07-30-2016, 03:06 PM | #201 |
Rock Crawler Join Date: Jan 2016 Location: US
| Re: Codyboy's "bulldog bronco" ascender
Work me a price with knucles LIFE IS GOOD |
07-30-2016, 03:51 PM | #202 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Codyboy's "bulldog bronco" ascender |
08-01-2016, 12:26 AM | #203 | |
| Re: Codyboy's "bulldog bronco" ascender Quote:
08-01-2016, 10:28 AM | #204 |
I agree LIFE IS GOOD |
08-01-2016, 11:42 AM | #205 | |
Ok Pete, some eye candy for you. With the Dlux Design brass knuckles you have 11.5 oz of none rotating weight. These are scale legal, so should help you out with the cheaters hah!!! I know these aren't for everyone but they will give you a huge edge over most scale crawlers. Now it will be up to you to hit those lines!!! Another cool product from CODYBOY DESIGN! Ernie, Awesome steering even with the limiting stops. More tomorrow. Ernie, Last edited by CODYBOY; 08-03-2016 at 01:42 PM. | |
08-01-2016, 11:44 AM | #206 |
Bad assery right there LIFE IS GOOD |
08-02-2016, 03:11 PM | #207 |
Quarry Creeper Join Date: Apr 2008 Location: upland
love the re-purposing! everything looks great! Don |
08-03-2016, 03:53 AM | #208 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
Wow, hats off to Codyboy Design! Well done
08-04-2016, 02:08 PM | #209 |
| Re: Codyboy's "bulldog bronco" ascender Thanks Don, re-purposing is one of my favorite things to do in R&D! Thanks Joe, always a great compliment coming from you. I was talking with Poprivet about how I modify SSD wraith knuckles to take brass brake weights (a little over 4 oz of nonrotating weight) and thought I would share it with everyone. "All part of passing it forward". So this is what it will look like on the knuckle. With out the hub. Modified knuckle. Holder I made to turn the hub in a lathe or drill press. The holder is turned to the same size as the inner bearing. It is a tight fit. I also drilled and tapped it for a 10/32" screw, and use it to clamp the small bearing against the knuckle. If your using a drill press, you can use a coarse file that has teeth on all four sides. Position the file and lower the knuckle onto it to form the ridge for the weight. There you have it. Have fun If you want to do this but don't have the tools let me know. I can do a set for you. Ernie, "Codyboy Design" |
08-04-2016, 07:56 PM | #210 |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
Amazing. I was thinking of the same thing for my ssd knuckles. How do you attach the brass weight to the knuckle though? Ben |
08-04-2016, 08:44 PM | #211 | |
Ernie, | |
08-05-2016, 08:30 AM | #212 |
Newbie Join Date: Jan 2015 Location: crawlorado springs
Can't wait to see more pics! Ernie, PM incoming...
08-05-2016, 08:59 AM | #213 |
| Re: Codyboy's "bulldog bronco" ascender Hey Ernie, Is the Axial universal in the pic one that is ready to go into an Ascender? It looks relatively unmodified, do the universals slide right into the Vaterra spool or is some filing required? I have a few spare wraith knuckles and 2 trucks that can immediately benefit from this mod. |
08-05-2016, 09:21 AM | #214 | |
Ernie, | |
08-05-2016, 12:03 PM | #215 | |
I will start with finished product, Here you can see the 4/40 button head screw. I think I remember that you have lathe, so on the screws I turned down the screw head a little for clearance of the 12mm hex nut. I notched the weight and you can see one of the four holes in the knuckle that I drilled and tapped to 4/40. Here you can see the hole in the knuckle. I thought I would show you a easy way to do the brake weight its self. This is RCC venders wheel weight that I I converted to a knuckle weight with this 9/16" brass washer. I just centered it on the back of the wheel weight and soldered it in place. I then drilled out venders weight to match the washer size. Hope this will help some of you guys out. Now you know all my secrets! If you try this, please share with us how you did it! Last edited by CODYBOY; 08-09-2016 at 09:31 AM. | |
08-11-2016, 01:30 PM | #216 |
A little update, I have no update on the Bulldog Bronco, I haven't had time! These are a few things I've been working on. Beef tube axles, and just about to finish a Codyboy Steering mod with brake weight brass for one of our members. These are designed to fit external bead lock wheels. Look pretty good from the front. More later, thanks for looking. Ernie, |
08-12-2016, 01:40 PM | #217 |
08-12-2016, 02:18 PM | #218 | |
Newbie Join Date: May 2015 Location: San Diego
| Re: Codyboy's "bulldog bronco" ascender Quote: | |
08-12-2016, 02:46 PM | #219 |
08-12-2016, 06:30 PM | #220 |
U only thought they where going on ur build LIFE IS GOOD |
Codyboy's "bulldog bronco" ascender - Similar Threads | ||||
Bulldog/Mattzilla "Mountain Buggy" | Bulldog | 2.2 Scale Rigs | 88 | 03-30-2016 07:59 AM |
"Rhino" 1/9 Nissan Patrol 4x4 Y60 1997 build with Vaterra Ascender K5 | clarketian | 1.9 Scale Rigs | 25 | 03-15-2016 05:36 AM |
"My Bulldog Berg build" | bigron | EnRoute Berg | 61 | 02-05-2014 07:59 PM |
<iframe width="420" height="315" src="//www.youtube.com/embed/gYr-dbPEOnE" frameborde | boolean21 | Scale Videos! | 0 | 10-01-2013 09:39 AM |
