10-30-2008, 09:24 AM | #661 |
Pebble Pounder Join Date: Aug 2008 Location: Indonesia - Rock Heaven
Hi Brad, I was wondering why are you and Austin (Dunn) prefer spring compression shock instead of droop? Since I've found spring setup is harder to adjust than droop..Thanks for answering my question...
10-30-2008, 09:49 AM | #662 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Nice looking rig. The biggest reason is torque twist. I personally don't like how droop set-ups can unload in some situations because of the torque from the driveshafts. Droop works better with Berg and Clod style axles IMO. | |
10-30-2008, 12:17 PM | #663 |
Thanks for your swift reply...could you please give me more detailed explanation? Furthermore, which do you think is best..fast unload or slow unload? Did you use different shock oil (WT) between front and rear shocks and can you please tell me how much weights did you put on each front and rear wheels...sorry too much asking..hope you don't mind... Last edited by dirtworkshw; 10-30-2008 at 12:26 PM. |
10-30-2008, 01:03 PM | #664 |
Quarry Creeper Join Date: Jul 2008 Location: Garden State
The search function has alot of valuable data. |
10-30-2008, 07:13 PM | #665 | |
Here's a couple pics of my last few mods. I installed JR's 8711 servo out front recently, which made a huge difference over my old 200oz Sanwa servo. I also swapped out the dig servo for Hitec's 985mg. The last pic is of my front body mount for those that were asking about it. | |
10-30-2008, 07:17 PM | #666 |
Quarry Creeper Join Date: Nov 2007 Location: Lakewood-Crawlerado
how'd you convince losi to let you use those tires? what do you think of them? Looking good man |
10-30-2008, 07:53 PM | #667 |
Pebble Pounder Join Date: Oct 2007 Location: Bay Area
Brad is your dig servo currently mounted with just the 2 posts going to the skid or is there another mount point on the rear of the servo. In one of the pictures I can see what looks like a 3rd screw... My SWX chassis should be in next week to go with my SW3. I'm looking forward to mounting up my new dig in it. |
10-30-2008, 08:00 PM | #668 | ||
10-30-2008, 08:21 PM | #669 |
Thanks for the info. Mounting the servo this way looks better than the normal location. Good to know a larger servo will fit there if the 225 I have burns out quickly.
10-30-2008, 08:24 PM | #670 |
Looks very nice Fred, may have to resurrect my sw-3 proto truck into a axial/ losi crawler. any pics of the outside mounting location of that nice steering servo plate you made? I see the 2 in the middle, but curious on the outside ones? knuckle screw?
10-31-2008, 04:05 AM | #671 | |
10-31-2008, 08:49 AM | #672 | |||
New Comp Build.......SWX......New Production Pics!! Quote:
10-31-2008, 11:17 AM | #673 |
Newbie Join Date: Oct 2008 Location: arcade
hi brad i see you switched springs from losi white and front stampede on left rear what are you running now im in the process of setting up my swx thank you for all the help
10-31-2008, 11:28 AM | #674 |
| I went to Losi reds out front, the black Pede spring got swapped to the right rear and the left rear is now a silver Losi spring. |
10-31-2008, 02:01 PM | #675 |
I wanna be Dave Join Date: Mar 2008 Location: Pacific Ocean
Bender, Is the R2D transmission meant to mount to the 2 side holes only in the chassis plate? Or is it recommended to drill mounting holes in the skid as well? It seams pretty solid just mounted to the plate, just wanted to be certain. Thanks, great chassis |
11-01-2008, 12:16 PM | #676 |
Brad, what dig unit you are you using now? Looks like DNA..am I correct?
11-01-2008, 02:43 PM | #677 | |
The R2D can be mounted to the chassis plate only, there's no need for holes in the skid plate. That is correct, I'm running the DNA dig. | |
11-02-2008, 10:15 AM | #678 |
Thanks Brad......so what is the total weight of this rig? And how many inches between belly to the ground? Also the total width of SWX chassis (with skidplate installed) measured from one outer sideplate to the other outer sideplate, because I wanted to prepare a body earlier before ordering this chassis...many thanks...
11-03-2008, 09:39 AM | #679 |
Brad are you running 2 chassis braces in the front to help remove flex on the open chassis side front to rear or was it done for another reason? I noticed in the rear you only run 1.
11-03-2008, 10:12 AM | #680 |
Pebble Pounder Join Date: Feb 2008 Location: Canterbury
Nice build. Think I am going to order an SWX chassis this week after reading this thread. Thanks for all the great info ! |
