03-06-2013, 09:37 AM | #81 |
RCC Addict Join Date: Aug 2011 Location: Pipersville
| Re: RolandRockshop's 2win banger KOH
I hate you. Putting Curries on and that skin is going to be awesome. Looks good, now go get that axle all scraped up... |
03-06-2013, 09:55 AM | #82 | |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| Re: RolandRockshop's 2win banger KOH Quote:
actually im torn on the rock jocks... the stock axle has waaay more clearence than the rock jocks.. i took them outside in my rockgarden yesterday for a test run... the rear end hung up on everything!! difference in diff's..stock and rock jock.. as you can see it hangs down a bit further than the stock axle. | |
03-06-2013, 10:04 AM | #83 |
Quarry Creeper Join Date: Mar 2012 Location: Brooklyn, New York
it's the price you pay for being fashionable... lol. sometimes it's better to look good and those curries look good. |
03-06-2013, 10:41 AM | #84 |
Quarry Creeper Join Date: Nov 2006 Location: land of make believe
i have to disagree. i think the stock axle looks better. that currie pumpkin is huge, it looks bigger than the wheels. how much heavier is the currie axle? Im diggin the cut stock tires though. |
03-06-2013, 10:46 AM | #85 | |
post#80 just a fyi for those intrested.. stock axle weighs 5.33oz rock jock weighs 8.78oz | |
03-06-2013, 02:17 PM | #86 |
Thanks. I should of looked back a page. Other than the lack of clearance, how was the performance with the extra weight back there?
03-07-2013, 06:36 AM | #87 | |
it feels a lil more balanced..doesnt want to flip on a sharp turn at high speed as much with more weight in the rear. had dinner with my grandparents lastnight..while i was waiting on the mexican chicken to get done cooking.. i took it outside and ran it around their house.. rocky hillside/waterfall/a few rock piles i made up.. Also i removed the delrin skid. removing the skid seemed to help it not getn hung up as much,just that lil edge hanging down seemed to grab everything. i think im gonna grind down the lower section like a 1:1 D60.. more Vanquish goodies coming in today... ill be on my ustream channel @noon dign in the Goodie box!! | |
03-07-2013, 09:38 AM | #88 |
did a spring swap on front shocks.. scx green spring and scx cups and traxxas tension spacers.. does a lot better than stock in the rocks now. i can compress shocks and they rebound to where the arms sit level. |
03-08-2013, 04:47 PM | #89 |
| Re: RolandRockshop's 2win banger KOH housing could use a bit more grinding on it... And the other goodies i was waiting on.. Vp did a helluva job designing these wheels..4 screws and i can change tires....are you kidding me... However..there was 1 problem with the rings on assembly.. seems it was a machining flaw and the screws wont fit down into the ring. Chatted with Tom and Steve about it and new rings and a few missing screws will be on there way monday. And they called me.. Thats customer service. Last edited by ROLANDROCKSHOP; 03-08-2013 at 04:53 PM. |
03-08-2013, 09:57 PM | #90 |
Pebble Pounder Join Date: Jul 2008 Location: 808
Looking really good those wheels are sexy 0.0"
03-08-2013, 10:24 PM | #91 | |
Quarry Creeper Join Date: Jun 2011 Location: butler pa
03-08-2013, 10:53 PM | #92 |
Newbie Join Date: Mar 2013 Location: SLC
| Re: RolandRockshop's 2win banger KOH ive been told you have to press the inner bearing into the pinion bearing spot but i had no luck getting the bearing in far enough to get a decent mesh. I assembled it and put the bearing caps on snugged and then used valve grinding compound on the ring gear/pinion and turned the pinion till the mesh was super smooth, tightened the caps down & repeat. finished with some light rubbing compound and cleaned, greased and tightened it all down.... good to go.
03-12-2013, 04:23 PM | #93 |
got my skinz in from Freqeskinz.... .. . . . . . . |
03-12-2013, 04:24 PM | #94 |
| Re: RolandRockshop's 2win banger KOH i think they turned out pretty nice! now for some illumination.. |
03-12-2013, 04:27 PM | #95 |
Oh you fancy, huh.
03-12-2013, 04:46 PM | #96 |
Looks sweet.
03-13-2013, 08:35 AM | #97 |
i also installed chaotic carbon fiber shock brace... yep fancy shmancy... now to get some illumination on this bad boy.. |
03-13-2013, 01:09 PM | #98 |
ordered a swaybar kit for a b4/t4 AE buggy/truck...@$7 off ebay perfect fit! just had to trim the bars to the right length.. and bam! |
03-13-2013, 07:31 PM | #99 |
went and had dinner with the folks tonite.. had my uncle get his fancy camera out and do a photoshoot with the new skinz on...got some pretty good pics. ill post'em up when he gets done with them. more so... WOW... go put swaybars on...now!! what a difference it makes in the rocks..much more stable,no more floppy/twisty rear end. |
03-15-2013, 05:55 AM | #100 |
Here's pics from the other day... |
RolandRockshop's 2win banger KOH - Similar Threads | ||||
RolandRockshop's Monsta Truck build | ROLANDROCKSHOP | Mega/Monster Trucks | 73 | 08-29-2015 08:02 AM |
flathead 4 banger | jetboat | 1:1 Full Size Vehicles | 17 | 11-12-2012 05:14 AM |
Rc KOH | crawladan | Chit Chat | 7 | 04-13-2009 01:53 PM |
