02-03-2012, 08:18 PM | #121 |
I wanna be Dave Join Date: Nov 2008 Location: Chillin in Utardia
| Re: cbp27's Defender 90 Build
Very cool color |
02-05-2012, 09:46 PM | #122 |
Rock Crawler Join Date: Jun 2010 Location: Colorado Springs
Thanks! I'm happy with it too |
02-06-2012, 12:41 PM | #123 |
Newbie Join Date: Dec 2010 Location: 30 feet below sea level
Nice colour. What motor do you use? Cause your Gelande seems to be pretty fast.
02-06-2012, 03:34 PM | #124 |
| Re: cbp27's Defender 90 Build Thanks Ikke. It has a HPI 15T Firebolt motor right now. I originally put a Holmes Torquemaster 45T but that was way too slow for me. The Firebolt was the only other motor I had laying around. And with the Axial SCX10 tranny and RC4WD Disruptor transfer case I still get plenty of low end torque. Once the HPI dies I may go for another cheap motor in the 15-20T range.
02-06-2012, 04:05 PM | #125 |
Well, today was a beautiful winter day with warm temps and I couldn't resist going outside. I slapped the lights and grill on the D90 and took it outside for some photos. I can't believe how great it looks even without all the windows and stuff! Hope you guys think the same! |
02-06-2012, 04:20 PM | #126 |
RCC Addict Join Date: Oct 2008 Location: PA
Looks awesome all together. Did you decide to wet sand and polish or just leave it?
02-06-2012, 08:27 PM | #127 |
| Re: cbp27's Defender 90 Build |
02-06-2012, 09:29 PM | #128 |
02-06-2012, 09:51 PM | #129 |
After some good rock rash you will never know. |
02-06-2012, 10:16 PM | #130 | |
Rock Crawler Join Date: Jan 2011 Location: Port Saint Lucie
| Re: cbp27's Defender 90 Build Quote:
02-07-2012, 07:53 PM | #131 |
| Re: cbp27's Defender 90 Build Cool, I'm itching to finish this thing. lol Yeah I can't wait to take it on the trails! Thanks! I like the gray too. I'm hoping to have it all buttoned up within a few weeks. |
02-07-2012, 08:32 PM | #132 |
Rock Stacker Join Date: Jan 2011 Location: DG
I like that metallic grey mate I am always fascinated with Defender builds like that, I also have the same tire and wheel combo on my D110, For that simplistic tire design, its amazingly climb well |
02-08-2012, 09:24 PM | #133 | |
| ! Quote:
Today I had some spare time to start playing with the stainless steel tubing I got from McMaster. I practiced bending with a piece of brake line from the auto shop first. haha After messing with the brake line I thought about giving up. The brake line has a special coating on it which makes it kind of slippery on the bending tool. But, I kept going and the stainless steel was a lot easier to work with. No slippery coating and it's a little firmer. Much better! I made the top rack loop a little shorter and narrower to give it a more streamlined look. And then added some 10mm screws and tape for a mock up. I think I'll make it even shorter. Safety Devices makes a lot of great products and I really like what they have for the Land Rovers. This is my inspiration! I've been wanting to get some MadDogRC lightbars for a long time. I'd love to get a pair of 2" bars to match this truck, but they're too expensive so I might just get one 5" bar. Now I need some smaller tubing/rod to fit in the ends to make the joints stronger. Also need to get some Safety Silv 45, map torch, and a lot of luck! lol | |
02-08-2012, 10:45 PM | #134 | |
| Re: ! Quote:
02-09-2012, 10:34 PM | #135 |
Quarry Creeper Join Date: May 2010 Location: Los Angeles
Fantastic build. A D90 build is in my future for sure
02-09-2012, 10:42 PM | #136 |
As far as those light bars they are made using SMD waterproof black backing adhesive SMD 5050 LED strips with plastic housings. The housing could VERY easily be replicated using sheet metal or any material really. IMO those are WAY overpriced for what they are made of. A price point of $15 is more realistic. I can buy a 15meter roll of those LEDs for $25..... Make your own I'd be glad to help. Heres one of my quads with the SMD 5050s. That company is raping customers for a 3-4" stip and a plastic enclosure at that price. http://www.ebay.com/sch/i.html?_nkw=....c0.m270.l1313 They run off 3s/12v |
02-09-2012, 10:45 PM | #137 |
Not to mention they use white strips not black, which would look much better when the lights aren't lit. ;)
02-11-2012, 08:21 AM | #138 |
Can you just cut those light strips to length?
02-11-2012, 11:40 PM | #139 | |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
The housings are CNC'd out of 6061, hard anodized and potted with epoxy. As far as the LED's, they are more expensive (and brighter) than standard strip LED's, the color temp is 6500k pure white and are 5100 lumens. Wire is the best high strand count available. The housings are also made in small quantities so the cost is higher than a larger production run. Just thought I'd give you the correct information about our overpriced lights that we are raping our customers for. Last edited by chino63; 02-11-2012 at 11:43 PM. | |
02-11-2012, 11:53 PM | #140 | |
Tags |
1.55, d90, defender, land rover, mtz |
