Trail Blazer
I noticed the Xr beef tube from beef tube are a bit longer specially for this mod, I only have the stock wheels from the honcho kit so might have to look into those
wait a second, are you guys saying i need different beef tubes if i want to install new cvd's? if so, what ones?
No only for the Xr mod the tubes are longer, the lads are saying some of them still use normal lentgth tubes with the Xr mod. I havnt read anything about different tubes for cvd's "thumbsup"
wow this is getting long in the tooth.
XR Mod = XR (or wraith) Knuckles & Chubs (not necessarily nailing down which uni's)
Narrow XR mod you will need longer uni's (either lengthen scx10{ or ax10}universals or shorten xr universals )
Wide XR Mod uses stock length xr universals.
There is a lot of confusion because there are 2 (at least) different width XR Mods people are talking about (narrow & wide) without differentiating which is which.
Pick a width (or universal ) & let whoever you are getting tubes from what width (or universals) you are using & they can make sure you get the right ones.
You must use splined tube ends if you want the splines to line up together & lock in your clocking position with the chub, you can however clean out the ID of a splined Chub so it fits OVER the splines & then you use the screws to lock your clocked position.
Many options, many good ways to go, lots of overlapping info,
XR mod sticky maybe?
/\ well put CHUD
Spot on except for the part about needing splined tubes or cleaning out the id of a splined chub. Read some of the links posted above, you trim some of the tabs to act as splines and you can clock the chubs at matching angles.
This is why Axial should add this to the scx10 instead of spending tons of money on new body rigs that don't steer,,, They have the best scale rig why not make it better ???
I would love to see a narrower, center pumpkin AR60 for the SCX line. It would solve all of this swapping around of parts, and bring the SCX axles up in the scale factor. The AX/SCX axles were great years ago, but are pretty dated in looks.
Psssst...Brandon, are you listening :ror:
i could not agree more. in my opinion the four things axial should make stock about the scx10 are 4 link in the front, chassis mounted servo, waterproofed and better steering.
Go to 3 link with pan hard in frontok i have a problem with bump steer that i didnt notice before... at full flex on one side the tires are less that than a hair width from the shocks, not leaving for anymore radius. I'm running 4 link and cms, and when not flexing it could have way more steering. is there anything i can do to fix the bump steer or is it just something i have to live with...? (at least i can still run od/ud)
Make sure there is no play in your links that you use spacers to keep everything tight where your links connect to your axles and to the transmission mount, see if that helps. btw.. are you using plastic or metal links? As long as there is no slop it should work.
for instance on your axles where your lower links and shocks sit side by side, if there is room for them to wiggle put in some spacers to fill up the space if needed.... same where your links connect to the transmission mount.. make sure your links cant slide from side to side, and uppers etc.
