08-14-2008, 09:35 AM | #41 |
Newbie Join Date: Aug 2005 Location: Martinsburg
Never done the mod but I would think you would need to hold the yoke in a vice to secure it, and go slow with the drill bit.
08-14-2008, 11:02 AM | #42 |
Rock Crawler Join Date: May 2008 Location: Mansfield, PA
08-14-2008, 03:06 PM | #43 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
08-14-2008, 03:14 PM | #44 |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
If you do these by hand like I did you'll need to use a step-drill and not a drill bit. A drill bit cut's in a triangle pattern, so by the time you get the size your need the yoke will have a oval shape to it. A step-drill is WAY easy and cuts a perfect circle. Hold the yoke in a pair of Channel locks and go slow. Good luck. |
08-14-2008, 03:30 PM | #45 |
Hmmmm, now I didn't think of that. Looks like I will hit up Lowes Depot on the way home. Thanks.
08-14-2008, 06:05 PM | #46 |
Newbie Join Date: Jul 2008 Location: NB
I used a UNI-bit as well. Worked ok, then I finished the depth needed with a drill bit. Didn't turn out too bad for my first driveshaft. With that said my next shaft will be done on a lathe. G. |
08-14-2008, 06:27 PM | #47 |
RCC Addict Join Date: Apr 2008 Location: Singapore
I used a low speed driver/drill.
01-21-2009, 08:11 PM | #48 |
Rock Stacker Join Date: Jul 2008 Location: Carbondale
i know i have experienced this myself and probably most here who have done plastic drilling before my buddy said for lexan and plastics like that you can detune the tip of the drill bit so it doesnt just auger in as much(you'd have to make the cut face a little more square as oppossed to a surf wave lip like most bits have), does that give you the idea? he knew about some other ways to do it as well, but he said that most bits don't go down to these sizes we are using on these rc's i also liked his idea to put the yoke in the drill chuck and then have the drill bit fixed solid and do it that way, cave man lathe if you will |
01-21-2009, 09:56 PM | #49 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
what is the benifit of going this route and the extra work over going with what i did here with traxxas steel yokes and there other shafts................bob .... |
01-22-2009, 11:03 AM | #50 | |
Rock Crawler Join Date: Sep 2008 Location: Marysville, WA
Since running the Maxx shafts, I haven't had any issues with yoks or driveshafts. | |
01-22-2009, 02:05 PM | #51 | |
Last weekend I did this mod and the driveshafts are holding up great now. Got through a whole scale comp plus some extra trail riding with no driveshaft issues. | |
01-22-2009, 04:07 PM | #52 | |
OR you can use a end-mill bit instead of a drill bit..... works much better | |
01-22-2009, 10:06 PM | #53 |
i like the metal driveshaft yokes, are the shafts metal? you'd think there would be a metal shaft to work with those already if not. or be close enough to mod at least, any part numbers?
04-02-2009, 09:46 PM | #54 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
Just did this mod today, turned out Awesome. The lathe was definantly the ticket for getting the Traxxas T-maxx yokes drilled tho. Thought I'd save some time and vice it up and hand drill it, NO NO NO, that don't work. Drill press maybe, but I did use the dremel to cut the ears off the stock yoke. This is a seriously great drive shaft mod that anyone should be able to do. Gives a lot of BEEF to the drive train and is much better and cheaper than changing out steel yokes only to use a "smaller" traxxas shaft anyway. here's my pics.
04-03-2009, 08:41 AM | #55 |
Yup, I still have never even worried about mine. Strong as hell these are (Yoda).
04-03-2009, 12:37 PM | #56 |
Quarry Creeper Join Date: Aug 2007 Location: Morrison Crawlerado
Glad to see that this is still one of the best upgrades without getting MIP's and cutting/welding them. I just switched to Lipos and shattered to stock shafts and a CVD in about 5 minutes! I don't have a lathe so will be trying the step-drill bit or a uni-bit. |
04-08-2009, 09:24 PM | #57 |
Pebble Pounder Join Date: Sep 2007 Location: Fallbrook
cool post, iv been wondering why one of the venders dosnt sell a bolt on yok to install max shafts right into a axial crawler.
04-08-2009, 09:36 PM | #58 |
04-08-2009, 09:52 PM | #59 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
04-08-2009, 10:02 PM | #60 |
