4PK Setups, Tips, Tricks and Help
no its not
Ok, then it sounds like you might have an EPA problem.
Clear the model memory or start a new one is my suggestion. Program on of the DT switches as a 3 position switch like I detail in here and then setup the rear steer with one of the methods I give.
If that doesn't work I will gladly post screen shots of the settings you need. We will get you setup one way or another.
i have punk setup on DT 2 with 100% both ways but it seems that the punk isnt reading ch3. i mixed it with the steering like i was running dual esc's and it worked fine. rear steer is setup on ch4 using either dt3 or dl2.
I have never heard of the problem before with a Punk but just for grins, go to RXSYS and change it to C1. Then turn the radio off and back on. See if that does it.
i figured it out. i forgot to change it back to c2. im a tard. thanks for all the help Harley. just when i thought i was getting used to the radio the small things screw me up.
This might be in here, I've searched but can't find it, anyway is it possible to run a high speed servo and a normal servo at the same time? I'm running a Hitec 5990tg servo for steering and the Axial AS-2 servo for a winch and when I plug both in the RX blinks red then eventually shuts down. Maybe it's something else but that's all I can figure.
I don't know what the issue is Zach. In my RubberBelly scaler I run a 9157 for steering and a 3003 (analog) for the camera, plus a 3Racing winch (equal to an analog servo). I have never had these problems, try switching your radio to C1 mode and in the RXSYS menu and see what happens.
Well, I switched it and no luck, it didn't work at all. I switched back to C2 and still blinking red to green light then eventually shuts down. I plugged in a Hitec 625mg that was laying on the bench and no problems at all. It must be the servo but that sucks because it's a killer winch servo.:cry:
Any other ideas?
I had another AS-2 in another crawler set up as a winch that I plugged into the RX and no problems. Must just be a bad servo altogether. Thanks for the help though.
short battery life
I just fully charged my new 1700mah stock battery and only got 2hrs and 46 min of total time before my controller died. Is this to be expected or is something wrong? will a 2s lipo work?
Something sounds off for sure. I would estimate I get 8 hours out of mine. Cycle the battery a couple more times and see if maybe you didn't just get a false peak on the charger.
hi just bought 4pk but i cant set it up to vibrate, im going to vibra then fuel timer and pt1 - 7 go back to main menu ,try it out but nothing . am i doing something wrong?
thanks
im just trying to make it vibrate for fuel pit in but the menu is very confusing to me
