MISFITCOMPER
I went thru the 4 pages of this thread so far and alot of complaints about the weak CVD's/Axles and alot of people say to back the steering off and it will be fine.....well if it was desinged to have so much steering then shouldn't have to back it off, that's like buying a new car with A/C and every time you run it on High the car over heats and the dealer says to use Medium speed cause it will work better!
After seeing how many times the release date was pushed back after preorders were made and now this, I'm so glad I didn't order one.
If you take the truck and have your steering EP's maxed out and hold it in your hands, turn it full crank. You will here the cvd's making noise, that noise is the cup hitting the axle shaft. The cups don't taper inon the inside edge, creating stess on it. Once you do this, the shaft is compromized. Next thing you know you going up a straight vertical looking for traction, you hook up and SNAP! That's why its nice to back off the steering EP's. Besides the dig will help you turn sharper if needed.
