06-21-2018, 02:16 PM | #1 |
Quarry Creeper Join Date: Dec 2012 Location: okc
| Front shocks
So I found out why the Rtr front shocks are so bad. I removed mine to install soft springs and found out that the Rtr springs are so stiff they are hard to compress by hand. Also the stock shock fluid is so thick the shock is hard to move. Went with the factory soft spring and the lightest fluid I had on hand 27.5. They feel WAY better now. Will test as soon as possible and report back
06-21-2018, 02:26 PM | #2 |
RCC Addict Join Date: Jan 2009 Location: Bend
| Re: Front shocks
The stock springs and dampening with these cars is about spot-on honestly, and are so stiff due to the compounding leverage ratios of the a-arms and cantilevers (seriously, check out a brand new car). The firmness you're feeling is most likely actually drag from the 6 rod ends at each corner that get sticky with as little as a tiny amount of dust, and the a-arm hinge pins. As a matter of fact, almost every complaint about these cars is as a result of all that drag. A little bit of dirt and grime just about seizes the front suspension solid. Clean your rod ends, ream your a-arms so they can cycle freely on the hinge pins, and don't use any kind of lube that attracts dust. Graphite or a PTFE based dry lube will be your best friend here. Sent from my SM-S975L using Tapatalk |
06-21-2018, 02:57 PM | #3 |
Quarry Creeper Join Date: Mar 2017 Location: San Diego
| Re: Front shocks
Also the front suspension is set up to absorb jumps and hard landings common in U4 racing. Good for that, not so good for crawling. Sent from my Pixel using Tapatalk |
06-21-2018, 03:02 PM | #4 |
| Re: Front shocks
Mine is only used for crawling and trail running, no jumping or bashing. Thanks for the info
06-21-2018, 03:02 PM | #5 | |
| Re: Front shocks Quote:
Sent from my SM-S975L using Tapatalk | |
06-21-2018, 03:06 PM | #6 | |
Sent from my Pixel using Tapatalk | |
06-21-2018, 03:07 PM | #7 | |
06-22-2018, 05:14 PM | #8 |
Pebble Pounder Join Date: Dec 2011 Location: Ridgecrest, CA
| Re: Front shocks
I use mine for general trail running also, and I went thinner on the shock oil. 35 wt in front with stock springs, 15 wt in back with 1.8 lb/in springs. Handles much nicer for me without the rear end kicking up every time I go over a bump.
06-25-2018, 02:30 PM | #9 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Re: Front shocks
Converting my Clone Hammers to upright shocks with the battery up front made a night and day difference in the crawling capabilities of the vehicle. In my case, the cheap shocks on the clone hammers just made the lay down setup even worse, but as others mentioned, there are so many sources of friction in that setup that if it's not 100% perfect, it's awful. Going with stand-up shocks fixes all of that, and getting your battery up front helps a ton with climbing.
10-17-2018, 11:20 PM | #10 |
Newbie Join Date: Oct 2018 Location: Castle Rock
| Re: Front shocks
I tried starting a new thread, but hasn't posted yet... So I'll ask here Has anyone tried using a yeti front shock tower on their twin hammers? I've seen a couple people mention that it's an option, but would like to know if it's a good option. |
Front shocks - Similar Threads | ||||
Yeti Front Shocks | Ryanf58 | Axial Yeti | 12 | 05-28-2017 12:27 PM |
my TH with upright front shocks | nosyajg | Vaterra Twin Hammers | 8 | 12-27-2016 09:08 PM |
Front shocks? | Lochrie2 | Vaterra Twin Hammers | 5 | 02-15-2016 11:18 AM |
B44 FT front shocks ?? | 4XADICT | General Crawlers | 4 | 01-24-2009 08:29 PM |
