06-03-2010, 10:07 AM | #61 |
| Loving all the details you keep adding to it |
06-04-2010, 01:20 AM | #62 |
Newbie Join Date: Dec 2009 Location: Saint Louis
Well today i found this add on craigslist for a used HL that comes heavily modded but also includes the parts to convert it back. he was asking $600 but i got him down to $450. what do you think guys? good or no? http://stlouis.craigslist.org/for/1766934338.html |
06-04-2010, 11:29 AM | #63 |
Rock Crawler Join Date: Jun 2006 Location: Wisconsin
I think that is a fair price, as he has a lot of money tied up in that truck, even if you don't like the 4 linked suspension. A complete new body kind of sweetens the deal too. Maybe squeeze him for $50 more off, but $450 is not bad. What are new Highlifts selling for now? $409?
06-04-2010, 12:09 PM | #64 | |
06-04-2010, 10:50 PM | #65 |
Got the opportunity to add a little more detail to the front bumper! What good is a winch bumper if it doesn't have a little extra lighting for the late night drives? Bored a couple extra holes in the bumper and installed some Axial light lenses. No buckets behind them. Just some shallow holes to allow a somewhat press fit of the LED. I couldn't wait to see them lit up, so I wired up some test LEDs and put some power to them. The small lights are fog/driving lights. The larger, off road lights. Notice a little difference in the color of the light. I went for the off road HID look and standard incadscent bulbs for the fog lights. I think I will do the same for the high and low beams. Last edited by Espeefan; 06-04-2010 at 11:05 PM. |
06-05-2010, 12:43 AM | #66 |
06-05-2010, 10:39 AM | #67 |
Rainey, if you are serious about scale crawling, I would steer you to an SCX-10 chassis, and tell you to mount a Tamiya F-350 body onto it. That would be an ideal platform to start working with, and it wouldn't really need much work at all to be more capable then a Highlift. Even a 4 linked Highlift can't compare. The Highlift is more of a daily driver, occasional off road trail truck. I got tired of looking at the Highlift in pieces today and decided to halfway assemble it so I could see what it might look like when it's finished. This is the first time I've actually had it back together, to the point where it is a complete truck again, and after all the work I have put into it. I couldn't wait to see what the grill, hood, and front bumper would look like, working together! I also threw the box back on the chassis. It looked pretty good, so I snapped some outdoor photos. The lighting just isn't the same down in the basement, and on the workbench! The bed is pretty much taken care of now too. The 5th wheel ball hitch turned out exactly the way I wanted it to. Nice and beefy, but only the ball is exposed in the box. The ball actually holds the box on, and I was able to keep the stock hinges in the rear for battery changes or maintenance, although I did have to mill them shorter (since doing the bed drop lowered the whole floor, giving the box a lift). I can't wait to get this thing done! Then I might start on a trailer! |
06-05-2010, 11:40 AM | #68 |
Rock Stacker Join Date: Mar 2006 Location: Las Vegas
Sick looking truck.......... |
06-05-2010, 12:24 PM | #69 |
ok so i talked to the guy with the craigslist add again. i got him down to $400. i think i'm gonna have to buy it, lol
06-05-2010, 12:38 PM | #70 |
have you put any thoughts innto some kinda exhaust? like maybe dumps or stacks
06-06-2010, 08:17 AM | #71 |
Rock Crawler Join Date: Jul 2008 Location: E. City
I have to tell you man, that front end looks sick! It really looks good put together, the grill looks awesome! My only suggestion is to round off those shackle mounts. Other than that, I'm jealous. I also agree with redneck rainey, needs some exhaust. Maybe some dumps just in front of the rear tires? |
06-06-2010, 12:22 PM | #72 |
Rock Crawler Join Date: Jan 2009 Location: Jacksonville FL
what color you gonna paint it
06-10-2010, 11:50 AM | #73 |
Thanks guys! Glad you like it so far. Don't Slow Down, yeah, I thought about rounding the d-ring mounts a little too, but I'll have to see if I can get to it. For now, they still came out pretty nice! Well, for today's update, I finally have the bumper done. The biggest challenge with the bumper was getting a working winch on it. There really isn't much room anywhere on the truck for a winch, but I found a spot for it. Naturally, I had to machine up some more parts to make it work, but it sure did turn out well. The first thing I had to do was ditch the stock mounting plate and rollers. Didn't really need the rollers anyway. I machined the new ones for the front of the bumper. I machined an opening for the cable to pass through. The bumper also had the same sized opening machined into it. View from the underside, showing the roller I had to make to help the cable make a 90 degree turn and head out the front of the bumper. The roller has a large taper to it, to help keep the cable centered on the drum. It works awesome. I can pull the cable to the left or right, and it still wraps on the center of the drum. The roller mounts tie into the winch plate up top. Basically they sandwich the bumper. One more from below. Also, the pockets, in case anyone is wondering, are relief cuts to clear the leaf spring shackles and the front cross member of the chassis. When it's all together, space is tight, but the winch does fit under the hood, and beind the grill. Like a glove! The best part is, I now have working winch! Scratch off one more thing that is on the to-do list! The rest should be easy! I put more time into this bumper, then the whole truck I think! And for those mentioning exhaust, it will have dual stacks in the box. Diesel power! Last edited by Espeefan; 06-10-2010 at 12:01 PM. |
06-11-2010, 02:27 PM | #74 |
| I got the highlift!!!!!!! first thing i did was thake the 4 link setup off and returned it to leaf springs. the 4 link was a bit much, and far too top heavy.
06-11-2010, 02:37 PM | #75 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
i like that winch setup alot great job
06-11-2010, 03:06 PM | #76 |
Quarry Creeper Join Date: Sep 2009 Location: Marengo,iL
nice ford where are you in Wisconsin
06-11-2010, 04:57 PM | #77 |
That winch location is pretty sweet and the machine work is clever. I wish I had the tools to make stuff like this. Nice job Are those shackles the RC4WD ones? I was looking at some for my Tundra but thought they looked a little big. Last edited by dont slow down; 06-11-2010 at 05:00 PM. |
06-16-2010, 03:44 PM | #78 |
any updates yet?
06-17-2010, 11:02 PM | #79 |
Newbie Join Date: Dec 2008 Location: hillsboro
that bumper is amazing!!!
06-24-2010, 02:30 PM | #80 |
You still alive man?
