CRSMacgyver
Yes it will be fine.
J
I have been running it this way for a couple months with no issues at all. good to hear it officially......
J
1) Battery + goes to the RED wire of the battery itself right? I always get confused...
2) Can I just turn this setup on without having to set the ESCs individually? Turn on with escs, servos all plugged in then set everything?
Thanks in advance and sorry about the basic questions "thumbsup"
Mike
The FXR's have B+ and B-. Positive (red) to positive, and black (-) to black. Nothing too special there.
I don't understand what you mean by set the ESC's individually though.
Great info, Great sales man, even better product, futaba better be taking care of you big time. Loving the 4pk, followed your step by step with no issues, Now if you could use your awesomeness to make the rain go away so I can drive my new bully it would be awesome. :mrgreen:
Ok so when you set it up with 2 esc's you set 1 switch up to turn on and off pre mix 1 in "alt" and 2nd switch to turn on and off pre mix 2 in the "alt" position. So when you push it it turns it on then when you push it again it turns it off as set-up like you use. But if you leave the switchs in the "Nor" position you have to hold them down to activate that channel and when you let off it is deactivaded. And what I would like is that it is in 4wheel drive all the time hence 3 and 4 channel on all the time and then when you hold down the button it would open the signal the that channel instead of closing it. So you could hold the button when you want dig (open) and then let off and it automatically closes the channel again. Does that make sense hopefully?:?
Thanks
Harley
I was just following up if you ever found out an answer to my question. Thanks8)
Do you know of any micro RX that work with this radio?
Or heard anything of maybe getting one?
I don't really want to have to use a losi radio in the micro crawler.
Even 2 or 3 channel would be fine, come to think of it, a tiny one would work well in most crawlers, we don't need much range.
A micro RX is not available yet. I know that one has been suggest directly to Futaba Japan. I suggest them EVERY SINGLE MONTH in my driver race reports. I will get one made!
Attacking the RX
In an attempt to not leave any part of this truck simple and stock I decided to attack the Futaba RX. The Futaba's RXs are larger than some of the other companies out there but since they are the best it isn't like I would ever want to change for that simple fact. Instead I decided to modify the RX for this build to make it smaller. NOTE that this is definitely not Futaba recommended or approved, it will also effect range.
I started off by disassembling the RX. The two antennas plug into the curcuit board. One antenna is internal and one is external. I did 4 range test using my friend Aaron's Berg, both antennas, just external, just internal, none. Honestly I didn't have any range issues at the distance I was concerned about with any of the configurations, so NO anteannas it is! If I notice that I need one later I will plug the external in and coil it in the case.
So I decided to desolder the internal antenna mount and take it out of the case. The step up on the Futaba RX's is to accomodate that antenna, so it is no longer needed now.
After removing that I sanded the entire case smooth so that there were no lips, then I filled the hole with styrene and used body filler to smooth it all out. I used the Cow RC Moo-tor cleaner and degreaser to get all the residue from the sticker and sanding dust off. Worked really well and it didn't take me any paint prep time then. It didn't have any effect on the CA glue or anything either.
Lastly I shot some primer on it, most likely the RX will just get a simple coat of a subtle color.
I tried searching the thread..and now it's to bigso I hope this has not be asked yet..
is there a way to change the mix "names" on the main display??
right now it reads...
pmx1
pmx2
( i think thats close)
could you change it so it reads..
Front
thanks8)
