01-03-2024, 05:53 PM | #61 | |
| Re: B-MOW's Vanquish VRD Carbon Quote:
Also, thank you about the gearing tip! Noted for when I buy my VRD Carbon. | |
01-04-2024, 03:59 AM | #62 |
| Re: B-MOW's Vanquish VRD Carbon RCC member Distinctive PD had the same Hot Rod body on one of his builds. When I first saw his I knew I had to build one for myself. Fricker08 now owns PD's beautiful build. I was/is a fantastic build!
01-04-2024, 06:45 PM | #63 | |
Quarry Creeper Join Date: Oct 2010 Location: So. Cal
I'm still angry and happy at Fricker for buying that. I wanted it. Didn't need it. | |
01-04-2024, 07:23 PM | #64 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
| Re: B-MOW's Vanquish VRD Carbon |
01-07-2024, 10:31 AM | #65 | |
01-18-2024, 08:13 PM | #66 |
Not too much to report, but did get the Fusion SE 1800kv delivered a couple days ago. I got 'er in and mounted the receiver. Still need to get the wiring laid out and routed. Not in a real big hurry since the weather here in frigid Ohio has been in the single digits with wind chills in the negative. Hurry up and get here Spring! Edit: Oh damn, just realized I hit 4,000 posts! That's a lot of Bullsh**ing! Last edited by B-MOW71; 01-18-2024 at 08:15 PM. |
01-18-2024, 09:20 PM | #67 |
RCC Addict Join Date: Dec 2012 Location: Crookston
01-21-2024, 08:09 PM | #68 |
Spent some time today on the VRD and trying to decide where to mount the battery. The 2 obvious choices are on the sliders. So to determine which side the battery should go on, I threw the VRD on my SkyRC scales to see how the all around weight was as it sits in stock form with the NSDRC RS-500B servo, HW Fusion SE 1800kv and the RadioLink R6FG 6-channel receiver installed. As it sits it has pretty good weight bias. Right where most of us like our rigs to be. It looks like to level out the side to side bias, the battery will more than likely sit on the passenger side slider. I have 3 smaller batteries in my lineup that I have to choose from. A Tattu 3S 1300mAh 45C, Goldbat 3S 1500mAh 100C and a Ovonic Air 3S 2200mAh 35C. The Ovonic has been my battery of choice here lately that I run in most all of my rigs. A fairly inexpensive battery with great power and run times. And it's small size is nice and fits in tight spots nicely. After fitting each of the batteries on the pass. side slider, the weights are very similar. I think for now I will run the Ovonic 2200mAh. I want to eventually buy some smaller batteries like maybe an 850mAh or similar to possibly mount the battery up in next to the VFD or maybe up in front of the VFD in the future. |
01-21-2024, 10:10 PM | #69 |
Quarry Creeper Join Date: Mar 2020 Location: Las Vegas
Lookin' good!
01-22-2024, 06:52 AM | #70 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
You planning on competition or trail use for this truck? For competitions, that 1300 is the biggest pack I run. I only run that on our long courses like the 50 gate or team comp that was multiple laps around a long course with hill climbs, etc. I can get 45 minutes to an hour out of it. For typical 10 gate comps I like to run ~550-650mah. Thats has enough juice to run 2 courses if I forget to swap out packs, or ~25 minutes of run time on a 650. My point is those Hobbywing setups are pretty efficient so dont be scared of small batteries.
