fr8cture
I better start saving now. :lmao::mrgreen:
I'll do that. I definately have the room under this interior pan for the skid to come up, and that is a great idea for sure. I didn't measure the stock Wraith chassis to see where I stand as far as height goes, but I want low and mean. I'm trying to decide on where to mount the lipo while I build. Right now the stock Exo spot looks promising with a 1350 or 2200 lipo. That should also help balance the weight too if I mount the ESC and all on the drivers side. I'd like a easy to change type setup, so this may be my best option.Wait till you have all your parts on hand and you can put it all together with something under your tranny to space it up.
I used mixed matched mips amd traxxas max shafts, angle wasn't bad at all.
But you deff have me thinking about coping your truck. Lol
Save away "thumbsup". If it performs like I hope it does I'll be keeping this one for a while. I've been wanting a capable C3 rig to compete with for the last 2 years now, I just hope I'm on the right track with the amount of money I'm sinking into this build.I better start saving now. :lmao::mrgreen:
Nah, I think the one on my axle will work but thanks "thumbsup". As for the weight, I've got beeftubes in the axles and I also have a set of Bluemonkey axle weights to tune with. I like a little forward bias, but nothing crazy. With it having the servo up high on the chassis like it is now it's front bias already for sure. I'll built it up and then throw the weights on if it needs it. I made some decals for them so they look like brake rotors. Gotta keep it scale :mrgreen:. Nothing in the rules about axle weights, but I don't want them sticking out like a sore thumb. The skid Idea is a 90% reality on here though. As soon as I have it a roller I'll check into it "thumbsup".More than balance, think front weight bias, yeah you can stack the front wheels full of weight but that has its limit.
Low weight is great but low and over the front drive shaft will do ya even better.
Why does No one make a front motor mount for this thing?
And I just found the small Panhard mount for the wraith - do you need one?
They feel great. I'm going to experiment with the inners a bit. Thanks a million sir "thumbsup". They should definitely do the trick. WAY better than stock for sure.How the foams feel? That was all of my 2.2 stock I had left. Lol
I'm not sure on the first question. I set it up like this from the start. The shocks get very close to bottoming out before the servo and truss hit each other. But you never really have full on compression up front anyway so I can't see this being a issue. The w.b. is a stock Wraith w.b. The skid, links and axles are straight out of the Wraith handbook. It may get brought in a little if I raise the skid, only time will tell.Without the panhard link how much does the cms and servo hit at compression? And suspension looks awesome i got mine mounted a different way but cant wait to c how urs works out? And whats your wheelbase as it sits now and r u gonna change it?
Thanks. There are two reasons behind the shocks being upside down. First is clearance. The tops of these shocks a bigger than the cups so they rubbed when upright. The other reason is to keep the weight down low. The upper halves of these shocks are fairly heavy "thumbsup".I love Wrexo builds, and especially this one. Nice work! I may have missed it earlier, but may I ask why you mounted the shocks upside down? I see no reason really why to do that. Otherwise looks absolutely killer!
Thanks man"thumbsup"Looking good bro!!!
like that upside down shock idea too!
I thought about it. As it stands I used some that were 1/2 longer than stock and it still wasn't long enough.Can you put longer rod ends on the rear shocks - should reach the stock exo shock mount perfectly then.
Thanks "thumbsup"i like this alot, deffinetly gotta get one started,
Thanks, I had to break down the whole top half of the cage ti get it all in there :roll:.That is looking good. Bumper looks great on there as well as the engine.
Thanks Eric. It's pretty nice stuff. I think I have one piece (for the lights) that's off just a hair, but that's expected for hand made equipment. I love it for sure.Looks great James. Can't wait to bolt up my bgr stuff too.
