Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Electronics
Thread: Remote Switch For LED Lighting
Old 09-09-2011, 07:40 AM   #21
I have the Axial Night Vision System which runs off the battery but has a physical on/off switch coming off of it on two wires that is mounted to the truck. Could your unit be adapted to switch the NVS on/off?
Spidubic is offline   Reply With Quote
Old 09-09-2011, 11:43 AM   #22
My controller should work for this application, but I don't know for sure.
The circuitry in my controller works by switching a transistor connection to ground.
If the Axial Night Vision System power switch works by switching in a ground, then everything is fine. The trouble is, I don't know for sure that it does. It could just as likely be switching in a connection to positive.
To be safe, what I would suggest is that I provide a controller that uses a relay for its output, then there could be no problem at all. This circuit would be a little larger as the relay is a little larger than the transistor and it costs a little more too.
I could do this set up for an extra $5. Let me know if you are interested.
Thanks,
Al
heyok is offline   Reply With Quote
Old 09-10-2011, 07:29 PM   #23
Definitely interested. Have a few things I want to do to my truck and another on the way that I want to light as well. When I am ready I'll drop you a PM.
Old 09-25-2011, 03:20 PM   #24
Default Current limit?
What is the max current for these? I ask because my LED light bar, Gear Head RC Trail Torch LED Lightbar, pulls about 390mA.
If it can handle this current, I would be able to recommend your switch for guys who would like to remotely turn my lightbar on/off.
Thanks!
Jim
Gear Head RC is offline   Reply With Quote
Old 09-25-2011, 03:23 PM   #25
The MOSFET transistor that I use is good for more than 10 amps, but I think that's a little much for the servo wire that feeds it. It would be fine for your application. Send me a PM and maybe we can brainstorm some stuff!
Old 09-27-2011, 11:26 PM   #26
Sending a pm your way.
shwng1973 is offline   Reply With Quote
Old 10-03-2011, 11:49 PM   #27
well, if I have winch on CH3, then what I can do with this remote switch?
I am using DX3R now
rcscaler is offline   Reply With Quote
Old 10-04-2011, 06:29 AM   #28
I am using DX3R now
Unplug your winch and plug in the LED controller !
Old 10-04-2011, 12:02 PM   #29
hahaha....I think winch is more important than LED controller.
well, so there are no way to run winch and LED controller at the same time right??
Old 10-04-2011, 12:04 PM   #30
You could run a Y cable. Then when you operate the channel, both things would respond!
Could install a switch on your rig. Normally you would leave the light control selected, but when you want to use the winch, flip the switch.
Old 10-04-2011, 05:13 PM   #31
alright, I am thinking to get a three way switch (On-Off-On)
so, one On for winch and the other for LED,
does that work?
Old 10-04-2011, 08:36 PM   #32
That could work just fine. In fact I just built up that very thing for a guy the other day. He was going to use it to switch between a front and a rear winch.
Old 10-05-2011, 01:39 PM   #33
yeah...I got this set up in my scaler and it works great
that's why I thought the same way...hahaha
I will try it when I place my order, I am going to rebuild my scale rigs, so I think I will still need some more items from U
will PM u ASAP
Old 01-03-2012, 06:33 PM   #34
Default Re: Remote Switch For LED Lighting
..are the LEDs and controller from Axial's AX24257 light system be waterproof on their own. I would like to have these Axial lights, along with your remote switch, but I drive under water quite frequently. What should I do to waterproof LED lights, the controller, and your switch?..
ussprinceton2004 is offline   Reply With Quote
Old 01-03-2012, 07:01 PM   #35
I can't really speak about how waterproof the Axial light system is. Maybe you con coat it in a conformal coating or plasti dip or something.
My remote switch is already waterproof.
The LEDs could be coated in something if you choose to. Silicone is another option, or hot glue, or epoxy.
Old 01-03-2012, 10:01 PM   #36
..ah, ok.....would this particular silicone adhesive sealant work?...here's the link to one on eBay: PRO SEAL Clear Silicone Adhesive Sealant Brand New 3oz | eBay
If not, which brand/type silicone would you recommend for waterproofing around the light buckets and LEDs? Are these silicone safe to use on exposed wires on the LEDs?..
Old 01-04-2012, 06:16 AM   #37
Sure, that would be fine to use around your light buckets. Test a little bit on an inconspicuous area to see if it will do anything to your paint. I was going to suggest using Shoo Goo but I just remembered that it will often do funny things to paint on Lexan.
Silicone won't hurt your wires.
You can probably find some silicone at a local hardware store.
Old 03-20-2012, 09:08 AM   #38
Just had a request to make a small version of this lighting controller. The main goal was to have a really short cable that goes to the receiver. Beyond that, this picture shows how I am making the connection to the lighting now.
Yes it is a lousy picture, but you will get the idea.
Old 03-27-2012, 11:13 AM   #39
Are these switches still available ? I live in North Vancouver and would love to pick one up or have you ship me one. Let me know and I can paypal ya for delivery if its to far outta my way to meet you.
Thanks
Jiggawhut is offline   Reply With Quote
Old 03-27-2012, 11:20 AM   #40
Thanks
PM coming your way.
Tags
led, lighting, remote, switch
You may edit your posts
