel cell cap to close it in a bit better on the sides. |
12-06-2019, 03:49 PM | #34 |
Got the cage cleaned up and painted. Installed the lower back half of the cab into the cage so I can close it up and still remove the main cab easily. Some interior work, front bumper, and body detail should finish it off for now. Looking forward to running this one again. |
12-06-2019, 04:28 PM | #35 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
I really like the profile of that cage, some nice work right there. How’s your gear mesh on the rear with the 3rd member and gears flipped upside down? |
12-08-2019, 12:55 PM | #36 |
| Re: Brandon's VS4-10 Rear Portal Yota Build No issues with the 3rd member yet. Im not too worried about it with the VP bearing retainers. Nothing is able to move with the design.
12-09-2019, 01:45 PM | #37 |
Newbie Join Date: Oct 2018 Location: Salt Lake City
When will that cage be available for sale?! |
12-09-2019, 03:54 PM | #38 |
| Re: Brandon's VS4-10 Rear Portal Yota Build One of my all time favorite projects while working at axial was the honcho. I actually painted both bodies that were used on the box art for the honcho kit, otherwise the project was nearly complete in 2009 when I joined axial R&D. I would love to make a modern version of the honcho on a VS4-10 chassis. Really anything Toyota based I would be happy with. Ill have to take this cage design into CAD and see what happens. The axle is offset to the wrong side but thats easily ignored. |
12-09-2019, 07:03 PM | #39 | |
Quarry Creeper Join Date: Nov 2018 Location: So Cal
I built both of my VS4-10 chassis with the intent to run ProLine Toyota SR5 HiLux front cabs and some sort of Honcho-esque rear cage. I've tried fitting the actual Honcho rear cage, and the fuel cell interferes with the lower cage rails. The other ProLine back half cage also doesn't fit well - I've tried that too. I even tried a GMade GOM cage. That one might fit, with some modifications, but I'd end up compromising the structural integrity. I would love to see a rear cage designed specifically for the VS4-10 to make a modern interpretation of a Honcho. | |
12-10-2019, 06:25 AM | #40 |
That is a good looking cage! It would be cool to see a modern version of the Honcho cage for the VS4-10. Hopefully that is something you can build in the future. |
Brandon's VS4-10 Rear Portal Yota Build - Similar Threads | ||||
Brandon's Blazer Build | Big_Trux | RC4WD Trail Finder 2 | 35 | 11-25-2019 06:09 AM |
Brandon's 1.9 Wraith Build | Brandon | Axial Wraith | 101 | 12-18-2014 01:24 PM |
Brandon's Formula Offroad Build | Brandon | Formula Offroad | 95 | 02-14-2013 04:48 PM |
Brandon's SCX10 Trail Ranger Build | Brandon | Axial SCX-10 | 68 | 07-29-2011 06:49 PM |
Brandon's SCX10 RTR Trail Ready Build | Brandon | Axial SCX-10 | 112 | 12-15-2009 10:29 PM |