01-22-2024, 07:29 PM | #71 | |
| Re: B-MOW's Vanquish VRD Carbon Thanks! Quote:
I normally just hit the parks with RC friends and have friendly "comps" between us on rocks and obstacles we find along the way. Sometimes throw down some gates to see who's the best on that particular day. That's good info on the battery pack sizes for the different length comps. Thanks for that. I'm going to pick up some of the smaller mAh packs to try out in the VRD. | |
02-04-2024, 07:34 PM | #72 |
Took the VRD out for its first drive today. I went to Delaware State Park dam about 50 minutes away from me. Never been there before, but have always wanted to check it out. I met up with others from the area and did some trailing and crawling. The rocks on the dam were the perfect size and shape to give the VRD a good test. Big, jagged, uneven and some were steep. I gotta say, I've read the hype and seen the pics of peoples thoughts on how capable the VRD Carbon is. I can now say after driving it, all the awesomeness that I've heard is true. I've driven a lot of different style rigs over the years, but never nothing this great right out of the box. It was pretty much point and shoot and it would tackle and overcome every rock obstacle I could throw at it. It is so light and nimble and very predictable. Vanquish did their homework and have produced a real winner! The Fusion SE 1800kv is the perfect power plant for this rig. Super smooth low end with enough power to bump over rocks if needed. The new NSDRC RS 500 SB budget servo is perfect for this type of lightweight rig. Plenty of quickness and power to turn the tires. And for the price it is hard to beat. Enough talking, here's the pics of the fun today: I'm looking forward to the next warm days so that I can get this back out on the rocks to do more testing. As of today, I really can't think of any modifications or tuning that it needs. It is just that good right out of the box. The Hyrax tires are just a spare set that I had laying around and mounted them up for the time being. The Hyrax actually did a great job. I do want to try out a few different sets of tires that I have to get a feel of how the VRD will do with different rubber on it. All in all, a great day to be out tiny trucking! Couldn't ask for better weather here in Ohio on February 4th! I did get some good video of the run today, so I'm going to try to get it all together and get it put up on my YouTube page when I get a chance. It's been awhile since I've posted any vids on there, so I'll have to re-teach myself how to do it! |
02-05-2024, 06:46 AM | #73 |
Glad to hear it performed so well for you. I'm anxious to get mine out on the rocks! How much run time did you get with that battery? I'm in battery selection mode right now and I may go up to 4S and keep the capacity low. The battle would be trying to get gearing that would keep the Fusion Pro 2300kV under control with 4S. I wouldn't want to get less than an hour of runtime though. I'm sure you got way more than that with the 3S 2200mAh pack. |
02-05-2024, 07:37 AM | #74 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
Rig looks great, love the pics. Looks like a gorgeous February day. Sounds like I better keep that kit on my shopping list Sent from my SM-G990W using Tapatalk |
02-05-2024, 08:36 AM | #75 |
Quarry Creeper Join Date: Mar 2021 Location: SOCAL
looks like a great time and challenging terrain for the VRD... Got mine over the weekend from Amain but I have yet to crack it open ... I took out some of my rigs instead, Good to know that the electronics choices are similar to what i had in mind ... How fast would you say the SE 1800 would get ya!!! I think the PRO would be fast for this rig at least for my pace. I don't really beat on my rigs so super speed punches are not necessary.
02-05-2024, 07:00 PM | #76 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
Man, such a purdy day! It was nice here too, so i took a couple rigs with me to town. Done the shoppin, hit the park, n realize i left my bag sittin on the floor smh. So no batts or tx. Love how the paint turned out! Cant wait to see the runnin vid. Sent from my SM-A516V using Tapatalk |
02-05-2024, 08:07 PM | #77 | ||||
Can't beat a February day like that. Though it was a little cool in the shade, so I tried to keep my body in the warm sun. I would keep it on the list for sure. Better yet you may just want to hit that spend more money button! Quote:
Great to hear your VRD arrived. I got a feeling your gonna love it! I would say that the SE 1800 isn't going to set any land speed records. IMO it has just about the perfect speed for rock crawling. It may be as fast as walking pace, maybe. I don't plan on trailing it, so the speed really isn't needed. It does have enough bumpability to get up and over rock edges when needed. Quote:
Thanks! I'll post a link when I get the vid done. | ||||
02-06-2024, 05:55 AM | #78 |
The vrd looks great man, I should probably get mine built soon.
02-06-2024, 06:44 AM | #79 |
02-07-2024, 03:34 AM | #80 |
Tags |
b-mow71, vanquish, vrd, vrd carbon |
B-MOW's Vanquish VRD Carbon - Similar Threads | ||||
B-MOW's Enduro Journey! | B-MOW71 | Element RC 1/10 Enduro Trail Truck Sendero | 243 | 04-08-2024 08:22 AM |
New Vanquish VRD Carbon | Sniper4370 | Vanquish Products VS4-10 Origin | 122 | 02-26-2024 08:48 AM |
B-MOW's IFS Trailwalker | B-MOW71 | Element RC 1/10 Enduro Trail Truck Sendero | 113 | 05-31-2023 09:16 AM |
