![]() | #1 |
Pebble Pounder Join Date: Dec 2014 Location: NJ
Are there any write ups on how to lock Twin Hammer's transmission in high gear? I am tired of burning servos for the low gear that I never use. I want to lock the trans in high gear for speed. I read that there are some spacers that need to be added but I am clueless without instructions.
![]() | #2 |
Newbie ![]() Join Date: Jan 2017 Location: Australia
There must be simpler ways, if your really only want high gear, but what I use is the Scorched Parts 3D printed gear change lever that replaces the need of a servo altogether.
![]() | #3 |
Quarry Creeper ![]() Join Date: Mar 2016 Location: Midlands
It’s a direct bolt in replacement for the servo. You would need to trim some of the interior away to use it. https://www.shapeways.com/product/G3...ionId=59997579 |
![]() | #4 |
Thanks guys. I will keep that solution in mind though for $24 shipped, it is a bit expensive vs free zip tie to keep the lever in high gear.
![]() | #5 |
An update: I took the transmission apart and following manual, I was able to add 6.5mm spacer to lock the transmission in high gear. I just needed to find a plastic tube that snugly fits the shaft and cut it to size.
![]() | #6 |
Quarry Creeper Join Date: Jul 2013 Location: PA
Try nitro fuel tube... you may have some on hand if you have nitro cars
Transmission gear / pinion gear question | dondraper25 | Axial Wraith | 5 | 09-03-2017 10:19 AM |
clicking sound in transmission when steering at full lock | atf300 | Axial Wraith | 7 | 10-21-2013 05:27 AM |
AX10 shift kit or shifting from Low gear to High gear? | legobrains | Axial AX-10 Scorpion | 19 | 10-27-2007 01:24 AM |
TXT Differential Gear Lock? | Steven | Tamiya Txt-1 and Juggernaut | 1 | 08-19-2007 02:51 PM |
How to lock the emaxx tranny and still have second gear | savyxer | Traxxas Crawlers | 10 | 08-25-2006 02:28 PM |
