Can't remember the color off the top of my head but it's the middle one.
No, power is the middle.
Now that I think back and you say that you have to pause before you can drive, I think you may have the throttle mode set incorrectly.
The BEC signal wire is yellow.
What would be the correct throttle mode setting? I checked in the TH-SPEED menu and it shows this:
MODE : 1 SPEED (OFF)
ALL : 100
It works finally!! set the "brake/reverse type" on the FXRs to LED 2. And no more having to pause for a couple seconds to go in reverse. I'm such a noob. Thanks Harley"thumbsup"The problem you are having is in the ESC's not in the radio. You need to make sure the throttle mode is correct in the FXR's.
ok harley, I need help.
I bought a moa rig used for a great deal. came with a 4pk that the previous owner "programed".....well i reset the 4pk and set everything to your specs. its working great!!!
now here is where im having problems. the escs are not putting out even power at slow speeds.
going up hill the front pulls way harder than the rear. almost like the bias is on but it reads 100%
but at wot it will stand on the rear axle tons of power.. could it be the motors?
or should I buy the cable to set the fxr's with the computer?
Sorry, but I have been having this as well with mine, my dad's, and a couple of the other locals. I know I have done that when I had my 4PK, now I have the 4PKS, and my dad has the 3PK with a couple others running the 4PK as well. That hasn't seemed to help us out. Maybe it's an issue for Tekin in our case.
I'v gone through Harley's videos many times, and I'v known 4PK/4PKS could drive front 100/rear 0-100 and front 0/rear 100. But there is still a question here for me a noob. Whether 4PK/4PKS could have front wheels proportional while the rear is 100, such as front 60, 80 or any from 0 to 100 and rear is 100? Thanks."thumbsup"
Yes it can, completely worthless in 99.99999999999999999999999% of the situations your truck gets into though.
