11-07-2019, 05:38 PM | #221 |
Quarry Creeper Join Date: Jan 2016 Location: Wichita
| Re: hillbilly's LOW RANGE inspired cab swapped bronco
Man, you've made some great progress! Sent from my SM-G955U using Tapatalk |
11-07-2019, 11:05 PM | #222 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
Since swapping axles I'm happier with how things are coming along now. Still a ton of work but closer then I was.
11-12-2019, 11:16 PM | #223 |
| Re: hillbilly's LOW RANGE inspired cab swapped bronco |
11-13-2019, 01:07 AM | #224 |
11-25-2019, 04:31 PM | #225 |
11-30-2019, 12:08 PM | #226 |
Finally mounted the body with some dual lock Velcro. I did have to use some e6000 on the body side mount plate and the back side of the Velcro so it wouldn't rip off. Very secure if I say so myself. That is the whole weight of the front of the truck lifted by a finger no other support. Haven't decided if I will make a mount in the back of the cab or not. Next is electronics mounting and paint and bodywork. |
03-12-2021, 07:44 AM | #227 |
Pebble Pounder Join Date: Feb 2021 Location: ERF
This is a great thread, is this thing still in the works?
04-23-2021, 10:48 PM | #228 |
| Re: hillbilly's LOW RANGE inspired cab swapped bronco I still have it but it's sitting in a box atm. I need to clean up a work space to finish it. I need to get some soldering tools to put my electronics in. I'm kinda stumped on the interior and making a dash. Might just wait and make it work first.
06-30-2021, 10:16 AM | #229 |
I think I have the interior figured out, it's very rough right now but I have a direction I can work towards. Just a pic with a tool box I picked up a while ago One step back I'm changing the transmission up it will still be forward motor but something a little more compact, waiting on shipping. Another set back the driveshaft is bought for t-case to front axle wasn't long enough in need of a 70mm/90mm. |
hillbilly's LOW RANGE inspired cab swapped bronco - Similar Threads | ||||
Rock bouncer vs. Low range crawler | ShagbarkSheriff | Axial Wraith | 13 | 12-03-2016 08:38 PM |
need low range gear | dhoffroad | General Crawlers | 6 | 02-05-2006 09:23 PM |
2.2's without low range mod ?? | dhoffroad | General Crawlers | 17 | 01-30-2006 01:22 PM |
Surging when in low range/ axles won't shift | theone13 | General Crawlers | 3 | 09-02-2005 09:34 PM |
