08-23-2010, 06:04 PM | #241 |
Pebble Pounder Join Date: Nov 2009 Location: Hudson
I have to say this is one of the most detailed threads ive read, and i have read just about every post. This is a good thread because you dont have to break the bank, instead you us what you have. After last nights read i have started a complete rebuild on my creeper. |
08-23-2010, 08:49 PM | #242 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
R-L,,,thanks for the kind words. I try to be detailed when I post up. To me theres nothing worse then lots of eye candy then no idea of how it got that way. Without the whole sob story my life has been a University level education of diversification and fabrication. Start a build thread if you havent already,,lets see the work in progress.------> Rock-Lockster's Rebuild |
08-23-2010, 08:56 PM | #243 |
Couple of tech notes....I received confirmation on the shipping of my HD CVD's. I worked a trade out over the weekend that earned me a set of Moab XL's and Axial 40 series Beadlocks. The Super Creeper is in the works. I also went out this evening and bought some M4 set screws, an M4 tap and a #30 drill bit so I can drill and tap my Traxxas Steel Yokes for M4 set screws. The M4 set screws use a 2mm driver instead of the 1.5mm driver that an M3 set screw uses...should be able to get thing a bit tighter that way. I personally dont use Loctite on my drive shaft set screws. I want the drive shafts to be easily removed if I have to rebuild an axle at a comp. PLus,,Ive stripped out the hex socket on about 4 of the M3 set screws. I was thinkin about the whole fast rebuild thing and thought of a way to make the axles about a 1 minute job to replace if I have a prebuilt axle standing by...there wont be any bolt and nuts holding the links and shocks on the axles. Ill post up when I get more done on it.
08-24-2010, 12:36 AM | #244 |
Rock Stacker Join Date: Nov 2009 Location: Hawaii
Ummm...excuse me, but I can read your threads just fine from here. |
08-24-2010, 12:50 AM | #245 |
Bah...ok...now I know what you are referring to, that dude in Tncrawler's build thread. Went and checked the members list since he mustve deleted his post. |
08-24-2010, 05:50 AM | #246 |
The question about steering throw has been raised a bit lately and part of that is the use of the right horn. Mine is custom using a iece of the Stock Creeper chassis plate to make an extension. The standard aluminum horn I run is 13/16" from the servo horn screw to the outer link hole,,I made a custom extension that makes it 1 1/8" and it gives me all the throw I need. It works just fine with my DS 8711 servo too. But it would be too much for a lesser servo like a 645 size. |
08-24-2010, 06:08 AM | #247 | |
08-25-2010, 07:09 PM | #248 | |
Oh by the way i use klein tools every day, there the best. | |
08-25-2010, 09:35 PM | #249 |
R-L,,,Thanks man. I made a slight change to the VC since I am running right now with stock CVD's and the limitations of the Right front long shaft i had limited the steering a bit to save the CVD. Since the steering is limited I decided to also remove the G-MADE Wheel Wideners. The VC is now back to stock track width. Im also kind of wondering if the added stress of te wideners added to the carnage that resulted in the cvd breaking. Still waiting for the Vulture chassis prototypes to be done...delay after delay...but soon hopefully Last edited by rmdesignworks; 08-25-2010 at 09:43 PM. |
08-25-2010, 11:07 PM | #250 |
RCC Addict Join Date: Dec 2008 Location: pullin somebody else out of a mud hole
looking for opinions i am thinking about changing the chassis over to a slingshot with traxxas shocks and losi springs ? sorry not trying to hijack your thread rm |
08-25-2010, 11:11 PM | #251 | |
Kinda figured out you were referring to 'Runninonmt', think that was his name. Always find your threads very informative RMDW. | |
08-26-2010, 05:33 PM | #252 |
The little red white and blue truck dropped of a package of HD CVD's from CKRC today. Ill get them in and let you all know what the real difference is between them and the stockers. All I know is they better last compared to the stockers,,Im not easy on my rig and I dont plan on changing my driving style just cuz there's sparklies in there.
08-26-2010, 07:59 PM | #253 |
Rock Crawler Join Date: May 2010 Location: CRAWlORADO
Im running the rc4wd cvd's and they work awsome I have not had any problems at all I have read that some of the ckrc cvd's have broke but I think its all in the driver.
08-27-2010, 10:38 PM | #254 |
| Creeper steering once more.....
After building my Creeper to begin with I loved my VC's steering angles,,,right up there with Bergs. But finding the limitations of the CVD long shafts I limited the steering to save the CVD's. I got my CKRC HD CVD's in yesterday and installed them tonight and took some pics of the differences. The wrist pin is definitely bigger but only by mil's. There is a defnite difference between the stocker's angles and the HD's. The HD's have a much deeper pin throat and the knuckle bottoms out way befor ete HD CVD's do. |
08-28-2010, 12:35 PM | #255 |
Quarry Creeper Join Date: Jan 2005 Location: uk s,wales blackwood
all i say is best of luck with them (i did go to reply this morning but my connection died before i could submit it and i aint typing all that again) |
08-28-2010, 12:46 PM | #256 |
| I take it you had issues with the HD cvd's? WIthout all the typing can you narrow down your reply into what happened?
08-28-2010, 01:10 PM | #257 |
sure in short i bought the ckrc cvds when they first came out i had to file the pin slots so they had the same amount movement on each side of the ball and debur them so moved smoothly with out binding they lasted about two months before the balls shattered, since then i have fitted standard cvds and steering stops so it cant over stress the pins as its unable to get full lock even when being forced by hand they are a bit sloppy now but they still work i want to try the rc4wd ones to see what they are like Last edited by perfictsib; 08-28-2010 at 01:11 PM. Reason: forgot somthing |
08-28-2010, 08:27 PM | #258 |
Well heres my thoughts,,,my stock set from the first day lasted about 3 1/2 months, these are advertised as being better than stock so they need to last at least that long if not 5-6 months based on the wording in the ad on CKRC. My stuff is well documented and if they fail prematurely then CKRC will be receiving a request for replacement or refund for the HD cvd's. I had originally wanted the ones from RC4WD but they are always out of stock...maybe one day.
08-28-2010, 08:37 PM | #259 |
Hey Thomas, The pin does look bigger, but what about the rest of the measurements? If everything else is the same, does that mean material was taken away to make room for the pins? Or is everything else bigger too? It's hard to tell from the pictures which is which until you show the steering angle. |
08-28-2010, 08:54 PM | #260 |
Juan,,sorry guys,,in the pics the HD cvd's are always on top of the pics. Without a digital micrometer its hard to see where material might have been sacrificed,,however if a better steel at a better Rockwell rating is used then the same amount of material or even a bit less would,,or at least should be stronger. The HD's I got are Red Loctited from CKRC and I didnt want to break them apart. The allen drive set screw in the HD's requires a slightly smaller Allen driver then 1.5mm too. My hand driver wouldnt fit into the set screws. There are some very slight differences between the HD's and stockers that you CAN see, such as the threaded area of the stub axle and the shoulder area where the outer bearing seats,,,and the tube bearing shoulder on the main shaft is also slightly different. The biggest difference I saw was the slot or throat that the pin pivots in is definitely deeper on the HD's. The coloration of both HD shafts are the same unlike the stockers. Im gonna hope for the best. |
