02-18-2013, 10:00 AM | #21 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| Re: RolandRockshop's 2win banger KOH |
02-18-2013, 11:31 AM | #22 |
gonna limit the rear shocks compression travel a lil bit... just a lil to much for my taste ...@5-10mm of fuel tube should do the trick. scale item's to order.. lightbars for roof and front exo radiator fuel cell maybe some scale stuff in cab..cb radio,gps,fire ext..etc i hope someone come's out with a better steering setup... mine's got slop in it after our test runs at Superlift.. |
02-18-2013, 11:39 AM | #23 |
N.E.R.C.C Uncle Blinky Join Date: Dec 2008 Location: RUKDNME...
i put some losi 4's in the rear work grate. Drail and the oe shocks have the same gland as the losi's |
02-18-2013, 01:38 PM | #24 |
just stripped my tranny down... NO FAWKN GREASE!! what hell man! id suggest you guys take it apart and give it a look and check to see if you have grease in the tranny. |
02-18-2013, 01:41 PM | #25 |
RCC Addict Join Date: Nov 2007 Location: CALI "209"
| Re: RolandRockshop's 2win banger KOH Couple other threads posted about the same thing. I wonder if it is an oversight or they designed it to run dry.
02-18-2013, 02:27 PM | #26 |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
The gearbox runs dry just like the Comp Crawler did. The shift cogs wont stick as much or slip under hard shifting.
02-18-2013, 02:33 PM | #27 |
Kc sticker's and a delrin fairlead installed... now to install winch.. before.. after.. Last edited by ROLANDROCKSHOP; 02-19-2013 at 10:02 AM. |
02-18-2013, 08:50 PM | #28 |
Pebble Pounder Join Date: Jan 2013 Location: Between a rock & a hard place in North Texas
Your TH is coming along nicely! Couple questions: Exactly which 2800 mah battery are you running? How is the trans working with grease in it? |
02-19-2013, 07:23 AM | #29 |
Rock Crawler Join Date: Sep 2010 Location: Little Rock, AR
Those KC stickers really bring the stock panels around
02-19-2013, 07:27 AM | #30 |
i didnt gob the grease in the tranny just enough to lube the gears.. lucas oil's lithium grease.. the battery i got off EbAy awhile back for my girls Lr3 scaler.. guess im gonna have to get her a new battery.. 2800mah 30c 2s |
02-19-2013, 09:08 AM | #31 |
Pebble Pounder Join Date: May 2011 Location: Uk
I greased mine up after the first run I did, I greased it enough to give the gears a smooth look and then ran it up on my bench for five mines and checked the shifting out it was smooth and very quiet, I've since done six packs through it over various terrain shifting a lot and its been fine so far, I shall run a few more packs though it and possible strip it down, but I can't see how a reasonable amount of grease will do any harm always better to use a little lube |
02-19-2013, 09:51 AM | #32 |
RCC Addict Join Date: Jan 2010 Location: Vermont
I greased mine as well, and has been holding up fine. It actually shifts quieter, there is still a click, but not as loud.
02-19-2013, 10:06 AM | #33 |
just got off phone with neil at Freqeskinz.. getn my wrap finished up hopefully by the end of the week. http://freqeskinz.com/index.php?page...mart&Itemid=71 |
02-20-2013, 06:46 AM | #34 |
i had a dinky Rc fuel cell laying around.. so i cut and trimmed it a lil here and there. it hides the battery a lil better i think.. had some Rc4wd 110mm coilover's..so i threw them under to see if i like the looks. Im for shure gonna order some Rc4wd 110mm king shocks for it. also found a set of links that would fit,so i swapped them out. |
02-20-2013, 07:33 AM | #35 |
Fuel cell looks good out back. I have one from my IFS SCX just sitting here. I'll have to figure how to mount it. The King shocks look good too. Just needs 2 more of them. |
02-20-2013, 09:59 AM | #36 |
whipped up a front shock brace... |
02-20-2013, 10:38 AM | #37 |
and throwing some paint on the wheels.. |
02-20-2013, 11:54 AM | #38 |
cut the treads on race claws... softened the sidewall a lil bit just cutting the lugs out. |
02-20-2013, 11:57 AM | #39 |
Told ya those tires were just begging to be cut on. |
02-20-2013, 12:52 PM | #40 |
Rock Crawler Join Date: Jul 2009 Location: Little Rock, Arkansas
This is an awesome build. Having fun watching it progress. Great idea with the light stickers as well.
RolandRockshop's 2win banger KOH - Similar Threads | ||||
RolandRockshop's Monsta Truck build | ROLANDROCKSHOP | Mega/Monster Trucks | 73 | 08-29-2015 08:02 AM |
flathead 4 banger | jetboat | 1:1 Full Size Vehicles | 17 | 11-12-2012 05:14 AM |
Rc KOH | crawladan | Chit Chat | 7 | 04-13-2009 01:53 PM |
