Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: Out boarded my rear shocks and now i have issues
Old 06-11-2017, 09:02 PM   #1
CTB
Unhappy Out boarded my rear shocks and now i have issues
I out boarded the rear shocks and now I seem to have a lot less rear articulation. it seems to take a lot more force to get the suspension to compress. I have the Vaterra Aluminum shocks mounted. Overall the shocks seem mushy and less responsive. any thoughts on the cause?
Thanks
CTB is offline   Reply With Quote
Old 06-11-2017, 10:46 PM   #2
CODYBOY's Avatar
Default Re: Out boarded my rear shocks and now i have issues
Thanks
Check the top and bottom mounts to make sure you shocks aren't binding.
Ernie
CODYBOY is offline   Reply With Quote
Old 06-12-2017, 04:37 AM   #3
The shock has more leverage on the axle now so you effectively increased the spring rate for when the axle twists. Spring rate for compressing the axle on both sides equally has not changed but that is a rare occurrence in normal crawling. This is also the reason you are getting less torque twist. The torque twist solution that has the least affect on axle articulation is moving the upper link chassis mounting locations up.
If your shocks seem stiffer when compressing the axle equal on both sides, something else is going on. Check your ring that floats between the two springs. It likes to drag on the threads of the shock body at least on the stock shocks.
JDM74 is offline   Reply With Quote
Old 06-12-2017, 06:06 AM   #4
CTB
Smile Re: Out boarded my rear shocks and now i have issues
Thanks, I guess I will look in to moving the links up and double check how the shocks are moving. Thanks help!
Old 06-13-2017, 12:02 AM   #5
There def is less travel after outboarding
rag6 is offline   Reply With Quote
Out boarded my rear shocks and now i have issues - Similar Threads
Rear SSD Diamond Offset issues Beorn Axial Wraith 22 10-25-2015 11:19 PM
Dingo Rear Axle issues Huber1918 Axial SCX-10 14 04-09-2013 11:37 PM
Rear differential issues? Kanine38 Axial AX-10 Scorpion 18 05-18-2010 05:48 PM
issues with rear axle build slegh Tamiya TLT Crawlers 6 06-02-2008 08:57 AM
Mamba Max Issues... Rear not working? run2jeepn Electronics 16 07-27-2007 02:12 PM
