11-10-2008, 10:13 AM | #701 |
Pebble Pounder Join Date: Feb 2008 Location: Canterbury
Just received my SWX. What an awesome looking chassis. Cannot wait to get this thing together. Once again, GREAT JOB BENDER !!!! |
11-12-2008, 03:00 PM | #702 |
Rock Stacker Join Date: Nov 2008 Location: Rock Springs
Just ordered my SWX. It won't be in till late Nov. This should give me plenty of time to come up with the other parts.
11-12-2008, 07:30 PM | #703 |
Quarry Creeper Join Date: Jul 2008 Location: Garden State
Finally got a chance today to run my SWX and i am really surprised with the handling over the stock kit. Side hilling was awesome climbs and drop offs are really smooth I can't believe how stable this thing is. I started off with white springs and 50 weight oil front and rear with a belly clearance of 2 3/4 and the truck was a little too soft, resulting in a little twist mind you I run about 60-70 degrees of articulation. i then switched to red fronts and silver rear and the truck came to life. I defiantly was able to run lines that my stock set up could not. Very impressed once again with this chassis .
11-13-2008, 09:13 AM | #705 | ||||
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Quote: | ||||
11-13-2008, 09:32 AM | #706 |
Rock Crawler Join Date: Oct 2008 Location: Sandy, OR
I have to say I am really impressed with my SWX. I have been making small changes for the last two weeks and the chassis is really responding well. I moved my dig servo down similar to Benders and limited my shocks a little and this thing flat works right now. I finally pulled off a win in our weekly comp, so something must be right. |
11-13-2008, 01:07 PM | #707 |
Axial needs to make Bender decals. Don't you think?
11-13-2008, 07:19 PM | #708 |
Newbie Join Date: Sep 2008 Location: Vancouver
Just wanted to post up and say the SWX is great. Made some minor changes to the link positions and this chassis flat out rails with my driving style. Sitting first over all in a LHS weekly comp and very happy with set up |
11-17-2008, 08:59 AM | #709 | |
Hmmmm...... Glad to hear it's working good for you too. | |
11-17-2008, 09:31 PM | #710 |
Rock Crawler Join Date: Jun 2008 Location: dublin
| 4-link In Front
BENDER, WHEN ARE YOU GOING TO MAKE A 4-LINK PLATE THAT WORKS ON THE SERVO / BATTERY SET UP LIKE IN YOUR LAST PICS ? (servo mounted low and on angle) THANKS AND KEEP UP THE GOOD WORK WHAT FOAMS DO YOU RECCOMMEND USING THE LOSI ROCK CLAWS ?? THANKS FOR YOUR OPINION |
11-18-2008, 08:40 AM | #711 | |
I run the same foams in my Rock Claws that I run in the HB tires, NWTT #8 Reach foams. | |
11-18-2008, 07:02 PM | #712 |
Quarry Creeper Join Date: Mar 2008 Location: richmond
after dabling with a losi white springs i gave up on them. i tried out like2crawls setup of reds in the front and silver in the rear,and WOW what a difference. with the limited articulation and stiffer rates the truck really feels planted and predictable! sidehilling has been improved alot as well! so reds with 27 1/2 and grays with 50 great starting point |
11-18-2008, 07:15 PM | #713 |
Pebble Pounder Join Date: Apr 2008 Location: Long Beach Ca.
Brad witch #8 NWTT. Hybrid, All weather or Rockhammers? Front and rear both? Thanks for the help. Last edited by prdquik; 11-18-2008 at 07:18 PM. |
11-18-2008, 09:50 PM | #714 |
11-20-2008, 08:40 AM | #715 | |
They all work great. I like the extra height of the HB tires. I like the sidehilling ability of the Carvers, but the Claws are tough to beat when it comes to pulling off steep climbs. | |
11-20-2008, 03:24 PM | #716 |
Newbie Join Date: Nov 2008 Location: Planet Earth
11-20-2008, 05:08 PM | #717 |
11-20-2008, 05:26 PM | #718 |
Rock Crawler Join Date: Jul 2008 Location: Chula Vista
Brad what right height are you running? My SWX is at 3" which seems high to me. My Axial Stocker was at 2.5"
11-20-2008, 05:56 PM | #719 |
Pebble Pounder Join Date: May 2008 Location: Kalispell Montana
11-20-2008, 06:10 PM | #720 |
Hey Bender, is it possible to buy the SWX skid and links? Basically the full chassis kit without the frame plates. I want to update my SW3.
