Dasher
Croakin' across the pond!
Hi Everyone I thought that I'd put together a short build thread as "Boris" ha now reached a decent state of tune. Like most who've gone the upgrade route I've got very little of the original AX10 left. I've also used may tips and tricks that can be found elsewhere so this is not a change by change build thread.
I've not attempted a build thread before so I hope that it goes OK.
Boris started as a stock RTC AX10, he ran OK first time out but decided to leave his drive shaft set screws out on the rock somewhere. Consequently, on returning home I completely stripped the rig and did the chinese builder's job for him (properly). At the same time I acquired another AX10 off ebay - Kit built so had all the shiny bits - and started a transplant operation.
Once that I'd found RCCrawler - I realised that shiny bits didn't help much and that a start from scratch approach was needed. I'd read Casey's build thread, recognised the similarity and decided to build a Frogger.
In early Feb 2011 the chassis arrived,
I'd tried various shocks on the bodied AX10 and settled on a semi droop set-up, using 3Racing shocks, 30wt oil and internal springs. Externally at got differential rate springs and a stiffer one on the left rear to try and take out torque twist.
The Frogger didn't sem to like this, annoying as I'd spent a lot of time developing a mix that worked well.
