02-11-2013, 05:40 AM | #1 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| Good shift servo replacement!
Guys post up you recommendations for a new shift servo! |
02-11-2013, 06:21 AM | #2 |
Rock Crawler Join Date: Nov 2008 Location: Beloit,ohio
| Re: Good shift servo replacement!
Hitec 225mg |
02-11-2013, 06:28 AM | #3 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
^^^ x2
02-11-2013, 07:28 AM | #4 |
I have hated the 225 ever since the VF dig days! Those things just burn up so easy! Hopefully this thing shifts smooth enough to not have to deal with that. |
02-11-2013, 07:35 AM | #5 |
Newbie Join Date: Jan 2013 Location: Central NJ
Is there a specific servo horn we should be on the lookout for?
02-11-2013, 09:33 AM | #6 |
I have a 7954sh, I should use that for the stearing servo, then take the stock stearing servo and use it for the shifting! I wonder if that would work?
02-11-2013, 09:39 AM | #7 |
I wanna be Dave Join Date: Dec 2008 Location: ?
| Re: Good shift servo replacement! |
02-11-2013, 01:13 PM | #8 |
Rock Crawler Join Date: Sep 2011 Location: FNQ Australia
Yep, I was going to change mine to a standard size when I tore it down but a whole new mount would need to be made, I'm on the hunt for good mini instead.
02-11-2013, 01:50 PM | #9 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
I installed the stock steering servo as the shift servo, just had to make a mount to accommodate the wider standard size servo. I will take pics of the mount and installation to post up. I didn't want to suggest this mod until I've got some time using it and so far with about 3 hours of hard driving it has been working good with no issues at all.
02-11-2013, 11:53 PM | #10 |
Rock Crawler Join Date: May 2005 Location: Fort Wayne
Why did you replace the shift servo with the steering servo?
02-12-2013, 12:21 AM | #11 |
| Re: Good shift servo replacement! Because after I went for a boat ride all my electronics went belly up except for the steering servo and because dig/shift servo's are typically just strong enough to do the job they tend to burn up quick if the linkage gets bound up at all. I just wanted a more robust/reliable shift servo to keep me running battery after battery with no issues.
02-12-2013, 12:19 PM | #12 | |
| Re: Good shift servo replacement! Quote:
Post a pic of your setup! I just ordered one and would like to do that! | |
02-12-2013, 12:21 PM | #13 | ||
02-12-2013, 12:37 PM | #14 |
| Re: Good shift servo replacement! Have you tested your setup yet? How does the linkage look alignment wise compared to stock? Curious if you get any binding like I did when my standard size servo was mounted further out then the stock servo causing the linkage to not be straight with the shift rod which in turn caused it to bind.
02-12-2013, 01:43 PM | #15 |
02-12-2013, 01:48 PM | #16 | |
02-12-2013, 03:21 PM | #17 |
02-12-2013, 03:30 PM | #18 |
02-16-2013, 06:49 AM | #19 |
RCC Addict Join Date: Jan 2005 Location: Germany north
| Re: Good shift servo replacement! thats mine |
02-16-2013, 05:43 PM | #20 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
| JR MN48 and some XR linkage. Works poifect. |
Good shift servo replacement! - Similar Threads | ||||
Help and Idiot Set Shift Servo End Points Please! | alexchen86 | RC4WD Trail Finder 2 | 6 | 07-28-2012 10:14 PM |
Help Setup Gear Shift Servo Please!! | alexchen86 | RC4WD Trail Finder 2 | 4 | 07-20-2012 11:30 PM |
replacement servo gears? | theloudone | Electronics | 10 | 03-17-2012 07:24 PM |
Shift servo? | 09 Screw | Electronics | 5 | 03-01-2011 07:12 PM |
shift servo | 4-linkedWK | Electronics | 3 | 04-12-2008 09:06 PM |
