10-03-2013, 10:07 AM | #21 |
Pebble Pounder Join Date: Sep 2010 Location: Santee
| Re: myth619's spare parts TJ build Thanks. I'm not sure what I'm going to do yet. I have a couple ideas but they will depend on if I run a spare tire or not. If i run a spare the mount will tie into the rear part of the cage. If no spare I'll just do a simple box bumper.
10-04-2013, 03:45 PM | #22 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
Man this thing is taking shape. I'm liking everything from the cage to the boatsides to the front bumper. Sub'd |
10-05-2013, 12:02 AM | #23 |
I decided to put a spare tire on this rig. Just not sure at what angle to mount it at. I want it as low as possible for the best COG. These are the two best options I can think of. I like the look of the traditional vertical mounting but it gives a bad departure angle but I like the departure angle of the 45* mounting. Give me you opinions. Thanks Last edited by myth619; 10-05-2013 at 12:20 AM. |
10-05-2013, 12:03 AM | #24 |
| Re: myth619's spare parts TJ build |
10-10-2013, 04:10 PM | #25 |
10-10-2013, 04:22 PM | #26 |
And finished off the front bumper Winch hook loop soldering on the fairlead mount fairlead mount done, fairlead mounted, winch mounted I know the spool on the winch is off center and looks weird but I didn't want the winch motor hanging off the side of the bumper. Found some batteries that will fit on the boatsides. All the fab work is done and now its time to tear it all apart, paint every thing, find all the correct hardware to assemble it all and put it back together.. |
10-10-2013, 05:43 PM | #27 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
your metal work looks very good. the jeep is turning out great. |
10-10-2013, 11:11 PM | #28 |
10-10-2013, 11:30 PM | #29 |
I got my work area cleaned up ready to start the tear down That last time it'll be assembled until its painted 20 minutes later..... I know this is usually done at the beginning of the thread but since I was collecting parts as I went I didn't know what I was going to end up with. Parts list: New Bright 1/10 TJ Body Modified SCX-10 Chassis Stock SCX-10 Shock bodies w/ Proline springs (front) Proline Power Stroke Scalers (rear) Fabricated CMS Fabricated 3 link/ track bar mount(front) 4 link rear(using Axial 4 link axel truss) Stock SCX-10 Axels (wheel nut to wheel nut) Stock Axial Trans GCM Transfer Case A mixture of Axial and Traxxas drive shafts and u joints Stock SCX-10 Wheels and Bead lock rings (for now, hopefully some MTHead rings will be purchased before final assembly) 1.9 Proline TSL Swampers 1.9 Proline Flat Iron(spare) HH BRXL HiTech 645-MG Traxxas Link 2.4 RX 55t Venom Motor 20t pinion 87t spur (2) 1300mah 3s in parallel |
10-14-2013, 10:49 AM | #30 |
Proline TSL Swampers mounted Painted and weighted the wheels. Put 7oz on the fronts and nothing in the rear. |
10-14-2013, 10:53 AM | #31 |
Got the fab work painted ( other patrts not shown, im bad at taking pics) |
10-14-2013, 10:56 AM | #32 |
Fully mounted the GCM T-case |
10-14-2013, 10:59 AM | #33 |
I got on a major role and the next thing i knew it was a roller with the electronics mounted. I ended the evening with having a running chassis. |
10-14-2013, 11:09 AM | #34 |
Pics are a little hard to see, I'll get better ones in the day light. I was going to painted the body yellor but I really like the black on black look. I think I'll be running this one by the weekend. |
10-14-2013, 01:00 PM | #35 |
Rock Crawler Join Date: Apr 2011 Location: SD
Wow myth, this rig looks a lot better without all the decals. Did you paint the body or just remove the stickers? All that awesome look'n cage work you did and front bumper would have probably stood out if you painted another color...but it still looks sweet. If I had any brazing or welding skills I would have started a thread on my YJ. I will just post up pics once it's complete hope i can see you and your Jeep at a gtg soon |
10-14-2013, 01:24 PM | #36 | |
| Re: myth619's spare parts TJ build Quote:
That's the only thing I don't like about the all black. In the day light it should be more defined. The cage, bumper and sliders are a different tone of black then the body.They color may still change. I just haven't found the color(s) that really grab me. | |
11-30-2013, 05:50 PM | #37 |
11-30-2013, 07:20 PM | #38 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
How did you mount the trans , Got any body off pics?
11-30-2013, 07:27 PM | #39 |
| Re: myth619's spare parts TJ build The first page of the build thread has all the fab work pics. I made a mount right behind the passenger side shock mount that the trans bolts to and used a GCM transfer case on the stock Axial skid. Last edited by myth619; 11-30-2013 at 07:47 PM. |
11-30-2013, 08:08 PM | #40 |
So how does that setup work for you , It looks killer.
myth619's spare parts TJ build - Similar Threads | ||||
Myth619's Chero Build | myth619 | 1.9 Scale Rigs | 3 | 04-12-2012 08:35 PM |
Spare Parts Build | thzero | Illinois | 9 | 12-16-2011 09:27 PM |
...spare parts build... | Leprasol | Axial SCX-10 | 14 | 05-25-2011 08:45 PM |
Spare parts build | max power | Non Crawler RC's | 5 | 10-28-2008 01:38 PM |
Spare parts build.... | ddiaz10240 | 1.9 Scale Rigs | 1 | 08-26-2008 11:30 PM |
