06-13-2007, 11:08 AM | #61 |
RCC Addict Join Date: Sep 2005 Location: Beaver County, PA
06-16-2007, 05:00 PM | #62 |
Pebble Pounder Join Date: Dec 2006 Location: Earth
you thought of basing a rig around a Proline Desert Rat body? that would look killer!
06-16-2007, 08:48 PM | #63 |
Corr Truck Corr Truck Corr Truck Corr Truck Corr Truck
06-16-2007, 09:22 PM | #64 |
RCC Addict Join Date: Jun 2006 Location: spotting for jeepsohigh
So im guessing CORR truck I will get to modifying the chassis to change the wheelbase and rear clip. The desert rat body is pretty coll but the only one thats close on size is the 1/8 scale body for gas truggy but the one i have is a little more scale looking. OK now Red bull paint job or maybe Carl Rendezender Lucas Oil paint job? |
06-17-2007, 03:50 PM | #65 |
I'd go red bull paint job because it looks great on anything
06-17-2007, 04:03 PM | #66 | |
Pebble Pounder Join Date: Mar 2007 Location: creepin through the gates!
Maybe he is just good and the welder he is using is a good one, I have a millermatic 251 that will do it. Dont doubt the mans skills some people are just tallented. | |
06-17-2007, 09:11 PM | #67 |
Well stupid me forgot to turn off the gas bottle so now its empty:-( I will get it filled this week and proceed with changes to the truck. Anyone got a set off toureg stickers for the paint job if I go with the Redbull look?
06-18-2007, 06:52 AM | #68 | |
Already sold mine to another member, but Ebay usually has them. | |
07-26-2007, 03:28 AM | #69 |
Pebble Pounder Join Date: Apr 2007 Location: Anchorage
Did you get your bottle filled? I want an update...
08-06-2007, 08:50 PM | #70 |
Rock Stacker Join Date: Feb 2006 Location: Brick
I want to see a vieo of this thing running, I was watching your older prerunner build for a vid, but it looks like it is being used towards this one... NICE BUILD !... |
12-03-2007, 08:22 PM | #71 |
Newbie Join Date: Jan 2006 Location: Browns Mills
Any updates?
12-05-2007, 05:41 PM | #72 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
I really like the truggy, looks really clean. Will you post some info on your tecnique and materials for making the body?
12-06-2007, 07:02 PM | #73 |
Sorry guys no real updates other than its a coplete handful to try to drive. i say try cause it just spis the tires and lifts both fronts off the ground if it goes straight long enough to stay in it. As for the body its just .020 o aluminum, o being annealed so it is very soft the cage is all 3/16 aluminum welded and smoothed out at the welds. Thanks for the comments and i will do my best to get a vid soon but weather has turned bad here but i will try as soon as i can.As far as the other one i did use parts to finish this one but i still want some kind of CORR Pro 2 truck that i am gather stuff for.
12-07-2007, 02:04 PM | #74 |
Sorry for the questions, but what is annealed? After you make it soft do you just press it against the body or do you use tools like a hammer and dolly to shape it?
12-07-2007, 04:51 PM | #75 |
There are different hardness levels of aluminum T3,T4,ect. annealed is the softest most flexible of aluminum . I made a wood forming block and used a soft hammer to form the panels i also used a shrinker/stretcher on some places. Bottom line is the more time you spend on it the better the end product will be take your time and try not to get frustrated. Also the good thing about using annealed aluminum is after your finished it can be heat treated to give it more strength like t3 or t4. If you try to use something to hard it will just crack and break. I am no expert at this justhave some basic knowledge here so i'm sure someone might be able to give you some more info or correct me if i'm wrong.
12-08-2007, 07:33 PM | #76 |
thanks for the info. do you buy it online or from a local shop?
12-08-2007, 08:29 PM | #77 |
I borrowed it from work SHHHH! I am a mechanic for an airline so we kinda have a abundance of aluminum laying around .
12-08-2007, 08:52 PM | #78 |
Rock Crawler Join Date: Jan 2006 Location: Vacaville, CA
this is awsome. im building my pre runner right now!
12-09-2007, 10:46 AM | #79 |
Quarry Creeper Join Date: Nov 2007 Location: WNC
Beautiful. I love seeing CORR/Baja Styled prerunners.
12-23-2007, 08:42 AM | #80 |
I got some time and parts and started the rebuild. The body panels are just mockup right now. Reworked the front end with some Pede donor parts to lose some weight and help stiffen it up.
