03-08-2013, 06:37 PM | #21 | |
Rock Crawler Join Date: Feb 2010 Location: eugene
| Re: MIP ..... Twin Hammers Thread Quote:
I have not had a problem with my front end (yet) but like the guy I quoted, it would be awsome to get a setup like this. I would like to see the dog bones go away... along with the front center drive shaft. I wonder if the MIP drive shaft for the AX10 with dig would work for the front center shaft??? Last edited by lazynocturnal; 03-08-2013 at 07:49 PM. | |
03-08-2013, 07:02 PM | #22 |
Quarry Creeper Join Date: Feb 2012 Location: MARTINIQUE
yes, ful my TH with MIP please
03-08-2013, 08:37 PM | #23 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Wouldnt the front axles need to telescope due to the ifs? Thats that main reason for the dog bone end, so it can move in and out as suspension cycles.
03-08-2013, 10:41 PM | #24 |
Pebble Pounder Join Date: Feb 2013 Location: Asheville
My rear driveshaft is getting ready to bite the bust on my overpowered stock setup :p Steel idler gears would also be a nice addition! |
03-09-2013, 12:03 AM | #25 | |||||
Newbie Join Date: Mar 2012 Location: MIP
CVD- Was originally created by Eustace Moore of MIP. It has a cup on the shaft and then an axle with a ball fits into it. CVA- Came after the CVD and its basically a reverse version. Axle with cup and bone with ball to connect to it. Quote:
Also I don't believe that the AX10 Dig shaft would work it has a much shorter male bone as well as a regular output not the extended one that is featured in the picture. But I have not measured it up lol. Quote:
Again thank you guys for all the comments and keep them coming! I have not been able to handle one of the cars yet so what I can see from photos is the only knowledge I have. Last edited by MIP MATT; 03-09-2013 at 12:05 AM. | |||||
03-09-2013, 12:28 AM | #26 |
Pebble Pounder Join Date: Feb 2013 Location: Ramsey
Can i preorder a complete set yet? Put me down for a front and rear MIP set. I would like dog bones on the front as it is less rotating mass but am willing to sacrifice a few ounces to get reliability of a XCvd. My one issue with the stock fronts is that the suspension throw is limited by the dog bones being stopped by hitting the cup and not by the shocks, It would be nice to get articulation of the front to move another 1/4" to 1/2" which will allow me to use longer shocks and limit throw by my shock choice. I think front splined CVD or CVA would fix this issue and be a quality upgrade. Last edited by Kzzican; 03-09-2013 at 01:04 AM. |
03-09-2013, 01:17 AM | #27 |
Pebble Pounder Join Date: Feb 2013 Location: Near Aurora
If it moves it can use your help,thanks...Doc
03-09-2013, 05:11 AM | #28 |
Newbie Join Date: Feb 2013 Location: Louisville
Definitely in for MIP!
03-09-2013, 06:01 AM | #29 |
Quarry Creeper Join Date: Nov 2007 Location: WNC
I want to see some splined, telescoping front CV's.
03-09-2013, 06:13 AM | #30 |
Rock Crawler Join Date: Jan 2011 Location: Groningen, The Netherlands
Hmm..lessee... I haven't broken anything (yet). Mainly due to the fact that my TH is quite mildly powered with a 3400kv 10t stockspec LRP. And I am no fan of using 3s on that. Still. I see the rear center drive axle break when overpowered. The "neck" before the ball-bit is rather thin, compared to most cvd's. Coupled with a locked diff, the plastic middle-section will also, eventually warp, me thinks. The standard Front cvd's wíll most certainly be problematic with a locked front. Hardened front cvd's with a standard pin for the hexes would also be nice. Vaterra uses a slightly thinner pin for the hexes, and, while I haven't broken pins, they áre showing something like a "z"- bend to them. Full cvd's / sliders(i.e. no dog-bones) for the front would also very nice. Also, the plastic gears seem to be a tad weak. I noticed that quite a few people chipped teeth on the plastic gears, especially the idler. So, I'd say You should tear into the gear-box too, to see what can be improved there. Maybe a spring-loaded shift rod? Can easily be made by oneself, but could also be a convenient, cheap little Hop-up? Shifting is eating quite a few servo's here&there. Just throwin' out some ideas here. Last edited by Jay-Em; 03-09-2013 at 06:37 AM. |
03-09-2013, 06:16 AM | #31 |
Rock Stacker Join Date: Mar 2012 Location: usa baby
Splined teleys for me too!
03-09-2013, 08:44 AM | #32 | |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
03-09-2013, 10:37 AM | #33 |
Pebble Pounder Join Date: Sep 2011 Location: Oceanside Ca
While i havent broken anything yet, i just upgraded to a AE2 speed control, Brood stump humper, and will be running a 3s lipo. Im sure things will start shredding soon, especially since the front is locked with a spool. I am trying to make this thing bomb proof and would be happy to purchase any upgraded parts from MIP. you guys have always had great products!
03-10-2013, 05:20 PM | #34 | |
We will be ordering one next week to start looking into everything. Another question. From what I can see the front center shaft doesn't need to telescope correct? How is the wear on the front center shaft? I'm sure its of the same material as the front drives but definitely wont take as much damage. | |
03-10-2013, 07:42 PM | #35 |
Correct. Front center does NOT telescope. No travel going on there, but a bitch to get to and work on Wear is substantial just like on the cups in the front knuckles, very soft. |
03-10-2013, 10:51 PM | #36 |
Quarry Creeper Join Date: May 2012 Location: Gainesville
MIP FOR ME ALL AROUND PLEASEEEEE!!!!!! Rear driver shaft! Front shaft! Front inout and out put cups! Front whatevers you guys make!
03-11-2013, 04:42 AM | #37 |
Pebble Pounder Join Date: Dec 2012 Location: Belgium
whatever u gonna make, be prepared to send a package over to Belgium |
03-11-2013, 07:59 AM | #38 |
Rock Crawler Join Date: Dec 2011 Location: Virginia
Hi Matt, love your products. BMRC is developing longer trailing arms for the TH. I can already tell the longer WB is going to be a very popular upgrade. We have had several customers who already did the conversion say the longer WB is noticeably superior. What are the chances you can make a +1" longer rear shaft? |
03-11-2013, 10:12 AM | #39 | |
03-11-2013, 11:49 PM | #40 |
Rock Crawler Join Date: Oct 2011 Location: minot
Ok so splined front cvds. I'm down with those like a fat kid does cake.. My question is: What about us speed junkies who run putty in their front diffs? Any chance for some little outputs to replace the factory output cups and still run the factory diff with the splined shafts??? Gears have been mentioned, ill 2nd that.. As well as perhaps a larger pin for the axles... Oh and I run an mmp and a murfdogg 17.5 on 4s. I'm ready to break stuff.. |
MIP ..... Twin Hammers Thread - Similar Threads | ||||
Yet Another Twin Hammers | Tin Soldier | Vaterra Twin Hammers | 12 | 02-19-2014 07:47 AM |
twin hammers | zim35 | Scale Comp Rules | 264 | 05-19-2013 09:54 PM |
Twin Hammers | Rock Concepts | Videos! | 4 | 01-31-2013 02:50 PM |
