11-16-2008, 09:43 PM | #141 | |||
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Yeah......got started way back in the 4x4Wire days....... http://www.4x4wire.com/feature/rokclod/ ....though this hobby has come light years in recent years and all the new parts are great. More coming all the time. Quote:
http://www.montanascaledesigns.com/s...products_id=63 Time for a few new pics. Got the 8 cells mounted on the floor, floorpan, firewall, and seats. Jay | |||
11-16-2008, 09:54 PM | #142 |
RCC Addict Join Date: Dec 2007 Location: Calgary
that looks so good with the floor installed. Nice and clean looking. Great work |
11-17-2008, 08:41 AM | #143 |
| such a clean build |
11-18-2008, 12:40 AM | #144 |
RCC Addict Join Date: Feb 2007 Location: sweden
That looks really sweet, cant wait for more!
11-18-2008, 01:11 AM | #145 |
Quarry Creeper Join Date: Nov 2004 Location: Fenton, MO
Absolutely stunning work sir!
11-21-2008, 08:46 AM | #146 |
Pebble Pounder Join Date: Jul 2007 Location: little rock
bump..... any updates???????????
11-22-2008, 11:01 AM | #147 |
RCC Addict Join Date: Jan 2007 Location: San Jose
could you explain how you made the panels for the interior where the seats are mounted? Thanks. nice job for sure.
11-22-2008, 04:21 PM | #148 |
Quarry Creeper Join Date: Feb 2008 Location: Quincy
Beautiful work cant wait to see more pics |
11-22-2008, 09:26 PM | #149 |
Quarry Creeper Join Date: Aug 2004 Location: Pacific
Look's sweet,Jay.Great build-up and fab-work pics. |
11-22-2008, 10:52 PM | #150 |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
This is stunning work. True craftsmanship. I do to. I'd love more info/photos of the setup. I've been thinking of something similar on the charity montero build but thought I'd need the entire tranny housing at the motor end. Looks like I'd just need the bearing/shaft for the spur gear, or am I wrong? more info please... [I did read about some gear reduction on page 5 but not sure how that fits in here exactly]. p- |
11-24-2008, 11:25 PM | #151 | |
Thanks guys. Quote:
two holes in each seat base. Seats are held to the floor with two 3mm screws in each seat going into 3mm tapped holes in the floor sheet. Is that what you're asking? Jay | |
11-24-2008, 11:38 PM | #152 | |
and screws to the mount plate. I thought I might need a special shaft (cannabalized axle or driveshaft of some short) for the spur shaft but ended up using a slightly modified 5mm socket head cap screw. To that I added a spur hub, spur gear, 5mm nut and a driveshaft cup fits on the end and secures to the 5mm bolt that has flats cut on it. Hope that helps. Jay | |
11-25-2008, 10:19 PM | #153 | |
How did you shape or cut the floor panel in the first pic behind the seat? thanks again for the help! | |
11-25-2008, 10:30 PM | #154 | |
The firewall is thinner (maybe 0.020") aluminum. I simply used my hand to carefully bend it over the edge of a metal filing cabinet I have. The floor pan was cut using a small vertical bandsaw, but could be done with a hacksaw. Finished up with a file or two. Jay | |
11-27-2008, 12:25 AM | #155 |
sweet rok. thanks again.
11-27-2008, 06:31 AM | #156 |
pics pics pics pics pics pics!!!!!!!!!!!!!!!!!!!!!!!! how is it going got that body going i gotta see this all together. great job so far. great build up. |
11-27-2008, 09:51 PM | #157 |
Quarry Creeper Join Date: Oct 2008 Location: fullerton
this is the best scale build ive seen yet. i like all the creativity via the mototor mout location and the steering, fuel cell. how did u come up wth these?
11-30-2008, 10:53 PM | #158 | |
I knew I wanted the motor moved out of the cab to make room for seats and the batteries, so decided to put it under the hood where it would normally be and just built a little driveshaft to get power to the tranny....pretty simple. For the steering, I didn't want the servo on the axle but tucked under the body. Made up a simple setup that sorta resembles a steering box and pitman you might find on a typical crossover steering setup. Fuel cell just made to resemble a typical steel box cell. Jay | |
11-30-2008, 11:11 PM | #159 |
RCC Addict Join Date: Apr 2008 Location: Georgia
impressive rig where did you get the red springs that are on the tlt shocks?
12-01-2008, 03:20 AM | #160 |
Hey Rok, on post 121, pic 1...., Is your steering setup like the bell crank setup for hilux/f350.? How did you make the pitman arm (i.e., gray piece) on bottom? what is the piece on top (black plastic piece)? thanks a lot! |
