Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Szczerba's F-Toy #744
Old 05-05-2012, 11:54 AM   #61
Default Re: Szczerba's F-Toy #744
Originally Posted by dirk379 View Post
Turning out great, i think the interior works fine for the rig. It's probably a combo of leafs f/r, tires/wheels, and yota axles that makes me like this vs other f-toys. I love drivin full leaf'd scalers, they're a blast. Great build.
Yep, just enough pass for a scaler
Originally Posted by Manning View Post
It's very cool. I can't wait to drive it!
Ok, ok, You can drive it.
I have used these Hillman collar weights on other trucks. Heck, I am running them on my 2.2 berg comp truck and my 2.2 shafty comp truck. These were $6.99 each.
I knew I was going to the hardware store today, so I took a yota steering knuckle with me. These 5/8" collars work perfect for the front of my yota axles. 1.8oz each.
No modifications needed. Clamp right to the knuckle. I am running SLW modded 1.9 axial beadlocks. I have an extra set of non-modded SLW 1.9 axials if anyone needs me to check.
Can't get much easier than this!
Szczerba is offline   Reply With Quote
Old 05-05-2012, 04:36 PM   #62
Yes please check the un modded rims!!
Btw great build!!!
Yaeger is offline   Reply With Quote
Old 05-05-2012, 04:47 PM   #63
Old guy
ROCKEDUP RICKY's Avatar
Me too, I want to see how much air I can get. Sweet rig by the way.
ROCKEDUP RICKY is offline   Reply With Quote
Old 05-05-2012, 08:26 PM   #64
Btw great build!!!
Stock 1.9 Axial un-modded beadlock fits just fine. No issues. Don't think there will be any problems with most wheels.
As the weight does not go past the the end of the knuckle. Almost like they were made for these weights.
Thanks. It's not much of a jumper but we can try.
Old 05-06-2012, 08:25 PM   #65
Changed up the front shock rod ends to a touch longer and shortened up the outer shock limiters. Got a little more flex out of it. Need to get some Losi extra long rod ends for the rear shocks. Busted one at ECC and still haven't fixed it.
Changed up the front foams to one 1/2" non memory foam star cut foam slice with two 1/2" thin slices of 2.2 memory foam on each side. Ran this before in another 1.9 rig and it worked good. Still stock foams out back.
Shaved the side lugs down and shaved the lugs down a little.
Found some numbers and going to see if they grow on me. Not sure if I like their design.
1.8oz each knuckle weights might not be enough. I was running 2.0 oz in each front wheel before. Definitely woke up the front end wheel speed. Might find a way to throw some more weight on the knuckle weights or axles somewhere.
Couple late evening poser shots after a 1800mah run.
Rear traction bar is next on the to do list.
Old 05-06-2012, 08:46 PM   #66
WOOPOOW!!
F-toy keeps getting better Shane! Wish I would have had a scaler with me at ECC, I really wanted to run with this thing
Colby is offline   Reply With Quote
Old 05-06-2012, 08:53 PM   #67
Thanks. I was too busy on Friday with the 2.2s class to run in the scale dash. I had to replace the front gears while I was there too. But I have been driving it a hole lot the past few days.
Either shaving the rok lox down or going from 2.0oz wheel weights to 1.8knuckle weights worsened the vertical climbing. Got to figure out what is going on.
Researching traction bar setups now too.
Old 05-09-2012, 08:47 PM   #68
I really like driving this rig!
I've been putting a 1800mah lipo through it almost every night for the past 2 weeks. Super technical driving required with small tires and leaf springs.
Finally snapped a front dog bone pin tonight. Wasn't paying attention and got a front driver bound up and click, click, boom! Good excuse to order some XVD's.
After I shimmed up the ring and pinion gears, all is good with those gears.
1.9 Pitbull tires on the way with some nice MTHead beadlock rings as well. I'll have to mod a second set of 1.9 axials for the slw hubs.
Sanded the side lugs down a bit and siped the front tires.
