02-20-2013, 03:23 PM | #21 |
RCC Addict Join Date: Oct 2011 Location: Brighton UK
| Re: Which aluminum hexes fit?
I fitted wraith ones today, had to drill out the wheel centre and the hex centre but now it has the locking grub screw, 6mm wider stance, feels strongggg
02-20-2013, 03:34 PM | #22 |
Quarry Creeper Join Date: Nov 2007 Location: WNC
My Blitz hexes should be here tomorrow night. Can't wait to install them because the factory plastic hexes on my Twammer like to stick to the wheels and that's a good way to lose pins. Does anyone know the specs on the pins? I wouldn't mind having extras... |
02-20-2013, 03:38 PM | #23 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
| Re: Which aluminum hexes fit? I don't know the specs but I know they are a smaller diameter then Axial hex pins. Since I broke two pins last weekend I'm planning on drilling out the pin hole in the axle so I can use the larger pins which I'm hoping are stronger.
02-20-2013, 04:09 PM | #24 |
Sr. Product Developer Join Date: May 2005 Location: Fontana
These do... Losi: 12mm Aluminum Hex (5.7mm wide) (4): CCR: Losi (LOSA3186) There is not a ton of these in stock right now but you may get lucky if you order now I'm working on "rebadging" these under the Vaterra line for the future. |
02-20-2013, 04:34 PM | #25 |
| Re: Which aluminum hexes fit? How did you break them? I've read your entire thread and know that you have a beastly setup. I had an aggressive full throttle rock bouncing session on one of my rock obstacles earlier and was surprised that the Twammer held together with zero carnage. Although I'm only temporarily running an AE2 and rc4wd 35t on 2s until Friday... Mmp/tekin 13.5 on the way... |
02-20-2013, 07:11 PM | #26 | |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| Re: Which aluminum hexes fit? Quote:
02-21-2013, 08:52 AM | #27 |
Quarry Creeper Join Date: Sep 2005 Location: Sandy, UT
| Re: Which aluminum hexes fit? I'm running STRC Slash 4x4 hexes. They went right on and I didn't notice any slop in the pin, but it was super later when I put them on so it is possible. I beat on them with Roc412 power over the weekend with no failures though, so I think they're working well.
02-24-2013, 09:23 AM | #28 |
Quarry Creeper Join Date: May 2012 Location: Gainesville
I;m trying to make sense of all this info. So the stock pins on the twin hammers are smaller in diameter than axial? And the axle itself if bigger than axial?
02-24-2013, 10:25 AM | #29 |
Quarry Creeper Join Date: Oct 2010 Location: Land of the Cactus
I just ordered these and hope they fit, they look badass. 1/10 Brake Disc Wheel Adapters 12mm Hex (Red - 2pc) |
04-01-2013, 02:42 PM | #30 | |
Newbie Join Date: Mar 2013 Location: Fort Collins
Those do look really badass, did you get a chance to try them?? Quote:
04-01-2013, 02:55 PM | #31 | |
Pebble Pounder Join Date: Feb 2013 Location: Asheville
04-01-2013, 03:11 PM | #32 | |
Quarry Creeper Join Date: Aug 2010 Location: Varese - Italy
04-01-2013, 04:50 PM | #33 |
Thank you for the input, I have decided I am going to pull the trigger on the Losi's.. While I am making and order and paying shipping costs... What else would you suggest ordering? What is likely to break, or worth upgrading? I have a HH13t & BRXL ESC (TorqueMaster) and I am running 3s. I heard the dog bones break a lot.. Any input is greatly appreciated, I would like to make as little orders as possible to eliminate shipping costs and it sucks waiting for a replacement part to arrive.. |
04-01-2013, 05:38 PM | #34 | |
in Italy, the situation is much more difficult. For the other parts you want to buy, my opinion is, it depends on the type of use that you make of the Twin Hammers, there is a large difference in resistance depending on the use, the motor installed, the type of tires. If you like speed and bashing, prepare to order many parts ... | |
04-02-2013, 10:50 AM | #35 | |
I am just wondering what the weak links are that I should be expecting to break? I will be making an order today from RPP Hobby | Radio Controlled Cars, Trucks, Boats, Helis, Planes, Plastic Models for the Losi hex's. Quote:
04-02-2013, 02:14 PM | #36 |
Rock Stacker Join Date: Feb 2013 Location: Dayton
I am using the losi ones I have had no problems so far.
07-16-2013, 03:34 AM | #37 | |
Rock Stacker Join Date: Jan 2005 Location: SE, Aust.
Have you got pics of them fitted? | |
04-03-2014, 06:49 PM | #38 |
Rock Stacker Join Date: Jan 2014 Location: So. Cal. IE
This thread has been helpful. I went with the Slash 4x4 STRC hexes. They're about 1mm wider and fit perfectly including the pins. Sent from my Nexus 5 using Tapatalk |
08-26-2014, 10:54 AM | #39 |
Rock Stacker Join Date: Jun 2014 Location: Seattle
My plan is to drill TH shafts for Axial pins and drill Axial hex's for TH shafts. Keeps all my rigs running same pins.
08-29-2014, 11:45 PM | #40 |
Rock Stacker Join Date: May 2014 Location: vancover island Canada
i bought some form vanquish 12mm hex, has anyone tryed tgem on there th? hoping they will work!
Which aluminum hexes fit? - Similar Threads | ||||
Aluminum Wheel Hexes... | slolx50 | General Scale Talk | 2 | 05-27-2010 10:42 AM |
TLT aluminum hexes??? | nodnarb81 | Tires and Wheels | 6 | 11-07-2008 09:31 AM |
Aluminum or pastic hexes? | hellbentrodder | Tires and Wheels | 20 | 05-22-2008 04:32 PM |
