Associated LRP Quantum Super Reverse ESC, is it a good speed control?
Chadworkz
Gadsden, Alabama
Product: Associated LRP Quantum Super Reverse ESC (#LRP8420)
Basically, I have two main questions, but I would like as much information as you guys can or want to provide...thanks in advance!
[1] In general, is this a good ESC? Maybe for a 1/10 4WD EP Buggy?
[2] Would this ESC work as a crawling ESC? Maybe for a beginner RTR?
The reason I ask is because I might possibly be able to get a bunch of them NIB for an extremely low price!
Rec. Motor Limit - 13-36 turns/winds
Voltage Input - 4-7 cells (4.8-8.4V)
On-Resistance - 0.0023
Rated Current - 90A
Max. Current (30 sec.) - 55A
Cont. Current (5 min.) - 35A
BEC Output Voltage - 5.0V
BEC Current 30 sec - 2.0A
BEC Current 5 min. - 1.2A
PWM Frequency - 2300Hz
Reverse Operation - yes
Multi protection system - yes
Standard Connector - yes
1) It will be perfect for the buggy
2) It may not do well in a crawler because it goes into reverse immediately, if I remember correctly. I could be wrong, of course.
I would think it would be a decent to good scaler esc.
I have not used that exact esc but most of the older reversing esc's drag brake is weak, and you may have to "double tap" it to go into reverse. I think the other poster meant it would not go into reverse immediately.
I have one on an axil crawler It does'nt have a ajustable drag brake. It works but it rolls on the down hill and you must use the brake.
