01-20-2009, 05:14 PM | #61 |
RCC Addict Join Date: Mar 2007 Location: Penngrove
thanks guys for the comments I have some fender flares from RPP coming in the mail and need to get some progress done on the trailer...too many projects (I currently have 11 rigs) |
03-22-2009, 09:29 PM | #62 |
Not realy an update but been debating what to do with the fender flares. I'm not really a fan of the pockets for the screws so I think I'm going to fill those in with body filler. Then I'm either going to paint the flares semi-gloss black or the body color, what do you guys think? |
03-22-2009, 10:12 PM | #63 |
Quarry Creeper Join Date: Nov 2007 Location: nanakuli
go with body color, it'll look sick.
03-23-2009, 08:58 AM | #64 |
Newbie Join Date: Sep 2008 Location: China
I totally agree, go with the body color. Also, your truck looks very clean without the front bumper and roll bar, i think the screw holes don't match your overall look. I'd fill them up. That's just my opinion though, any which way, your truck looks awesome!
03-23-2009, 05:08 PM | #65 |
Quarry Creeper Join Date: Dec 2007 Location: a place where everything looks the same. oh and no rocks.
ill be deffinitly adding this to my list of best tundra's.awsome job man. perfect resemblance(spl) to a 1:1. nice work |
05-03-2009, 10:52 PM | #66 |
Rock Stacker Join Date: May 2009 Location: San Francisco
Wow I really like your paint and wheel tire combo. Where did you get your battery from??
05-13-2009, 09:42 AM | #67 |
| Updates?
Mad4 any updates on your rig?
05-13-2009, 11:58 AM | #68 |
yes, hopefull very soon I started painting the fender flares and also strted working on the trailer again. I need to get it finished by the 21st of June for a scale GTG we're having |
06-13-2009, 08:10 AM | #69 |
Pebble Pounder Join Date: Jan 2007 Location: Bulgaria, Sofia
How is this thing coming along, man? |
06-13-2009, 09:59 AM | #70 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
Damn, I wanted to vote for flat black on the flares. This thing is sick, but needs some tube work. Or maybe some Ruenell bumpers or something
06-13-2009, 11:37 AM | #71 |
Quarry Creeper Join Date: Aug 2008 Location: iderho
I would have said black too. Matches the wheels and makes them stand out. Clean tundra man, keep it up |
06-14-2009, 07:54 PM | #72 |
Fender flares are done, filled the holes and painted same color as the body, looks alright. I need to get the trailer done then some more mods to follow |
06-15-2009, 05:05 PM | #73 |
I'm loving the looks of that tundra + those rims and tires + the fender flares :OOO What were those rims again? EDIT: Just did a closer inspection on the mini deans that u did on your LEDs.. So u did common ... cathode (-) or was it anode ... :takes a quick look in wiki: .. common cathode Nice.. would have never thought of that ;) Last edited by ccbg; 06-15-2009 at 05:10 PM. |
07-07-2009, 12:32 AM | #74 |
I recently was lucky enough to get a 1.9 Campbell rock racer chassis from ecoli at MFF. This will finally give me have the motivation to finish this as a true tow rig. First here is the build thread of the rock racer: MFF Campbell Rock Racer now some fun with a RC4WD transfer case...mmmmm: |
07-07-2009, 11:49 AM | #75 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
Keep'em coming man, this build is looking nice! |
08-02-2009, 10:48 PM | #76 |
| major trailer update...
Well getting the campbell buggy almost complete has made me motivated to get the trailer functional A couple months back I cut up a bunch of 1/2" x 1/2" steel angle for the side and front/back rails. I since then I decided to shorten the trailer to 20.25 inches so I cut the side rails and then cut the cross braces from 1/2" x 1/8" steel flat stock. I used some 1/2" x 1/2" box for the tongue and some strips of 1/2" expanded steel for the deck My MIG skills is rusty The last couple months I've also been gathering all the suspension and axles parts. I have Hilift springs that I bent eyelets in along with some lower helper springs, I also got some RC4WD brass 12mm hex bushings. These will spin on 3/16" steel rod treaded M4 on ends for the sxle nuts. I will use landing gear collars to hold the other side of the hex's. I bent TLT steering rods for U-bolts and will use TLT bracets to hold the outer ends of the leafs For the inner end of the leafs I made some cantilever shackels Drilled some holes for the brackets and cantilevers Suspension mocked up the cantilever seems OK in single sheer, no bindage with out a load |
08-09-2009, 12:53 PM | #77 |
The axles for the trailer are 3/16" solid steel rod that I threaded with a 10-32 die. The brass bushing is from RC4WD and I used 3/16" RCplane wheel collars. To make the springs and u-bolts work with the axle I fab'd a small plate from 1/8" Delrin. All bolted up, it's a strong set up I'm using HPI stockcar wheels and soft tires, I think they are the radials... All assembled |
08-09-2009, 01:29 PM | #78 |
Quarry Creeper Join Date: Aug 2009 Location: Syracuse
Nice Truck!!! But one Q are you hooking up the LEDS for the trailer with a seperate batt source or is it gunna be powered by the truck? |
08-09-2009, 01:34 PM | #79 |
Once the trailer was rolling I had to figure out how to mount the tow hitch on the Tundra and still allow the bed to tilt for battery access. I decided to use a piece of 2" x 2" x 1/8" think Al angle stock. It replaces the small angle bracket that came with the kit. I will ditch the Delrin tow hitch soon so I getto fab'd the small brackets Its tight to the bumper which is cool for clearance but it will need a huge drop hitch... I hook up the trailer I had to use a 1" long piece of delrin as a "drop ntoungue" I think I will have to make a nice metal drop hitch and get rid this POS It works for now, later I wil make some fenders and taillight /license plate mount |
08-09-2009, 11:36 PM | #80 |
RCC Addict Join Date: Aug 2006 Location: ****, SL,UT
that is sick!
