08-08-2017, 09:54 PM | #201 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
| Re: The old girl is wore out--time for a change. |
08-09-2017, 12:41 AM | #202 |
And the pads for the pedals. The right will be for rear and the left for front. As you can see there placement should make it easy to hit both. I am not 100% on how they sit and ya never know till its actually used but I am hoping I nailed --will see... |
08-09-2017, 12:45 AM | #203 |
So next I figured I would so the accel pedal. I had a stack of toyota 1st,2nd and 3rd gen truck pedal assemblies to choose from and I believe its a 3rd gen I grabbed. I had to rework the mount portion of the pedal first and then made a riser that it sits on.
08-09-2017, 12:46 AM | #204 |
Riser mounted now onto the part that holds the cable.
08-09-2017, 12:47 AM | #205 |
Made the bracket for the cable and got it mounted.
08-09-2017, 12:49 AM | #206 |
Got it mounted and notched the panels for the cable to pass thru.
08-09-2017, 12:51 AM | #207 |
So the next part is what I call the backbone and its a very important piece as the hood will butt up to it and the dash will also. So I started by making it and then trimmed the hood to match.
08-09-2017, 12:54 AM | #208 |
So the hood is kinda flimsy in the middle so I made something for it to rest on and then trimmed the backbone down to match the hood better with a lip to help keep water from running back.
08-09-2017, 12:57 AM | #209 |
so it was time to start the dash and I started with the top part of the dash.
08-09-2017, 12:59 AM | #210 |
And from there it just evolves.
08-09-2017, 01:01 AM | #211 |
I ordered a custom set of guages from speed hut and finally got them out of the box and finished the drivers side. And there it is the finished dash.
08-09-2017, 03:04 AM | #212 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
Wow.
08-10-2017, 12:35 AM | #213 |
08-10-2017, 12:40 AM | #214 |
So I had an idea for what I wanted to do with the electrical center. I wanted it as weather proof as possible and I had a spot I wanted it to go but had to wait for the dash to be done first...
08-10-2017, 12:44 AM | #215 |
And this is what I came up with. It was built in that size to fit a certain spot. I originally wanted to use 1/2 turn retainers like I did for my storage but there just wasn't enough exposed height so I went with threaded knobs.
08-10-2017, 12:45 AM | #216 |
And there is where it goes. I got a start on mounts for the relays and will do more once I hit that point.
08-10-2017, 12:47 AM | #217 |
So now back to my storage area in the back of the rig. Now I played with a few different ideas for a lid. I wanted a lid with overlap and once I figured out what overlap I wanted I had to cut it down a bit so the lid could slide over the bin without the rear tube hitting it.
08-10-2017, 12:50 AM | #218 |
So I got the lid built and used a larger retainer. It locks done really nice and I used an automotive foam seal for the lid.. I was really happy with how it turned out..
08-11-2017, 12:35 AM | #219 |
Ok so one thing I plan on doing is enough wiring so I can get the mounts on the chassis.
08-11-2017, 12:37 AM | #220 |
I got the batteries wired up and the main battery feed started down the driver side of the chassis. That will be finished later on.
The old girl is wore out--time for a change. - Similar Threads | ||||
Time to change it up!! Pic heavy | mudbeast2 | Axial SCX-10 | 18 | 05-23-2015 11:27 PM |
Time for a change | kookie31 | Axial SCX-10 | 2 | 04-17-2015 11:24 AM |
Time for a change | ManiacMagoo | Paint and Body | 1 | 07-10-2010 05:25 PM |
