10-18-2013, 12:23 PM | #21 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: '49 Merc C2
Great looking ride...not sure I like the spare tire though
10-18-2013, 12:38 PM | #22 |
Quarry Creeper Join Date: Mar 2009 Location: western ny
| Re: '49 Merc C2
Awesome !!!! Hope ya don't mind but I wanna steal your interior idea what did you use as the base to mount all the interior parts on ? Thanks for any help you can give |
10-18-2013, 11:52 PM | #23 |
I wanna be Dave Join Date: Sep 2007 Location: San Tan Valley
| Re: '49 Merc C2 Can't remember the exact thickness but it is just some heavy gauge styrene painted black on the bottom and flat tan on the top. As you can see from the pic it is mounted using the body posts and some additional body clips to secure.
10-20-2013, 06:45 PM | #24 |
| Re: '49 Merc C2
Made my suspension adjustments before the first comp today and was very impressed with the rig, This thing plain works. I finished the day with a -53, next closest competitor was a +39. I'll try to get a few pics up later. |
10-21-2013, 07:43 AM | #25 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
| Re: '49 Merc C2
^^ Yes, it just plain works and looks good to boot. Red wheels, black rings FTW. Diggin the winch hook too, they work ;) One of these days I'll finish all 3 courses and put up something worthwhile. |
10-23-2013, 07:22 PM | #26 |
| Re: '49 Merc C2
Had the day off today so I decided to change out the front bumper. I wanted something a bit more menacing so this is what I came up with. You'll probably notice that I installed some old Hilux headlights. They were in the parts box so I decided to put them to good use. I think they look pretty bad ass in the Merc. I tried to make the lake pipes but I kept crimping the 3/8" brake line I was trying to use. If anyone has a better idea or a better bender and wants to give it a shot I'd be willing to pay for your services. All I'd need is the pipe, I can do the rest. |
10-23-2013, 08:15 PM | #27 |
| Re: '49 Merc C2
Now that's a stinger....don't run into anyone with that....
10-23-2013, 09:38 PM | #28 |
| Re: '49 Merc C2
Video from our comp this past Sunday, first run for the Merc. Celtic Customs rc - YouTube |
10-23-2013, 10:52 PM | #29 |
| Re: '49 Merc C2
Brian, I have a homebrew bender that will bend fairly tight radius. You are welcome to borrow it. Solid rod would be the easy way though.
10-23-2013, 11:12 PM | #30 |
| Re: '49 Merc C2 |
10-24-2013, 07:04 AM | #31 |
| Re: '49 Merc C2
Well, let me know if you want to try my bender.
10-24-2013, 07:56 AM | #32 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Re: '49 Merc C2
Have you tried filling the tube with sand? I know its a pain, but might work with the radius you want.
10-24-2013, 11:28 AM | #33 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: '49 Merc C2
Sand, salt, or even water and freeze it all work to different degrees. If it where me I would go to the LHS and pick up a K&S bender. It comes with 4 pieces of brass. That brass is anealed so it will bend a tight radius. Then p/u some brass tubing from the display center to finish off the length of the pipes along with some flat stock to build the flanges and caps. Brass is super easy to work with and you can solder it with your iron. I think you and I have talked about brass work before, P/U some oatly tinning flux from the hardware store in the plumbing section to ensure a quality joint..... You can aneal the brass tubing from the rack also. Just heat it up to a glow and let it cool by itself. Only reason I suggest the bender combo is it will give you the bender which is a tight radius.Its like 9.00 or so. Last edited by hotwheels000; 10-24-2013 at 11:31 AM. |
10-24-2013, 03:56 PM | #34 |
| Re: '49 Merc C2
Thanks guys!
10-24-2013, 04:24 PM | #35 |
| Re: '49 Merc C2
those headlights look amazing.
10-24-2013, 08:43 PM | #36 |
| Re: '49 Merc C2
Thanks Cory!
10-24-2013, 11:33 PM | #37 |
| Re: '49 Merc C2
So R2j / Shon has offered to make me a set of Lake Pipes. The plan at this time is to make them out of 3/8" stainless tubing. With the stainless I have the option to polish them or paint them black. I quickly bent up a set of 1/4" this evening and didn't like the look of them at all. They were way too small in diameter and I felt they got lost under the body. Here's a pic of pretty much what I'm going for, minus the heat shield. Last edited by bmuzz1; 10-24-2013 at 11:45 PM. |
10-25-2013, 06:24 AM | #38 |
Rock Crawler Join Date: Jul 2011 Location: north little rock
| Re: '49 Merc C2 |
10-25-2013, 07:29 AM | #39 |
| Re: '49 Merc C2
Okay, side pipes then. I was thinking lake pipes like- |
10-25-2013, 07:47 AM | #40 |
| Re: '49 Merc C2
The heat shields as cool as they look will hang up on stuff and the traditional lake pipes are just too small for this rig. This rig is built to look good but I need it to perform just as good as it looks. |
'49 Merc C2 - Similar Threads | ||||
Merc ML500 | colin1986 | Axial SCX-10 | 30 | 12-18-2013 11:43 PM |
rebuilding the merc | bigoggy | 2.2 Scale Rigs | 10 | 04-23-2010 10:48 AM |
merc trail truck | smedo | 2.2 Scale Rigs | 3 | 09-16-2009 06:00 PM |
Merc G tester | raul duke | Videos! | 7 | 04-07-2007 10:38 AM |
Merc Trial Truck | moogie | 2.2 Scale Rigs | 46 | 01-14-2007 03:12 PM |
