06-01-2012, 11:52 PM | #41 |
| Re: Updated March 15, 2012: Higher Voltage Winch Controller How much my controller draws is dependent on the winch you connect to it. A better question is weather my controller can supply more than 5A. The answer is yes, it can provide just a little more than 5A. How much current will your winch draw at the voltage you intend to use to run it? |
06-02-2012, 08:05 AM | #42 | |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
| Re: Updated March 15, 2012: Higher Voltage Winch Controller Quote:
06-02-2012, 08:11 AM | #43 | |
06-02-2012, 08:44 AM | #44 | |
You can test this yourself if you like. Connect your own 3R winch to a 2S lipo and see what it will lift. This is a valid test because all my controller does is switch the power to the winch. Granted there is a small amount of resistance added from the controller, but it is really small - in the neighborhood of 50mOhm Last edited by heyok; 06-02-2012 at 08:50 AM. | |
06-07-2012, 07:12 PM | #45 |
Rock Crawler Join Date: Jan 2011 Location: Hartford City, Indiana
I need one! PM sent |
11-20-2012, 08:10 PM | #46 |
Rock Crawler Join Date: Apr 2012 Location: Chattanooga
I would like one of these but want to make sure what I need. I will be running this off of a Traxxas TQI with the fourth channel. I have heard the forth channel is not a true 3 position switch but I'm thinking it will work, do you know. Also if I understand correctly its ok to now run this off a BEC set at 7.2 v meaning it no longer has to get its power through the receiver? I will be using this with a crap winch until my quicksand winch gets in then it will go to power that instead! Thanks
11-20-2012, 08:32 PM | #47 | |
Yes, you are right about the voltage. 7.2 is fine. You could even go directly to a 2S lipo if you like. | |
12-03-2012, 05:25 PM | #48 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
hey man. got a little question: i got one of your higher voltage (7.2 i think) 3 pos controllers a while ago, and am finally using it. however, i have the the bec down to 5.8 volts for my servo. is that a problem? also: i get a lot of cogging and sometimes it just decides to go the opposite direction when using it. it also has a delay when using it. i press the button and count to 1 and it starts, then it also keeps going for about the same time too. all in all its almost unuseable. what do you think? |
12-03-2012, 05:33 PM | #49 | |
01-03-2013, 08:58 PM | #50 |
Newbie Join Date: Jan 2013 Location: Des Moines
hello i was looking at your lower voltage units and was just wondering how much this high voltage unit, 3channel with jst plug will cost thanks
01-03-2013, 08:59 PM | #51 |
3 position switch sorry
01-03-2013, 09:03 PM | #52 |
The controller is $35 and adding the JST costs another $2
01-03-2013, 09:29 PM | #53 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
Just so I'm clear, if I want to use a hv servo winch, say a hitec 7955, with your controller, can I power it with a 3 cell lipo directly? I see 3 of these controllers in my near future. |
01-03-2013, 09:41 PM | #54 | |
Check out the 4 amp (or larger) controller on this page if you want to run higher than 2S Lipo voltage: Winch Controller - Relay Driven - External Power | |
01-03-2013, 09:58 PM | #55 |
Ok, wiil do. Thanks. |
01-06-2013, 04:03 PM | #56 |
Need to make a servo winch? Another servo winch building tutorial |
02-06-2013, 10:15 PM | #57 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
Your first post says you can use a 3s battery, and mention of up to 30v. Is that still correct? |
02-07-2013, 06:07 AM | #58 | ||
02-07-2013, 07:28 AM | #59 |
I can see that... but 3 lines below that it says " You could try 3S Lipo, if you think your winch will handle it " which is why I was questioning it.
02-07-2013, 07:39 AM | #60 |
Right, I see how that is confusing. Perhaps I should change it. It was left to show how the product changed over time, but really, that isn't important... The other part of the reason for leaving it is that I don't have control over any posts but my own, so if I change it, the following posts and my follow ups won't make sense. That's why the first post in bright red explains what is happening now. Appreciate your input. |