Since it's down right now. I will try to get the traction bar(s) built this weekend. Rear leafs are getting warped and I am loosing traction from the axle twisting up out back upon acceleration.
Old 05-09-2012, 08:56 PM   #69
so how much did you pay for the chassi if i may ask?
grunt95 is offline   Reply With Quote
Old 05-09-2012, 09:01 PM   #70
Rpphobby had them on sale for $185 a couple months ago and I decided to pick one up. Just the "topper" part. Looks like RPP no longer carries these. Guess they sold out. I think with no plans of Reign making any more mass produced.
I had to modifiy it to work with the leaf spring setup. It was made well. I dump it on its lid at least once a crawl session.
Reign RC SCX10 F-Toy bolt on cage.
Old 05-11-2012, 07:56 AM   #71
Got some 1.9 Pitbulls on 1.9 axials with some MTHead rings. Wheels will get the SLW mod treatment as well.
New XVD's are in the mail.
Old 05-12-2012, 08:50 PM   #72
Modded a second set of Axial 1.9's to accept SLW hubs. 350's on there since the pit bulls are a little wider.
New foam setup in. A mix from the foam bins.
XVD's where supposed to be here this morning but got delivered to the wrong post office.
Old 05-16-2012, 08:50 PM   #73
The pitbulls are really waking this rig up. Finally got a good foam combo in them.
Fronts = super firm inner prototype/leftovers from CrawlerInnovations foam pile with pitbull outers.
Rears = HPI Mini Trophy truck 1.9 stock foams with PitBull outers
Works awesome though.
Added small helper springs to rear leaf to tone down axle wrap until I can fab up the traction bar. Going to steal TommyR's design.
Weighed it tonight. 6lbs 4oz
Old 05-17-2012, 07:48 AM   #74
looks nice shane!
pitbulls look good on there,as well as your mod'd wheels.
boy usps has been sucking it up here lately..
my Ti steering link..
ashtons motors..
your xvds..
its a conspiracy i tell ya!
ROLANDROCKSHOP is offline   Reply With Quote
Old 05-18-2012, 11:36 AM   #75
Digging the look and progression of this rig, I have checked back a few times. Good stuff. The color weights are a nice find for sure....I will have to try those
Desert Rc is offline   Reply With Quote
Old 05-18-2012, 11:44 AM   #76
Originally Posted by ROLANDROCKSHOP View Post
looks nice shane!
ashtons motors..
your xvds..
Yea. it's happened to me before. The parts were in the next day though.
Got the XVD's installed and they work good. Already had a small 5x8x2.5 bearing junk out inside the axle. Ordered some "goot" ones.
Thanks.
I was thinking of swapping beadlock rings cause the pit bulls work 200% better than the rok lox. Athough I have a new uninstalled set of Crawler Innovations Lil' Nova 1.9 Dual Stage 4.50T Foam Pair (2) for the rok lox.
I added about 1.5 oz to each wheel on the pit bulls to see if it helped. The pit bulls were grabbing better, so I really didn't need it. I ended up pulling the knuckle weights off. I need to remove the wheel weights and add the knuckle weights back on.
I am halfway done with the rear traction bar. Just need to do some more head scratching to get it mounted to the axle. I used half of a 1/2" collar to make it as well.
Old 05-18-2012, 05:24 PM   #77
I want to drive this thing.
Manning is offline   Reply With Quote
Old 05-18-2012, 11:17 PM   #78
1.55's ? Yes.
Night driving at RolandRockShop ORV is a challenge.
Old 05-19-2012, 07:39 AM   #79
day time shot with 1.55". alot of fun to drive with these tires. Name:  ImageUploadedByTapatalk1337434786.165831.jpg
Old 05-19-2012, 07:48 AM   #80
Looks awesome with those tires
OKJeepin is offline   Reply With Quote
Szczerba's F-Toy #744 - Similar Threads
Szczerba's FF-SZ 2.2s Szczerba Axial AX-10 Scorpion 389 06-11-2013 08:30 PM
Szczerba's JK (Minus some doors) Szczerba G-Made Crawlers 193 11-06-2012 07:26 AM
