jcboof
Yea, if he's saying it was right, and you have proof that it wasn't, which in the pic it clearly isn't, then he rewired and more than likely screwed something over on it through no fault of yours. This whole situation just seems really sketchy....
Looking back over some old PM's from him he states that he has 2 5000mah lipos. One is a reedy and the other is a venom. The venom would not fit in the car unless its a bullet pack battery, and the reedy would also not fit unless it was a bullet connector pack. Things are getting a little more sketchy now.....
The way the JRXS chassis is set up is for a bullet pack lipo. If he had packs that were direct wired, both the positive and negative battery wires would have be located on either the left or right side of the pack. There is no way for the wires to fit through the wire openings unless he took out a dremel and cut a large slot in the chassis top plate which would ruin the chassis.
So he has to have bullet connector packs. IF he rewired the connector with bullet connectors, he likely crossed polarity or ruined the board when soldering the connectors on. Or if he didn't rewire the plug, he would have had to use an adapter like I did.
I really hope he sends me some pics and clears things up. I really want to make things right on my end to clear my conscience but if he is unwilling to respond, I'm just not sure what to do.
