Droop Vs. others
See here is where I just get lost again. You say Pro's.. And list Lower COG. Well you can set up any 4 link Sprung set up to set just has low. You can have the links just as flat. By one either running shorter shocks or changing the angle of them and so on. On the Dropping the axle part. Just sounds goofy to me still. I can see Droop helping on Sidehills. Steep inclines I don't see it being any better then other setups. Speical a Stick set up. Just not possible b/c of the break over point. We need to post some videos showing how this works and why. And what makes it so much better then a Correctly Set up Sprung rig.
run2, you asked for it (hope MTHead doesn't mind)...
http://www.youtube.com/watch?v=eN9Cvo6Sn0Q
I think this vid shows a droop working properly...watch the breakover
about :32 into the vid, as the skid high-centers on the rock the droop
set-up allows the front wheels to maintain traction.
I don't think you can get the same effect running a conventional sprung suspension.
But, I could be wrong :-P After all, I'm a just a noob
BTW, I've really enjoyed this thread...very informative and productive
discussions like this are what makes this forum worth reading every day.
back to the oil weight.........
i have read every thread about droop vs. sprung, im with R2J i just want under stand it.
i have been messing around with kind of super thick oil (i read that JFA was running 1000wt in one of his rigs and he liked it) to see how the suspention reacts. THE RAMBLING IS ABOUT TO START try to keep up......well in some rocky places the thick oil works very well due to the slow reacting axle, front right tire on top of a rock then the left starts coming up, the right will stay in the air for a second longer when the left hits the top of a rock and the right will set its self down on top of another rock if you work it with the throttle. but now i have seen something like this with sprung suspention also but the tire does not sty in the air as long. RAMBLING OVER.
SO.... the way i under stand this is with a droop set up (no springs in side) your cassis is what makes it settle to its ride height. so a lighter chassis does not work as good as one with more weight. these are what effects the pressure on the tires.
sprung suspention chassis' weight has little effect on the articulation of the suspention. all of the tire pressure on the ground comes from the springs.
the droop
i think that a sprung truck would climb the same rocks the same way.
i have seen on some of the comp videos trucks (droop and sprung) navigate the same rocks and they both look the same........ i dont know any more.
i did jump on the droop band wagon (i made 4 tubers 3 2.2 and a super all of them droop) but now im not so sure. on some rocks the droop works better and on some rocks the sprung truck works better.
i dont know......... 9 of one and 3/4 of a dozen of another "thumbsup"
YES..... i like this thread too.
Does anyone have a Video of one that can droop like the Above video and still carry a Tire? I can't see how it could carry a tire like a Torsion Set and still Droop that much. Doesn't seem possible.
It will "carry" the tire if the hole is deep enough or the oil is thick enough. You cant have lots of articulation and have it act like a torsion too, but you can set it up for any amount of articulation that you want.
So if you can carry a Tire like a Torsion Chassis. Will it still Droop like that Video? Or does the thicker oil slow down the reaction of the droop to Carry the tire longer before it droops. Does that make since?
I swear I'm not retarded......Just seems to be a lot of I'm not sure how it works answers. Thats all. I think this helps to get to the bottom of how it really works.
The thick oil will allow it to carry a tire over a hole. It slows down everything though so you would have to drive slower over a break over angle rock.
I like this droop idea. I'm currently building a TXT tuber but I think instead of building with conventional extended shocks, I'm going to build on the bumpstops and set the shocks up for a "retracting" spring. The shocks are 6.25" long Aluminum Savage shocks.. should work well for this setup.
I know i'm learning alot about how to set my hustler up ,
I have tried NO springs in the front , and the thickest oil I had at teh time which was 80 weight in the rear. I totally understand what rockpiledriver is talking about. Testing the same thing here. ;-)
Bingo... I limit the unloading with a zip tie from the chassis to the axle.
Here is another curve ball for you. I only run springs in the front shocks.
And yes, the only comparison I am making between the drrop and torsion is the ability to carry a tire. Now... I can increase the amount of articulation on my droop rig, while limiting unloading at the same time. With a torsion you could only increase flex with tire weight, and if you do that you will also increase the effect of unloading. Same with a stick chassis or a sprung rig.
The droop also alows the axles to fall away from the chassis to gain traction in a high center situation. Another thing that is impossible with all of the other designs.
I'm *trying* to answer your questions, let me know if it's working. ;-)
r2j...Maybe I'm way off base here (noob, remember) but I believe that
the way in which the vehicle weight transfers is what makes the difference.
I "believe" that there IS a difference between dropping only the axle on a
break-over, and shifting the entire vehicle weight. (as would occur with
a sprung set-up)
Also remember that a droop rig set-up (properly) will have a lower COG.
(I know there has been disagreement on this)
Question for you: Why (or) do you feel there is an advantage to carrying
a wheel ? Wouldn't it be advantageous to keep as many wheels in contact
with the ground as possible ?
Just wondering here.....
example of where carrying a tire would have helped.
I don't think calling it.. Lower COG is the right term. I'd say more of a way to counter act rigs with a Higher COG... I say that b/c the springs help keep shocks closed. You still have that the weight in the same spots. I have seen many Sprung rigs with Flat Lower links just like Droop set ups have. And I have seen a few Droop set ups not have there lower links flat.
Run why do you keep saying a tuber has a higher CG than a TVP style truck?
I just don't see how the comp tubers of today can.
B/c Steal tubing and Brazed Joints Out weigh most TVP chassis....Look at XRC and the SW3....They have less material up high and it's aluminum not steal tubing...I'm sure it's not much. But with bigger Tubers like with a Super Class rig. The SW3 and XRC would have less weight in it.
You are forgetting one key point thought the body.
A stock rubi body weighs over 6 onces wich probably is more than the xrc itself.
Now you just flipped the weight from low to high.
The hustler has a very minimal cage up top that I would bet weighs less than a leaxn body.
What does your chassis weight with the Panels on it?
