11-23-2016, 05:44 AM | #261 |
Quarry Creeper Join Date: Jan 2016 Location: US
| Re: Codyboy's "bulldog bronco" ascender
Ohh and what are you using for a transfer case? Sent from my SM-G900V using Tapatalk |
11-23-2016, 10:06 AM | #262 | |
| Re: Codyboy's "bulldog bronco" ascender Quote:
Thanks, can't wait to mount them up and go out for test crawl! They look great, Pete will prolly want a set too! Nate | |
11-23-2016, 10:14 AM | #263 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Codyboy's "bulldog bronco" ascender |
11-23-2016, 03:50 PM | #264 |
The motor forward mount is a GCM mount made for the ascender, and the transfer case is rc4wd. Ernie |
11-23-2016, 06:13 PM | #265 | ||
Sent from my SM-G900V using Tapatalk | ||
11-23-2016, 07:56 PM | #266 | |
Ernie | |
11-30-2016, 07:22 PM | #267 |
I told Nate that I would share the jig I made for holding the slider parts while I tack them together, so thought I would share with everyone. I wanted something that has some adjustability for different size sliders. A little adjustment to slider width that Nate and I talked about. They still need to be cleaned up. Ok so now a question for all of you, Nate and I discussed the need for RULR (rear link riser) that is incorporated with the Gullwing Sliders. What do you think, would it be handy? Let me know what you think! I don't want to offer them if you don't think they are needed. Ernie |
11-30-2016, 08:23 PM | #268 |
Rock Crawler Join Date: Jan 2016 Location: US
Yes they r needed on any of the ascenders i personally like rulr over the swaybar i also mounted mine toward the front i like the look of it more and tire barely hits LIFE IS GOOD |
11-30-2016, 08:25 PM | #269 |
Rock Crawler Join Date: Dec 2014 Location: In the sticks
Sounds like a great idea to me. In my opinion link risers are a must, so why not incorporate them into the sliders. And while I'm at it I'll offer my services and test the proto types for you. |
11-30-2016, 08:59 PM | #270 | |
Ernie | |
11-30-2016, 09:05 PM | #271 |
If you could only see the grin on my face right now |
11-30-2016, 09:51 PM | #272 |
P.S. Good luck with all those holes. One of my Ascender's has a pair of risers I threw together and I only drilled a single hole lol. Figured if things ever change I'd drill another hole.
12-01-2016, 09:20 AM | #273 |
12-01-2016, 10:38 AM | #274 | |||
12-01-2016, 02:05 PM | #275 |
I had a thought the other day when I was thinking about my RULRs. If any of you are familiar with an eccentric mtn bike bottom bracket I was thinking about something similar. It would allow for a piece to rotate that would have the mount at atached off center which would alow for quite a lot of adjustment. Kinda hard to explain...but maybe you get the idea. Probably easier to just drill a bunch of holes...but easy isn't always the best! Sent from my SM-G900V using Tapatalk |
12-01-2016, 02:07 PM | #276 |
EBB type of setup is a possible solution, but little complex, prolly just drill three or four holes that are "best" in general. |
12-01-2016, 04:28 PM | #277 | |
Ernie | |
12-01-2016, 04:51 PM | #278 |
I just need to figure out a way to make it...I have limited machining tools ie. Hack saw, drill and dremel tool... Sent from my SM-G900V using Tapatalk |
12-01-2016, 09:56 PM | #279 |
12-02-2016, 04:31 AM | #280 |
Codyboy's "bulldog bronco" ascender - Similar Threads | ||||
Bulldog/Mattzilla "Mountain Buggy" | Bulldog | 2.2 Scale Rigs | 88 | 03-30-2016 07:59 AM |
"Rhino" 1/9 Nissan Patrol 4x4 Y60 1997 build with Vaterra Ascender K5 | clarketian | 1.9 Scale Rigs | 25 | 03-15-2016 05:36 AM |
"My Bulldog Berg build" | bigron | EnRoute Berg | 61 | 02-05-2014 07:59 PM |
<iframe width="420" height="315" src="//www.youtube.com/embed/gYr-dbPEOnE" frameborde | boolean21 | Scale Videos! | 0 | 10-01-2013 09:39 AM |
