10-06-2014, 07:48 PM | #61 |
Pebble Pounder Join Date: Mar 2013 Location: labrador
| Re: Sp3cia1-K's Goat Built Ibex Build
Im thinking of settings the effie up in droop to try combat it being a bit too tall. Also I need a set of those ultra4s! The Trukkracea |
10-07-2014, 07:13 AM | #62 |
Quarry Creeper Join Date: Dec 2011 Location: Gold Coast, Australia
I have had some GoPro issues recently, most of my stuff corrupted and everything I recorded at the Toohey Challenge on the weekend didn't actually record/save. I managed to recover from footage from camping though, tested using my suction mount on the roof panel and camera angled back into the cab area, turned out great with very little vibration! Also a couple other random shots. |
10-07-2014, 06:57 PM | #63 |
Rock Stacker Join Date: Sep 2011 Location: Perth, Western Australian
Nice build Kyle, simple and clean : )
10-07-2014, 07:59 PM | #64 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
Very sweet built and seems to handle nicely when going fast. What motor and ESC are you using? And what cockpit did you use?
10-07-2014, 08:06 PM | #65 |
Thanks guys Motor and ESC setup is a Roc 412 3100kv geared 10/54 I believe paired with a CC MMP on 3s |
10-07-2014, 09:18 PM | #66 |
Oh and it has the cockpit from the HPI Trophy Truck or whatever it is called. It's 1:12 I believe, I have a c1 cockpit but doubt I will be able to make it work due to the second A pillar
10-17-2014, 11:01 AM | #67 |
Pebble Pounder Join Date: Mar 2013 Location: yucca valley,
i absolutely love this truck! definetly gonna chop the rear section up and braze it back together like yours. looks sweet!
03-26-2015, 06:12 PM | #68 | |||
| Re: Sp3cia1-K's Goat Built Ibex Build Quote:
Quote: Quote:
03-30-2015, 08:26 AM | #69 |
Glad I could help Natedog! This is set to be getting some proper updates soon, new rear axle in the works soon, reworking the chassis for better clearances, new panel designs and some custom machined trailing arms made by a local guy near me. Should be good |
04-01-2015, 06:24 AM | #70 |
So I've been meaning update this build for ages, just been enjoying running it myself but it is time that I finally paint the chassis and get some proper panels done up. Around KOH time I was scouring the net looking for Ibex's that competed and found a couple with the one that most took my eye being the JDS Motorsport entry, #4461 driven by Doug Jackson. Although I don't plan on this being an exact replica, I am planing on basing the design and layout on this truck and working my own ideas and sponsors into it. I started with the panels, this time around I'm wanting to go with one piece panels that wrap around the whole truck, a bit of heat from the heat gun helped with this and creates a nice flared arch look. For the time being I won't be going with the 'Jeep' front grill for this one I don't think, will be going for a flat hood design. Following the design and layout ideas from JDS with the exception of the enlarged diamond plate rear, here is how it looks. I simply got masking tape and tore thin strips for the template Note the hole in the hood, I wonder what that might be for... Next to tackle was getting rid of the old chipped and scratched paint off ready for painting, so out came the sheets of sandpaper.. At the same time I reworked the lower tube work on the right hand front for better servo clearance at full bump. I had altered it a while ago but when I brazed it all up I hadn't noticed that it angled in, which in turn hit on the servo horn under full compression. Despite hitting, I made up a ton of clearance anyway so I didn't worry about it. Now that it is being painted, I went ahead and straightened it and raised it a touch more while I was at it. Not overly deserving of a picture but you can see the altered front in the other images anyway. The paint I am using to achieve the metallic/candy red requires a good silver or chrome base to work with so that was the first step. I'll let it dry overnight and shoot the red in the morning. May as well mock up the panels to see how it is looking. And that hole seems to have been filled with something.. By the way, that is an axial exo engine piece up front! |
04-02-2015, 11:01 PM | #71 |
| Re: Sp3cia1-K's Goat Built Ibex Build |
04-02-2015, 11:04 PM | #72 |
What axle shafts did you use with the XR lockouts front and rear? Did you grind new flat spots on Wraith axles and then cut off extra lenght or?
