07-16-2011, 11:06 PM | #21 |
Rock Crawler Join Date: Feb 2008 Location: Georgetown, TX
07-17-2011, 04:29 PM | #22 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
That's what I thought. Just checking.
08-08-2011, 08:37 PM | #23 |
Rock Stacker Join Date: Nov 2007 Location: Tenino
Anybody with a 3racing winch NEEDS to buy one of these controllers. I received the controllers today. I decided to do some testing to see if the winch was stronger with heyok's controller than the 3racing controller at the same voltage. My rig weighs in around 8lbs, I sat the rig flat on the ground and hooked the winch to the door knob, with the stock winch controller at 7.2v (power from a CC BEC), it lifted the front off the ground and got it completely vertical but then stalled out when it tried to lift it completely off the ground. I swapped in heyok's controller and repeated the test. The first thing I noticed was a major increase in line speed when spooling the line out, I started winching in, it easily got the rig vertical and continued to steadily pull the rig off the ground all the way up to the door knob. Another awesome feature is that heyok's controller will act as a brake and keep the winch from spooling out. I was ready to toss the 3racing winch since it kept stalling all the time, now the winch is actually useable. I can say with 100% certainty that heyok's controller gets a lot more power to the winch, I am very impressed. Last edited by hlb3; 08-08-2011 at 08:42 PM. |
09-17-2011, 10:11 AM | #24 |
I think I better post a little about how these controllers have worked in the field. Of course, people want more performance from their winch, so they run the voltage up higher than six volts. This is what I designed this controller to do. The parts I used will easily handle at least twelve volts. What I am finding is that if the controller is run from the same power supply as the receiver, things work great. Running your receiver at a higher than normal voltage is fine, depending on its specs. For example my Spektrum SR3000 will take 9.6 volts see: http://www.spektrumrc.com/Products/D...ProdID=SPM1200 When the controller and receiver are powered from different supplies, bad things sometimes happen. I know this is the way things are often hooked up, but for some reason that I haven't been able to fully trouble shoot, this is a recipe to burn out the winch controller. |
12-13-2011, 09:32 AM | #25 |
Just adding a little to the explanation about powering the HV Winch Controller, in case it makes it easier to understand: The receiver and winch controller need to be operated from the same BEC, weather that be the ESC's built in BEC or an external BEC. |
02-15-2012, 02:39 PM | #26 |
| Updated Feb 15, 2012: Voltage Winch Controller
I've just made a change to the HV Winch Controller. Now you can power it from a dedicated battery or a separate BEC. Please don't exceed the voltage that you would get from a 2S Lipo pack. |
02-15-2012, 02:41 PM | #27 |
| Re: Updated Feb 15, 2012: Higher Voltage Winch Controller
I can also build the controller like this if you like: The receiver plug will connect to a channel as before. Plug up to a 2S Lipo battery and away you go! This will add another $6 to the price, making it $41 for a HV Winch Controller using External Power Last edited by heyok; 02-24-2012 at 09:25 AM. Reason: needed to mention a price change with the external power option. |
02-17-2012, 01:13 PM | #28 | |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
| Re: Updated Feb 15, 2012: Voltage Winch Controller Quote:
Do you mean the 30v limit is no more and now we should stick to 9-ish volts? | |
02-17-2012, 01:19 PM | #29 |
| Re: Updated Feb 15, 2012: Voltage Winch Controller |
03-31-2012, 07:57 PM | #30 |
Rock Crawler Join Date: Mar 2011 Location: USA
| Re: Updated May 15, 2012: Higher Voltage Winch Controller
It's looking like a Hot Rod ,, racing,, winch controller too me ,,Nice work will be get one of them too ,,But can this one run on the low volt ,,6 ,, also..You probly answered it all ready I just didnt see it Thank you ,,,KMS |
03-31-2012, 08:16 PM | #31 | |
| Re: Updated May 15, 2012: Higher Voltage Winch Controller Quote:
Yes, this one will run just fine at the lower voltage too. | |
04-03-2012, 12:09 PM | #32 |
Quarry Creeper Join Date: Dec 2009 Location: Honolulu
Payment sent. Thanks Al.
04-03-2012, 12:20 PM | #33 |
| Re: Updated May 15, 2012: Higher Voltage Winch Controller |
04-03-2012, 01:09 PM | #34 |
05-08-2012, 03:38 AM | #35 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
| Re: Updated March 15, 2012: Higher Voltage Winch Controller
What do I have to do to run this with a 3 racing winch, HH BRXL and 3s power, thanks for making such great products.
05-08-2012, 08:54 AM | #36 | |
| Re: Updated March 15, 2012: Higher Voltage Winch Controller Quote:
If you want to run it from a separate 2S Lipo pack, lift the red wire from the receiver plug and connect it to the positive of your Lipo pack. Run a wire from the black wire from the receiver connector to the negative of the 2S Lipo pack. If you would prefer to run it from a BEC, the BEC inputs would be connected to your 3S Lipo pack and its red output wire would be connected as in the last paragraph. The black doesn't need to be run because it already has a connection path from your ESC's wiring. | |
05-09-2012, 02:53 AM | #37 |
Thanks mate, great info.
06-01-2012, 01:59 PM | #38 |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
can you run a 3r winch, with your controller, from a external 5a, 9v bec? (hardwired, reciever is on 6v from esc and steering servos are hardwired to 6v from a cc bec.)
06-01-2012, 05:14 PM | #39 | |
I don't know how long a 3R winch will last if you push it that hard. | |
06-01-2012, 09:09 PM | #40 |
will your controller draw more than 5a?
