11-29-2014, 02:42 AM | #61 |
Quarry Creeper Join Date: May 2010 Location: Perth, Australia
| Re: Mattzilla Ultra4 2014 build from down under - codename "Gojira"
ESC mounted to the tray and motor wired up.. i can almost feel the drive on this now its so close to being useable plenty of room in the radio box (its a Yeti fuel cell).. and here's a mockup in Photoshop of the colour scheme and some sample logos (not the final logos or placement but you get the idea).. Last edited by mce076; 12-03-2014 at 06:42 AM. |
11-29-2014, 04:45 AM | #62 |
Rock Crawler Join Date: Sep 2011 Location: FNQ Australia
Are you keeping the on/off switch ? I cut and solder all of mine , they tend to get a bit of dust in them and glitching /shorts happen . The other solution is blutac around the switch which stops the dust but makes it un-usable so I just cut them off.
11-29-2014, 06:26 AM | #63 | |
| Re: Mattzilla Ultra4 2014 build from down under - codename "Gojira" Quote:
i'll leave it for now and see how it goes and if its an issue i'll do something about it one thing though, i wouldnt mind making an emergency cut off loop for the battery lead somewhere given its 6 screws to access the pack or a bit of finger contortion to get to the on/off switch | |
12-03-2014, 06:45 AM | #64 |
so there's no room to mount a sway bar pre-built into the chassis.. i opted for this setup while i consider my options, which is very much like some monster trucks use (its also now on the top of the links) panels are now primed ready for painting.. and a poser shot with a change of scenery for once |
12-04-2014, 07:35 PM | #65 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Great looking rig!
12-05-2014, 04:11 AM | #66 |
| Re: Mattzilla Ultra4 2014 build from down under - codename "Gojira" |
12-05-2014, 08:55 AM | #67 |
Quarry Creeper Join Date: Sep 2007 Location: Hancock MD
wow this thing is unreal on the packaging, everything is hidden out of view but then the rig doesn't look cluttered up to purposely hide it.
12-05-2014, 09:53 AM | #68 |
Pebble Pounder Join Date: Mar 2012 Location: Port Angeles
That is a bad ass rig!!!!
12-07-2014, 02:26 AM | #69 | |
it didnt take much effort to keep all the internal wires hidden just needed the battery tray/shield to hide that one away i've actually gone through phases of liking/disliking it as various parts progressed but i think that was just me being used to seeing a certain look sometimes what you see in your head is hard to put out there in reality lol but i am very much pleased with results so far | |
12-07-2014, 02:30 AM | #70 |
i gave in an decided to start painting the panels.. couple mistakes here and there and learning that TS paints dont like isopropyl when they're not completely cured the reason for the isopropyl was to clean the tape residue from the orange stripe as the 3M tape i normally use on lexan seemed to leave a residue on that colour i still have the roof and bonnet to do but not sure how to paint it.. it needs to have the same scheme extended to there somehow but still deciding on exactly what to do Last edited by mce076; 12-12-2014 at 11:14 PM. |
12-08-2014, 05:33 AM | #71 |
small update.. the battery tray/shield has been painted now... this just leaves the roof and bonnet still but i'm having a hard time visualising the final look that i think i want |
12-09-2014, 04:55 AM | #72 |
next panel completed is the roof panel.. this leaves time to stress over the bonnet and also do the grill piece (which might be re-made so i can do some cutouts easier) |
12-12-2014, 11:10 PM | #73 |
this update will be pic heavy as all the panels are finished.. i decided to cut some holes in the front grill piece to suggest that lights were previously there and painted to match.. i then did a mockup on the bonnet to visualise the final look.. so with the grill completed and the bonnet painted, here's the final paint job.. this leaves me just to install things like lightbars and do the decals.. Last edited by mce076; 12-12-2014 at 11:12 PM. |
12-13-2014, 07:51 AM | #74 |
RCC Addict Join Date: Dec 2012 Location: Crookston
Rig looks really good. Can't wait till I get mine to start on it. Got some good ideas from you build that I am wanting to try. You going to start on the Mantis chassis now?
12-14-2014, 09:18 AM | #75 | |
glad that my build has given ideas, thats one of the things that i like about this segment of the hobby.. the sharing of ideas and seeing how others solve problems or put together the same parts with different outcomes is awesome i'm still not done with this one just yet but it could be a few weeks before any updates and its finalised | |
02-10-2015, 06:41 AM | #76 |
so there's been some minor changes since the last pics were posted - first thing was to swap out the Rock Beasts for a taller set of tires so went with the Growlers - then i played with the track width, front is now 10.5" rear is 10.25" - upped the spring rate on the front to the next step - removed the spare tire, think it looks better then i took it out for its first shakedown run.. i managed to clip a triangle rock sticking out of the ground with the axle right in front of the right side link mount that resulted in a snapped revo rod end, which brought the session to an early end unfortunately here's the damage.. i was quite pleased with how it was handling but i think i'll now soften up all the suspension now that i feel the balance is right.. here's some photos of how it came back home.. |
02-10-2015, 06:53 AM | #77 |
Looks good. How do you like the growers? Been thinking of getting a set for mine.
02-10-2015, 07:36 AM | #78 | |
what i did notice was the weight of this (7.1lbs being class legal for U4RC 1.9 Trophy) combined with the Duece Wild single stage foams it doesnt climb anywhere near like my comp setup Scale 2 chassis.. i think they will wear in a lot better, they felt a little slippery out of the packet but they now have a different feel so they should come in given some time to wear out in the dirt and driving around on grass, flat rock and loose stones/gravel they worked well enough | |
02-20-2015, 06:32 AM | #79 |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
What was your runtime like with that 3S 2200 with that kind of weight? Curious as I am looking at batteries for my U4 chassis. Thanks Wes |
02-20-2015, 07:17 AM | #80 | |
i just drove up and down in straight lines at full throttle all the time to see how long it would last runtime was around 20mins, motor temp was mid 80s (celsius) out in the dirt with a mix of fast bursts and slow rock crawling would give you a longer runtime | |
Mattzilla Ultra4 2014 build from down under - codename "Gojira" - Similar Threads | ||||
Scale 2 build and progress - codename "Colonel Mustard" | mce076 | Axial SCX-10 | 39 | 11-05-2014 05:30 AM |
801rcc 2014 Ultra4 and Trail, Event #9 "Descent into Darkness" | NaZ-T | Competitions | 1 | 09-26-2014 01:37 PM |
801rcc 2014 Ultra4 and Trail, Event #8 "Elevated Chaos" | NaZ-T | Competitions | 2 | 07-31-2014 07:33 PM |
801rcc 2014 Ultra4 R/C, Event #6 "Dusted Desert 600" | NaZ-T | Competitions | 3 | 07-01-2014 07:02 PM |
801rcc 2014 Ultra4 R/C, Race #1 "Rock Rail Express" | NaZ-T | Competitions | 10 | 01-18-2014 03:49 PM |