04-02-2015, 11:47 PM | #73 |
04-08-2015, 04:06 AM | #74 |
04-11-2015, 08:57 AM | #75 |
Got everything back together and went for a solo run to make sure all is good. She is looking good but not happy with the cage paint.. we'll see how long I can stand it. Here are some shots from today, radio in one hand, slr in the other while chasing the truck around. Not bad considering This shot gives a bit of an insight to the paint condition after just one run.. The silver under coat is still in good condition though with the exception of around the new alterations up front. I love the look of the new inner guards too, simply just some 0.5mm alloy sheet cut and bent to match the chassis just like on the 1:1s. Here is my new trailing arm setup as well made by a local trail mate. I ended up having to do a fair bit of modding to get these to look/work right, that's only cause I didn't think of the shock angle prior to getting them made. They originally had revo ends front and rear but meant my shocks lent forward rather than vertical or backwards. To fix this I needed to move the lower mount back by shortening the rod end and arm behind the mount and lengthening in front with Jato ends. Worked out perfectly in the end! Last edited by Sp3cia1-K; 04-11-2015 at 09:00 AM. |
04-13-2015, 12:12 PM | #76 | |
Quote: Bake at 200F for one hour after each coat and then ready to assemble. | |
04-13-2015, 01:14 PM | #77 |
I have a 4 grub screw locker in the rear so I don't really have any issues with that side of things. It is the HR locker and have a LU FI spool up front. I don't think this was a bake paint as it was an overcoat/candy paint. I'll keep running it for now till I see something else I need to tweak on the chassis, like I should have added sway bar mounts on the rear somewhere |
04-13-2015, 03:34 PM | #78 |
OK thanks. The paint baking works for all spray paint and really makes a huge durability improvement. I've found that baking several times makes the paint even harder and more chip and scratch resistant. |
04-13-2015, 06:35 PM | #79 |
Great work on the update!
04-13-2015, 08:10 PM | #80 | |
Thanks Harley! I went ahead and put some sponsors on it the other day too, I wasn't going to be recreating the sponsors on the JDS livery, but more so just the overall design. Here it was on Sunday at the weekly social. We hadn't even left the car park when I found the biggest bolder that I for what ever reason didn't see and went BANG into it at full pelt on the left front wheel.. Exploded my servo horn into 2 or 3 pieces and broke the front short side axle shaft. It absorbed alot of force in the hit too! The shaft twisted nearly 1/4 of a turn before failing. The failure was where I had shortened the shaft for the narrower axles and I have always driven the thing hard, and some poor driving on my behalf at times.. I have another set of unis waiting to get narrowed anyway as I was planning on going rear steer for a bit of fun. Sooo we'll see if that still happens. Last edited by Sp3cia1-K; 04-13-2015 at 08:14 PM. | |
Sp3cia1-K's Goat Built Ibex Build - Similar Threads | ||||
Jethro's Ibex build (Harley's Plans Scaled for 1.9's) | Jethrobodean | 1.9 Scale Rigs | 80 | 02-11-2020 07:03 AM |
Harley's Ibex Goat Built Wraith | Harley | Axial Wraith | 57 | 09-09-2019 02:19 PM |
2.2 Ibex build | MNorby | 2.2 Scale Rigs | 17 | 10-03-2015 07:20 AM |
1.9 Ibex budget build | Brassbender805 | 1.9 Scale Rigs | 0 | 06-19-2014 10:58 PM |
Sp3cia1-K's Poison Spyder Wraith Rebuild | Sp3cia1-K | Axial Wraith | 26 | 04-14-2014 07:24 AM |
