12-12-2008, 10:46 PM | #41 |
RCC Addict Join Date: Mar 2007 Location: Penngrove
Finally an update and some modifications... I couldn't stand the sloppy steering and shifting so I decided to ditch the stock bell crank steering infavor of crossover. I reused the stock drag link by shortening it and threading the cut end with a M3 die. For the shift linkage I used the a shortened stock tie rod and the brass 5mm ball ends from the kit. I had to space the servos 1/8 so that the aluminum servo horns cleared the bottom of the chassis I decided to the lift the trans so a move the battery was in order. First I flipped two of the stock crossmembers Then I built a stop out of delrin so the battery dosnt slide forward and used a traxxes battery bar and more delrin blocks for the rear bought two new 5000mAh 2S LiPo, they had a black plastic case so once I remove the sticker they willl be stealth more to come... |
12-12-2008, 11:08 PM | #42 |
This is my first time seriously wiring LED's on a cralwer so I decided to buy a bunch of super high intensity LED's off ebay, they came from Honk Kong and with resisitors for 12V. I picked up some 150 Ohm resistors to work with my new 7.4V LiPo. I started with the switches for the LEDs', the perfect place to locate them is the space where the steering servo once was. More Delrin and some 80 thou PS... I built the harness using 22 AWG wire from radio shack and mini Dean's connectors For the cab I used two 5mm-50,000mcd and four 3mm-7,000mcd LED's. Two of the 3mm LED's I painted with Tamiya clear amber colored paint same for the bed but also painted the 5mm LED's with clear red installed: fog lights: also cant forget the trailer lights.... Last edited by Mad4Rnr; 12-12-2008 at 11:41 PM. |
12-12-2008, 11:42 PM | #43 |
Quarry Creeper Join Date: Jan 2006 Location: lehi, Ut.
that Tundra is sick!!! nice work so far keep the pics and progress coming |
12-13-2008, 03:29 AM | #44 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
Looking good. Lets see those lights lit up. |
12-13-2008, 04:25 AM | #45 |
RCC Addict Join Date: Feb 2007 Location: sweden
Love that color! A really clean build.
12-13-2008, 04:31 AM | #46 |
Pebble Pounder Join Date: Jul 2007 Location: SinCity
Nice rig!! Can't wait for a chance to get just the body...
12-13-2008, 08:56 AM | #47 |
Rock Crawler Join Date: Jan 2008 Location: Cotati
Looking awesome man. Can't wait to see it lit up.
12-13-2008, 10:56 AM | #48 |
Ask and you shall recieve I picked up some Tamiya 4mm clamping wheel hex's to narrow the track width by almost 6mm. I think the slot where the cross pin goes is deeper than normal. When I wired three LED circuits I made it so the first switch operates the marker and tail lights: The second switch is for the head lights only: And the third one is for the fog lights: I made it so the rear turn signals and revese lights turn on with the fog lights so that its full bright (will light the whole garage) I think I got camera happy, been up to midnight ever night this week tweakin on the truck, cant wait for the trailer, drawing up plans next... |
12-13-2008, 11:46 AM | #49 |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
that tundra is BADASS! love the light setup |
12-13-2008, 01:50 PM | #50 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
That's a sweet truck. Is there more clearance now between the axle center section and the ground or does it just look that way with those wheels and tires?
12-13-2008, 02:05 PM | #51 |
Nor-CalRCRC Join Date: Dec 2006 Location: Monterey Peninsula
Looks great. We'll have to get a night trail ride together sometime now that my JK is done.
12-14-2008, 01:46 AM | #52 |
RCC Addict Join Date: Feb 2008 Location: Nevada
Sweet tundra, that gun metal paint job just sent it right over the top very nice! |
12-26-2008, 06:03 AM | #53 |
Newbie Join Date: Nov 2008 Location: belgium
Wow i like the lights the truck to btw :-P Nice job ^^ |
12-28-2008, 12:31 AM | #54 |
RCC Addict Join Date: Nov 2007 Location: CALI "209"
really nice work, gun metal is sick!!
01-11-2009, 08:14 PM | #55 |
Thanks for the comments everyone, a small update for you; I started on the trailer by cutting some 1/2" x 1/2" x 1/8" steel angle iron. I wasn't sure what material to make it out of but thought that this would be strong as all-get-out and i can weld it with my millermatic 210 . The outer dimensions of the bed are 9.5" x 21.5 so with the wheels and fenders overall width will be 11.75". Picked up this hitch from fleabay for 20 some-odd bucks: Its made from Delrin so I may rebuild the cross bar and just run the hitch and ball I made these from Hi-lifts leafs, not sure how they will hold up, we will see Also so more info on the paint since I've been asked a couple time: After tamiya primer I shot the underside, bed and window trim with Tamiya Semi-gloss black number TS-29: http://www3.towerhobbies.com/cgi-bin...0&I=LXRS41&P=K Then I masked the bed and windows and used Tamiya Gunmetal Gray number TS-38: http://www3.towerhobbies.com/cgi-bin...0&I=LXRS70&P=K To finish off I clear coated the body color only with this: http://www3.towerhobbies.com/cgi-bin...0&I=LXRS31&P=K |
01-11-2009, 08:38 PM | #56 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
This is one of the cleanist Tundra builds I have seen so far. Nce work.
01-12-2009, 12:30 PM | #57 |
Pebble Pounder Join Date: Nov 2008 Location: Hamburg, MI
ill take it thanks for the chance really good looking rig super scale looks like somthing i would see around my area
01-20-2009, 04:09 PM | #58 |
Newbie Join Date: Jan 2009 Location: milton
can't wait to see more |
01-20-2009, 04:22 PM | #59 |
Quarry Creeper Join Date: Oct 2008 Location: Rochester Hills, MI
Looks good I like how bright the lights are.
01-20-2009, 04:26 PM | #60 |
Looks good. I might do a truggy with that body.
