06-11-2016, 07:12 PM | #221 |
Rock Crawler Join Date: Feb 2015 Location: Melbourne
| Re: No Drift Winch Controller! (using 3 position transmitter channel) - Part No. 3PW Is there a way to know 100% which version I have? (Standard or HV?) I got it in trade and all I was told was it was heyok. It was wired up so that a cc bec was powering the rx which was then powering the hitec servo this controller and a servo winch. The AE2's bec was doing nothing. But the cc bec was only set to 5.5volts which I thought was odd.
06-11-2016, 07:27 PM | #222 |
Send me a picture of it and I can probably tell.
08-22-2016, 07:14 AM | #223 |
| Re: No Drift Winch Controller! (using 3 position transmitter channel) |
08-22-2016, 07:19 AM | #224 |
Great pictures. Six volts max on that one. |
12-12-2016, 12:28 PM | #225 |
Quarry Creeper Join Date: Jun 2012 Location: Washougal
Is there a what to tell which controller I have? I bought it used, Was told it is a Heyok. I don't know if it is 2 channel or 3?
12-12-2016, 12:30 PM | #226 | |
| Re: No Drift Winch Controller! (using 3 position transmitter channel) Quote:
Send me a PM with a picture of the part. Or, you could just try it. | |
01-17-2017, 09:50 AM | #227 |
Newbie Join Date: Jan 2017 Location: Harker Heights
Can you do a controler for a 3rd chanel 3way 7.4 volts. I am running a ko propo euros and a rx8 turned up to 7.4 and a rc 4wd winch. Shipped to Texas 76548.
01-17-2017, 10:42 AM | #228 | |
Thanks for checking out my electronics! This is the part that will get you going: 4 Amp Relay Output Winch Controller You will want the H option to work with the high receiver voltage. Send me a PM and I will help you. Al | |
01-17-2017, 01:23 PM | #229 |
pm sent
02-19-2017, 08:35 PM | #230 |
Newbie Join Date: Feb 2017 Location: Buffalo
I'm hoping you guys can help me out.. I installed one of your controllers and all good once programmed. Works in and out with the 3rd channel buttons on my tactic stock controller. Everyonce in awhile it'll stick in either position and I have no control! I have to obviously shit my truck off to stop it. Once restarted it'll be fine for a awhile until it does it again. I don't have a lot of RC electrics experienece so any help is welcome please! |
02-20-2017, 05:29 AM | #231 | |
Send me a PM and I will do my best to help you. | |
09-29-2017, 01:35 PM | #232 |
Newbie Join Date: Dec 2013 Location: Huntington
I have a question and I'm too lazy to read every post. I have a dx4c so it has 3 position switches that default to center. Does this controller stop the winch when you release the switch? As in you have to hold the switch to make the winch run?
09-29-2017, 03:04 PM | #233 | |
Connect a servo to your winch channel and post up your results. | |
09-29-2017, 03:42 PM | #234 |
Ok I guess it is my tx then. Kind of figured it was the logic built into the tx. You always have to click the button back to center to get my current winch to stop. Which I hate. That's what I'm trying to figure out how to change.
09-29-2017, 03:51 PM | #235 | |
I had a quick look at the manual, but if it says how to make it auto return to center, I'm not seeing it. Here is the link to the manual if you want to have a look: https://www.spektrumrc.com/ProdInfo/...-Manual_EN.pdf | |
09-30-2017, 07:23 AM | #236 |
Quarry Creeper Join Date: Dec 2012 Location: St.Johns
The "C" TXs don't have the ability to do what you want. You'll have to go to a "S" for momentary operation Sent from my SM-G920P using Tapatalk |
09-30-2017, 08:21 AM | #237 |
| Re: No Drift Winch Controller! (using 3 position transmitter channel) - Part No. 3PW |
12-12-2017, 04:16 AM | #238 | |
Pebble Pounder Join Date: Jan 2009 Location: THE OTHER STATE OF MAINE
| Re: No Drift Winch Controller! (using 3 position transmitter channel) - Part No. 3PW Quote:
Sent from my SM-T320 using Tapatalk | |
12-12-2017, 04:18 AM | #239 |
12-12-2017, 06:04 AM | #240 |
| Re: No Drift Winch Controller! (using 3 position transmitter channel) - Part No. 3PW I have been searching for this answer for awhile. I own the 4c and been disappointed with the switch operations. Lools like the new 5c allows this based on a video on youtube. Sent from my SM-G930R4 using Tapatalk |
Tags |
creep, winch drift controller |
